Interior light help?
WalshingMachine
WalshingMachine is offline
PostPosted: Sat Jul 26, 2014 3:53 pm    Post subject: Interior light help? Reply with quote
New to theSamba and have a problem: the interior sconce lights in my 67 campmobile have conked out. Bulbs are fine, wiring connects all the way back to the regulator in the engine compartment, but no juice! Any ideas before I put the seats and panelling back in?
olliehank47
olliehank47 is offline
PostPosted: Sat Jul 26, 2014 5:17 pm    Post subject: Re: Interior light help? Reply with quote
I always assumed the rear sconce lights were wired to the switch on the left side of the speedo pod--the one that controls the rear cargo area light in all other buses. Have you tried flipping the switch on the side of the pod? I don't have a westy so it's just an assumption.
Daddybus
Daddybus is offline
PostPosted: Sat Jul 26, 2014 5:21 pm    Post subject: Reply with quote
Test connection at regulator to see if it is hot (12v).
joe cool
joe cool is offline
PostPosted: Sat Jul 26, 2014 5:48 pm    Post subject: Re: Interior light help? Reply with quote
x2. i would want those on a fuse from the fuse box. i don't believe they were not done that way originally.
BarryL Premium Member
BarryL is offline
PostPosted: Sat Jul 26, 2014 7:06 pm    Post subject: Reply with quote
If it's the original Westy harness then there is a bakelite fuse holder on the wire exactly like the back-up light fuse holder. But if it did pop the fuse, why?
Clara Premium Member
Clara is offline
PostPosted: Sat Jul 26, 2014 8:21 pm    Post subject: Re: Interior light help? Reply with quote
They are independent of the regular dome lights.
They were wired like this, off the VR, with an inline fuse:
Check the wiring in the engine compartment.
Das67bus
Das67bus is offline
PostPosted: Sat Jul 26, 2014 8:49 pm    Post subject: Reply with quote
Do you have a good ground to complete the circuit?
SLOW RIDE........TAKE IT EASY!!!
-Foghat
COMFORTABLY NUMB!!
-Pink Floyd
