JB Weld on drain plug!!
brookshay
brookshay is offline
PostPosted: Wed Apr 23, 2014 8:09 am    Post subject: JB Weld on drain plug!! Reply with quote
Subject says it all, trying to figure out options here.
85 Westy original 1.9.
Any thoughts or suggestions?
85 Westy
PDXWesty
PDXWesty is offline
PostPosted: Wed Apr 23, 2014 8:13 am    Post subject: Reply with quote
What's the problem? Stripped case, stripped plug, trying to remove jb weld from the drain plug? I think you do need more description on what you are asking.
89 Westy 2.1 Auto
brookshay
PostPosted: Wed Apr 23, 2014 8:14 am    Post subject: Reply with quote
My apologies. The plug has been jb welded in and cannot remove to drain oil.
I'm guessing there was a reason behind the jb weld but can't get past it to see what it is.
85 Westy
borninabus Premium Member
Samba R&D Dept.
borninabus is offline
PostPosted: Wed Apr 23, 2014 8:18 am    Post subject: Reply with quote
one would have to assume that the case is stripped.
do what ever it takes to remove the drain plug and then (dependent on how much damage you do) either use a longer drain plug or a timesert in the case.
not the end of the world, by any means Wink
88 Van WBX, A/T - 13 JSW TDI 6M/T - 2012 Touareg TDI Sport
Samba R&D Dept.
PostPosted: Wed Apr 23, 2014 8:19 am    Post subject: Reply with quote
and by 'do what ever it takes' i mean put a big breaker bar on it and break it loose Twisted Evil
brookshay
PostPosted: Wed Apr 23, 2014 8:21 am    Post subject: Reply with quote
Ok that's encouraging. The folks that I think did it are looking to replace the pan, which I haven't been able to locate a replacement for?
85 Westy
PDXWesty
PDXWesty is offline
PostPosted: Wed Apr 23, 2014 8:30 am    Post subject: Reply with quote
There is no drain pan on a WBX. The drain plug is threaded right into the engine case. Try not to do too much damage or you'll be replacing the whole engine. Maybe a little heat would help?
89 Westy 2.1 Auto
Terry Kay
Banned
Terry Kay is offline
PostPosted: Wed Apr 23, 2014 8:42 am    Post subject: Reply with quote
Get a torch with a small tip & heat up JUST the plug.
Get it hot, and back it out of the engine.
What your mission is to get the epoxy soft enough to be able to spin the plug out.
Don't go crazy here or you'll have aluminum rolling off of the engine block.
Obviously there is a problem with the hole for the drain plug--be prepared to be repairing that with an oversized self tapping plug, or a thread insert.
Some hobbiest did that engine a big favor .
T.K.
jackbombay
jackbombay is offline
PostPosted: Wed Apr 23, 2014 11:29 am    Post subject: Reply with quote
JB does get pretty useless above 600*
I second the heat it up then twist it ASAP with a socket.
Gas struts to pop your top easily!
Pop Top strut kits now available for late Bay window Westies Smile
Samba ad here.
DIY artificial rain gutters (ARGs)
Wildthings
Wildthings is offline
PostPosted: Wed Apr 23, 2014 12:02 pm    Post subject: Reply with quote
Never tried using one of those oil suction setups, but maybe that would be a better option than dealing with the plug.
brookshay
PostPosted: Wed Apr 23, 2014 12:18 pm    Post subject: Reply with quote
Many thanks for the help and suggestions. I am very thankfully going to be working on this with someone who knows much more about it than I do. Excited to learn through this one.
85 Westy
MrBuelterman
MrBuelterman is offline
PostPosted: Wed Apr 23, 2014 3:08 pm    Post subject: Reply with quote
You could leave the drain plug alone and use one of these,sucking the oil up through the dip stick, for your oil changes.
Could save you from having to deal with the chance of killing the engine case.
0to60in6min
0to60in6min is offline
PostPosted: Wed Apr 23, 2014 4:00 pm    Post subject: Reply with quote
that's the solution...
I would do the same
Corwyn Premium Member
Corwyn is offline
PostPosted: Wed Apr 23, 2014 4:09 pm    Post subject: Reply with quote
I would do the same
It's what I use to change the oil in my boat's diesel engine; the drain plug is just a bitch to get to. Maybe change your filter more often too.
'90 White Westy ("White Lightning")
FAS Gen V 2.0
The Annual Baja Rally
~ Captain Ron ~
vweggie
vweggie is offline
PostPosted: Wed Apr 23, 2014 4:55 pm    Post subject: Reply with quote
There's a second plug that you can drain oil with it uses a 6mm allen key if I remember correctly. My previous van had a stripped plug so I used the other plug to drain the oil. It takes a bit long because of the smaller diameter hole.
1990 Multivan 2.1 AT
