best sealant for fuel lines
skills@eurocarsplus
Samba Peckerhead
PostPosted: Thu Jul 03, 2014 8:52 pm    Post subject: best sealant for fuel lines Reply with quote
as the title states, i was looking for something to seal some threads on the new outlet on my fuel tank.
i tapped the center of the outlet bung to accept a brass 5/16 (outlet) fitting. the problem is, i want to be able to remove it if needed, and i can't install it with the fitting screwed into the tank (going into a bus)
none of the permatex stuff i have found seems to be rated for gas
http://www.neverseezproducts.com/threadseal.htm
so, what have you guys used? really want to stay away from teflon tape if i can
gprudenciop wrote:
[email protected] wrote:
Jake Raby wrote:
Brian wrote:
74 Thing
74 Thing is offline
PostPosted: Thu Jul 03, 2014 9:27 pm    Post subject: Reply with quote
I used blue loctite before, but I also never took off the fitting afterwards. No leaks though!
FreeBug
FreeBug is offline
PostPosted: Thu Jul 03, 2014 11:56 pm    Post subject: Reply with quote
Gas is thin and slippery...you really want a positive seal with a fiber gasket or aluminum ring, or the like, im not sure thread sealant is the way to go. I may have misunderstood your question.
esde
esde is offline
PostPosted: Fri Jul 04, 2014 12:37 am    Post subject: Reply with quote
Did you tap it with straight threads or tapered? If they're straight, can you bottom the fitting against a copper washer? If they are tapered I'd use the thick yellow teflon tape, though I know you say you don't want to.
Quokka42
Quokka42 is offline
PostPosted: Fri Jul 04, 2014 1:58 am    Post subject: Reply with quote
Blue loctite usually works well, and is rated for gas at the necessary level for fuel lines. When dealing with N/A street engines, that is - if you are running a "fuellie," or even a straight methanol racecar, there is a different product that I can't remember the number of, but look up Henkel, or call and ask for a recommendation. Loctite 243 will even seal most turbo fuel injection lines on "gas." (Oh, and it's fine with ethanol blends.)
There has only ever been one man who was perfect, and they nailed Him to a cross.
fastfil
fastfil is offline
PostPosted: Fri Jul 04, 2014 3:29 am    Post subject: Reply with quote
Stag sealant has worked well for me. It's safe for petrol and won't 'lock' when it dries out. I always use a tiny bead when re-using copper sump plug washers.
I'm fairly sure it is still around. My tube is 19yo and I can no longer stab a screwdriver in to a gooey bit... Crying or Very sad
"...swingaxle...transaxle...same diff."
skills@eurocarsplus
Samba Peckerhead
PostPosted: Fri Jul 04, 2014 5:48 am    Post subject: Reply with quote
tapered threads
i thought about using blue loctite. perhaps i will go this route. i have read that the yellow teflon tape falls apart, and i didn't want to run the risk of using it...
Jake Raby wrote:
Brian wrote:
nobuggybob
nobuggybob is offline
PostPosted: Fri Jul 04, 2014 6:07 am    Post subject: Reply with quote
Gasola. It is used for threads when putting gas sta. pumps and piping together.
You Can't Quit Poverty
Dale M.
Dale M. is offline
PostPosted: Fri Jul 04, 2014 8:31 am    Post subject: Reply with quote
Teflon tape is a valid solution... However the bad part is getting onto fitting and getting fitting seated without shredding it....
Yellow or white tape same formula chemically so either will do....
How about plain old hardware store thread sealant... Recommended for almost any type of liquid or gaseous fuels including "gasoline"...
Pretty much thrown my rolls of Teflon tape in trash after finding this product (by brand) ...
Dale
bscriver
bscriver is offline
PostPosted: Fri Jul 04, 2014 8:42 am    Post subject: Reply with quote
Ive had this problem on boats before. I always use loctite aviation gasket sealer. has never leaked on me yet.
ONEBADBUG
ONEBADBUG is offline
PostPosted: Fri Jul 04, 2014 9:21 am    Post subject: Reply with quote
That stuff can be dissolved by alcohol, so... I would use liquid Teflon.
skills@eurocarsplus
Samba Peckerhead
PostPosted: Fri Jul 04, 2014 10:51 am    Post subject: Reply with quote
looks good to me
http://www.gasoila.com/products/pipe-thread-sealants/gasoila-e-seal-thread-sealant.html
i had read the same thing on a boat site before posting here. i would think that it would disolve over time
Jake Raby wrote:
Brian wrote:
nobuggybob
PostPosted: Sat Jul 05, 2014 5:52 am    Post subject: Reply with quote
Gasola Is all you need Cool
Vee Dub Nut
Vee Dub Nut is offline
PostPosted: Sat Jul 05, 2014 6:14 am    Post subject: Reply with quote
Gasola does work well.
Fightin' Texas Aggie Class of 2006
67 Beetle (TBD)
74 Transporter (EJ25 Swapped) - Build Thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0
See all my VW pics on Instagram @ vee_dub_nut
x-file
x-file is offline
PostPosted: Mon Jul 07, 2014 4:26 am    Post subject: Reply with quote
Loctite 567 teflon thread sealant.
Instant results,and no problems.
raygreenwood
raygreenwood is offline
PostPosted: Mon Jul 07, 2014 7:47 am    Post subject: Reply with quote
Indian head works excellent for this. No issues with gasoline. Ray
fredn
fredn is offline
PostPosted: Tue Jul 08, 2014 9:38 am    Post subject: Reply with quote
This stuff is the best. It's on TV so it must be awesome. I use it on the old cracked rubber fuel lines over my exhaust.
1982 Air Cooled Vanagon Carat Weekender Interior
tencentlife wrote:
...most are doing what most auto forum participants do, parroting things they've heard
View user's profile Send private message Twitter Classifieds Feedback
jpaull
jpaull is offline
PostPosted: Tue Jul 08, 2014 4:06 pm    Post subject: Sealant Reply with quote
Permatex Aviation I have used on Fuel lines and fittings for years. You know its good cause its horrible to remove from your hands. Its rated resistant to fuel and time has shown its true.
http://www.permatex.com/products-2/product-categor...uid-detail
Jeff
