Which Mahle Pistons / Cylinders?
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Fri Apr 25, 2014 12:38 pm    Post subject: Which Mahle Pistons / Cylinders? Reply with quote
Rebuilding a stock late model Beetle fuel injected engine and there are 2 different Mahle sets. Is one better than the other and why?
311 198 069 FFG Engine Piston Set w/ Forged Pistons
311 198 069 F Engine Piston Set Flat; CR 7.7:1
And don't say the bottom because the top only comes with one piston Wink
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
Dan Ruddock
Dan Ruddock is offline
PostPosted: Fri Apr 25, 2014 12:46 pm    Post subject: Reply with quote
Glenn, the top forged ones are better but on a stock engine they are over kill.
You got my second gift, yes?
Mr. 010
Glenn is offline
PostPosted: Fri Apr 25, 2014 1:02 pm    Post subject: Reply with quote
Yes... no rush on the rest.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
udidwht
udidwht is offline
PostPosted: Fri Apr 25, 2014 9:26 pm    Post subject: Reply with quote
I'd go with AA myself. The Mahle sets I've run across have been unsightly and off out of the box. I thought I remember hearing that AA was making the Mahle sets these days?
1972 Westy Hardtop/Type-4 2056cc
96mm Biral AA P/C's~7.8:1CR
71mm Stroke
73 Web Cam w/Web solids
Bosch W8CC plugs
S&S 4-1 w/Walker QP 17862
3 rib 002 Trans
185R14 Hankook tires
bugguy1967
bugguy1967 is offline
PostPosted: Fri Apr 25, 2014 9:37 pm    Post subject: Reply with quote
Heard the same thing about AA and Mahle being the same thing.
The cast pistons have longer skirts, so they'll need to be trimmed if using a C/W crank. I would vote on the forged set, just because of the lean tune of the stock FI system and the higher head temperatures.
Also, because of the a/f ratio, I believe it's important that the static compression gets set per the manual.
"A petrol engine can start readily, run smoothly and give every appearance of being in good order, without necessarily being in good tune." - Colin Campbell, "The Sportscar Engine"
