zak59 Samba Member
Posted: Sun May 25, 2014 8:37 pm Post subject: aircooled vw motor into subaru brat |
What would the pros/cons be?
4wd hi/low
Fairly light weight(it would be if it was mine)
Lift tires 27 inch swampers possibly
Let me know your opinion and wat you think pros/con would be in your mind |
KrAzY-BaJa Samba Member
Joined: May 22, 2008 Posts: 1409 Location: Sacramento CA.
Vanapplebomb Samba Member
Joined: November 03, 2010 Posts: 5572 Location: Holland, MI
Posted: Sun May 25, 2014 9:21 pm Post subject: |
Posted: Today 11:15 pm Post subject:
Pros:
Not much...
You could say it has an air cooled motor for bad a$$ points
Oil pan won't hang as low...but that really isn't a problem in the first place...
Cons:
Pretty much everything else in my opinion. The Subaru 4wd set up will not be of any advantage over the bugs rear wheel open drive. A bug works well off road because it has a heavy rear weight bias that more often than not keeps the driving wheels planted. The Subaru, although it would have a more even weight bias, wouldn't really have any advantage in the traction department. Also, the suspension will not do well at high speeds off road without major modifications, nor will it be any good at creeping over obstacles without major modifications. The chassis is also pretty flimsy.
Basically what you would end up with is a vehicle that is ok at some things but really isn't particularly good at anything.
This isn't any fault of putting a VW engine in a Subi... Truth be told, the Subi brat is just an unideal platform to start with. _________________ 1800 Type 4 Berrien 295
http://www.thesamba.com/vw/forum/viewtopic.php?t=487021 |
zak59 Samba Member
Posted: Mon May 26, 2014 12:05 pm Post subject: |
I'm not looking for power I'm just building something that will be street able kinda. Mostly hunt out of and cruise around logging roads etc. |
zak59 Samba Member
Posted: Mon May 26, 2014 12:07 pm Post subject: |
It will be a resident of my cabin. |
BUGGUTZ Samba Member
Joined: March 13, 2007 Posts: 537 Location: Luzerne Mich
Posted: Mon May 26, 2014 12:08 pm Post subject: |
Interesting concept. I would do it just to do it. Wouldnt sink a ton of money into it though. |
zak59 Samba Member
Posted: Mon May 26, 2014 12:11 pm Post subject: |
I was planning on $500 budget so most likely I'll put together a loyale and cut it into a truck or soft top the rear. |
tripicana Samba Member
Joined: February 13, 2003 Posts: 1164 Location: colorado springs
Posted: Tue May 27, 2014 11:09 am Post subject: |
You'll spend that on an adapter plate... _________________ foam cowboy hats aren't good helmets. |
Posted: Tue May 27, 2014 5:03 pm Post subject: |
I'm having a hard time imagining how you plan to put together a functioning rig for 500 bucks... unless you already have everything on hand ready to go... still. That is really pushing it. Not saying it can not be done...just won't be easy to make a safe running driving vehicle for that.
Tell us more about your plans for this vehicle. That way we may be able to offer some more constructive advice.  _________________ 1800 Type 4 Berrien 295
mkparker Samba Member
Joined: October 12, 2004 Posts: 333 Location: Sherman, Tx
Posted: Wed May 28, 2014 5:41 am Post subject: |
Check out all of the people installing Subie engines into Beetles, Buses, Ghias and Things these days and ask yourself why? _________________ Michael
Pit Boy 6163 Spec Trophy Truck |
Posted: Wed May 28, 2014 6:07 pm Post subject: |
I say go for it. I would like to see it done. You will get plenty of cons on here but I bet they would ALL look at the thread. |
Posted: Wed May 28, 2014 7:19 pm Post subject: |
KrAzY-BaJa wrote: |
No Pro's
Cons
-lack of power
-Reliability |
He could put a stockish type 4 vw engine in it. Not really any less powerful that the engine that would have come in the original vehicle. Plenty reliable as well
Downside is that a good type 4 engine is $$...certainly more than 500 bucks. _________________ 1800 Type 4 Berrien 295
earthquake Samba Member
Joined: January 10, 2008 Posts: 4001 Location: SANDY VALLEY, NEVADA
Posted: Wed May 28, 2014 11:18 pm Post subject: |
How are you going to make the VW motor run backwards? I thought they spin opposite of a Subi, do they make a reverse rotation cam for a VW like a Covair? How are you going to cool it? is there room for a fan shroud under the hood? _________________ 74 CLASS 11 LOOK-A-LIKE
69 DUNE BUGGY
79 INTERNATIONAL SCOUT II
05 SCION XB SERIES RELEASE 2[#437]
95 Chevy C3500 dually
98 Ford E150
Link to Kelly J. Nolte 3/20/53 - 11/6/08
https://time-zonelabs.blogspot.com/p/about-kelly.html
DEATH TO CHINGERS!
[From a military recruitment poster in the novel "The Stainless Steel Rat" By Harry Harrison] |
Bashr52 Samba Member
Joined: July 16, 2006 Posts: 5669 Location: On an island in VA
Posted: Thu May 29, 2014 6:19 am Post subject: |
I dont know of anyone having to reverse the rotation of a subie engine when they put them in a bug, so why would they have to in order to go the other way? |
Posted: Thu May 29, 2014 10:42 am Post subject: |
earthquake wrote: |
Is there room for a fan shroud under the hood? |
There should be plenty of room if you use a pancake style cooling system. A type 3 or type 4 would fit no problem. _________________ 1800 Type 4 Berrien 295
Posted: Thu May 29, 2014 6:15 pm Post subject: |
Corvair is reverse rotation, subi is fine. Its just a neat engineering project. Lets get it going. |
deja-vu
zak59 Samba Member
Posted: Thu May 29, 2014 10:44 pm Post subject: |
I can have the plate made for free. Just gotta design it off of a subie into bug plate. Everything else has been or will be made by me or free cheap parts.
No one said anything about safe or driven on the road for 5-10min periods in the middle of no where |
