dcheek Samba Member
Posted: Mon Apr 06, 2015 1:25 pm Post subject: Diesel Injection Pump Losing Prime |
I have an '82 Diesel Rabbit pickup. If I park on a hill, where the nose is higher than the back, the pump loses prime overnight - it drains back into the tank. The only thing I can figure is there is a leak somewhere that lets in air to siphon the fuel backwards. I changed all the hoses and the copper gaskets on the banjo fittings and there is no visible fuel leaking when running. What else could it be?
Dave _________________ 1961 Bug
1965 Bug
1966 Sunroof Bug
1966 Westy
1976 914 2.0
1989 911 Carrera
1982 Diesel Rabbit Pick Up
1982 Diesel Vanagon
2014 Golf (last year German mfr for NA)
2023 Jetta Gli, Autobahn Black Edition 6 speed |
73sports Samba Member
Joined: September 26, 2004 Posts: 2107 Location: Warrington, PA
Posted: Mon Apr 06, 2015 7:51 pm Post subject: |
Fuel filter? Did you change the small return line between the injectors too? _________________ I will never lie, but sometimes the truth changes.
Central Jersey VW Society |
dcheek Samba Member
Posted: Tue Apr 07, 2015 4:49 am Post subject: |
73sports wrote: |
Fuel filter? Did you change the small return line between the injectors too? |
Yes, I changed the small lines too. The filter is almost new. Upon further investigation, I think I found the leak. It's the banjo fitting on top of the injection pump. I replaced the copper seals top and bottom and it still leaks. Do the fittings go bad, and more importantly, can you get a new fitting from Bosch. Or, can I us a different type of seal or apply a sealant to it?
1965 Bug
1966 Sunroof Bug
1966 Westy
1976 914 2.0
1989 911 Carrera
1982 Diesel Vanagon
