Has anyone considered doing a Saab B234 conversion?
Page: 1, 2, 3  Next
acegallagher
acegallagher is offline
PostPosted: Mon May 04, 2015 9:16 am    Post subject: Has anyone considered doing a Saab B234 conversion? Reply with quote
Hi there. Question just as it sounds. I've done a bunch of googling but have found no information. The B234 is a rock solid engine that's highly tunable, makes tons of torque, and lasts basically forever. Does anyone have any info or ideas about such a conversion? I'm soooooo curious.
CHARLIE-DONT-SURF
CHARLIE-DONT-SURF is offline
PostPosted: Mon May 04, 2015 9:28 am    Post subject: Reply with quote
In the middle of doing a Volvo B230 , 140ft/lb torque on single carb Very Happy
https://www.facebook.com/Cow-County-Looms-1010851485971680/
sasquatch88
sasquatch88 is offline
PostPosted: Mon May 04, 2015 9:30 am    Post subject: Reply with quote
Arrow
Zeitgeist 13
Zeitgeist 13 is offline
PostPosted: Mon May 04, 2015 10:14 am    Post subject: Reply with quote
I miss the gobs of fun it was to do waterpump replacements on the Saab 900 engines. I took my driving test in a '74 Saab 99 with balky D-jet injection.
The torque curve should be your guide to matching an engine to the T3. Personally, I want torque to build early and maintain up to 3k to 4k. Any engine that throws its torque hotdog down the hallway up beyond 3500k is useless to me
Casey--
'01 Weekender --> full camper
y u rune klassik?
acegallagher
PostPosted: Mon May 04, 2015 10:20 am    Post subject: Reply with quote
Depending on how you tune it the 9000/B234 engine peaks torque between 2800 and 3500 RPMs. Occasionally as late as 4000, though not usually. This guy got a fairly flat torque curve after 2800 using custom tuning and a nice exhaust. In fact, having driven and tuned several 9000s the torque curve is the reason I want to put a B234 in my Vanagon. So much low end torque.
http://www.saabcentral.com/forums/showthread.php?t=234240
MarkWard
MarkWard is offline
PostPosted: Mon May 04, 2015 10:55 am    Post subject: Reply with quote
I believe you would be on uncharted waters. Assuming you can weld and fabricate any thing is possible. Looking forward to your progress.
Zeitgeist 13
PostPosted: Mon May 04, 2015 11:04 am    Post subject: Reply with quote
I assume there are no off the shelf bellhousing adapters or flywheel spacers available, so those two are probably the biggest challenges to overcome
Casey--
y u rune klassik?
morymob
morymob is offline
PostPosted: Tue May 05, 2015 4:27 am    Post subject: Reply with quote
Check with Kennedy engineering, seems they make adaptors 4 about anything, last i checked you can get their listing which gives pros/cons of each eng.
Jake de Villiers
Jake de Villiers is offline
PostPosted: Tue May 05, 2015 8:26 am    Post subject: Reply with quote
Kennedy doesn't show a Saab engine on their list. Volvo, yes, but not Saab.
Some very interesting comments regarding vibration levels, too.
http://www.kennedyenginc.com/Pages/EngineOptionList4cyl.aspx
'84 Vanagon GL 1.9 WBX
@jakedevilliersmusic1
www.crescentbeachguitar.com
www.thebassspa.com
whafalia
whafalia is offline
PostPosted: Tue May 05, 2015 8:32 am    Post subject: Reply with quote
Is that the one where the water pump leaks into the crankcase and can only be removed with a rare puller that uses a left hand thread? Loved that feature, still miss my 900s though
84 westie 2.2 w/ digijet, AT
williamM
williamM is offline
PostPosted: Tue May 05, 2015 8:44 am    Post subject: Reply with quote
took 3 years to get laurains 900 running and not setting it on fire with the red sleeve on the fuel pump GROUND wire.
some days I get up and just sit and think. Some days I just sit.
opinion untempered by fact is ignorance.
Don't step in any!
Zeitgeist 13
PostPosted: Tue May 05, 2015 8:46 am    Post subject: Reply with quote
That's the one I referenced earlier. I seem to recall the block was some kind of English design or something. I've always liked Saabs, including my mom's two stroke smoker from the sixties
Casey--
y u rune klassik?
Chuey
Chuey is offline
PostPosted: Tue May 05, 2015 9:39 am    Post subject: Reply with quote
I'm gonna go out and jump into my 1988 Saab SPG and drive it to work. It rides rough but it's kind of fun. I've had a few Saab 900s and we now also have a 9000. They have been very good cars for us.
My Doka has a stock engine and it's fine with me. But then, I've never driven a 1.8t cornveresion! Smile
Chuey
acegallagher
PostPosted: Tue May 05, 2015 9:45 am    Post subject: Reply with quote
The 900 engine would be a stupid conversion and that's the one where the water pump causes all sorts of issues. The 9000 engine however is rock solid, way more solid than a 1.8t in my opinion for a whole host of reasons. Also, more displacement, more turbo, and the resulting more torque. What's not to love?
MarkWard
MarkWard is offline
PostPosted: Tue May 05, 2015 11:01 am    Post subject: Reply with quote
The van doesn't care what engine is back there. The trick is to do a conversion that when done is both safe and reliable. A chain is only as strong as the weakest link. Powering up often exposes the next weak link.
This needs to be solved first.
I am using Saab hydraulic engine mounts to support my TDI.
WLD*WSTY
WLD*WSTY is offline
PostPosted: Wed May 06, 2015 10:33 am    Post subject: Reply with quote
The easiest Saab engine for a conversion would be the 9-2X. Wink
'82 SyncroWesty, the first ever conversion.'06 Subaru 2.5L
Jake de Villiers
PostPosted: Wed May 06, 2015 9:03 pm    Post subject: Reply with quote
Isn't that just a re-badged Subaru? Smile
www.thebassspa.com
DAV!D
DAV!D is offline
PostPosted: Wed May 06, 2015 9:50 pm    Post subject: Reply with quote
I say go for it. I like seeing what other people come up with which is not the norm. I've have a little over 5k miles on my 2.4 Ecotec now and it's great. (another rock solid engine with 170ish ftlbs of torque & 180hp stock)
I think if I do another major build, it will be taking a subie AWD system and finding a engine which spins the right direction to make it go vroom vroom in the forward direction inside a vanagon with awd.. Laughing
Then again, I kind would like to see what a 4bt Cummings would be like in a late 80s early 90s chevy shorty van with 4x4.. Embarassed
86 Syncro Build - Ecotec Motor Swap - Pop Top Conversion - Camper Build & Syncro Conversion
rustymini
rustymini is offline
PostPosted: Wed May 06, 2015 11:35 pm    Post subject: Reply with quote
Not to bash the idea of a Saab motor in a Vanagon, but after you work thru the engine trans adapter-flywheel deal, you will need to fab up an oilpan, as the Saab motor uses the transaxle as an oil pan.
The water pump is against the firewall on this motor, no real problem if it ever makes it's way into a Vanagon.
The late 70s "B" motor, used in the Saab 99 is the one with a water pump under the intake runners, under the brittle fuel lines, driven by a gear on the cam. As someone else said, need a special puller to change water pump.
View user's profile Send private message AIM Address Yahoo Messenger Classifieds Feedback
WLD*WSTY
WLD*WSTY is offline
PostPosted: Thu May 07, 2015 7:59 pm    Post subject: Reply with quote
That's what makes it so easy! Now the Aero is a bit tougher... Laughing
Page: 1, 2, 3  Next
