Dr OnHolliday Samba Member
Joined: May 11, 2012 Posts: 1215 Location: was Escondido now San Berdoo
Posted: Tue Jun 16, 2015 12:13 pm Post subject: Tie rod end taper angles |
I'm trying to determine specs on tie rod ends.
What I think I know:
Pre-'68 VW Type 1 tie rod studs are 10 mm diameter with a 17 mm nut;
March '68-on VW Type 1 tie rod studs are 12 mm diameter with a 19 mm nut
BUT do these each have the so-called 7 degree taper (actually 1.5" taper per foot)?
It appears that the 1.5" per foot may be an industry-wide standard for tie rod tapers?
Thanx
PS I'm pretty sure I have the older 10 mm ends on my car as my tie rods each have one end that is non-adjustable / intregal with tie-rods _________________ 1965 Type 1 sunroof Baja / about 70k miles on self-rebuilt '74 1600 and counting / SP heads and aftermarket valve keepers / non-doghouse shroud with external cooler and filter / 1.5 qt extended sump / Weber 32/36 DFAV progressive carb / 009 dist with Pertronix / 1.25 ratio rockers and ball adjusters / 1.5" stainless steel J-pipes and carbon steel baja exhaust |
Posted: Wed Jun 17, 2015 10:51 am Post subject: |
Nobody knows about taper angles?
jsturtlebuggy Samba Member
Joined: August 24, 2005 Posts: 4608 Location: Fair Oaks/Orangevale, CA
Posted: Wed Jun 17, 2015 4:00 pm Post subject: |
It is what I use, the 7degree 1 1/2 per foot taper reamer when I need to ream for larger tie rod ends. _________________ Joseph
Elrod Motorsports
Motion Tire Motorsports
Into Volkswagens since 1960 |
Posted: Wed Jun 17, 2015 9:48 pm Post subject: |
Thank you. Yes the Ford and I-H ends are 7.5* for sure, but I think I want to upgrade my ends to the post-68 VW size so that's why my inquiry. _________________ 1965 Type 1 sunroof Baja / about 70k miles on self-rebuilt '74 1600 and counting / SP heads and aftermarket valve keepers / non-doghouse shroud with external cooler and filter / 1.5 qt extended sump / Weber 32/36 DFAV progressive carb / 009 dist with Pertronix / 1.25 ratio rockers and ball adjusters / 1.5" stainless steel J-pipes and carbon steel baja exhaust |
Sandbar Norm Samba Member
Joined: August 02, 2008 Posts: 115 Location: A Sandbar in Fl.
Nectar1 Samba Member
Posted: Fri Jun 19, 2015 3:29 pm Post subject: |
What are you looking to accomplish here?
Both sizes of tie rod ends are readily available.
If you're looking to change tie rod ends and ream the steering arm for strength per se you may be better off upgrading the spindle to the '69-ON spindle with the larger stub and forego the reaming. |
Posted: Mon Jun 22, 2015 3:07 pm Post subject: |
What do I want to accomplish?
I need new tie rods and ends, my tie rods are old-style 1-piece with ends.
I always consider what economical upgrades are available when i start a project.
Because 7* ream costs at least $90, my cheapest option right now is new or used tie rods (probably reinforced) with pre-68 ends....no reaming. But it allows future upsizing to post-68 tie rod ends.
I'm trying to determine that all vw type 1 have same 7* taper angle. I will eventually buy a 7* reamer because I have american projects that I will install the Ford ends on... _________________ 1965 Type 1 sunroof Baja / about 70k miles on self-rebuilt '74 1600 and counting / SP heads and aftermarket valve keepers / non-doghouse shroud with external cooler and filter / 1.5 qt extended sump / Weber 32/36 DFAV progressive carb / 009 dist with Pertronix / 1.25 ratio rockers and ball adjusters / 1.5" stainless steel J-pipes and carbon steel baja exhaust
Last edited by Dr OnHolliday on Wed Jun 24, 2015 12:03 pm; edited 1 time in total |
Posted: Wed Jun 24, 2015 12:00 pm Post subject: |
Btw - the book "Bajas and Buggies" doesnt list any concerns about installing upsized tie rod ends - is it wrong or out of date? _________________ 1965 Type 1 sunroof Baja / about 70k miles on self-rebuilt '74 1600 and counting / SP heads and aftermarket valve keepers / non-doghouse shroud with external cooler and filter / 1.5 qt extended sump / Weber 32/36 DFAV progressive carb / 009 dist with Pertronix / 1.25 ratio rockers and ball adjusters / 1.5" stainless steel J-pipes and carbon steel baja exhaust |
dustymojave Samba Member
Joined: January 07, 2007 Posts: 5820 Location: Lake LA, Mojave Desert, SoCal
Posted: Thu Jun 25, 2015 4:47 pm Post subject: |
Yes, the angle is the same for all of them. Stock early ends are stronger than stock rods. Beef the rods, then the ends are weaker. But still fairly strong.
When you ream the steering arms and pitman arm out for bigger rod ends, you make the wall of the arm around the hole thinner and theoretically weaker. I prefer steering arm gussets which wrap around the end of the arm to reinforce that. This is the pitman arm on my 58 Baja with a 1/4" thick gusset TIG welded around the outside. It could be MIG welded too.
But you could get away with reaming the arms to fit Ford or International ends without a problem. The arms you're reaming and the tie rod ends and the tie rods are all the same as what Jeff was dealing with when he wrote Baja Bugs & Buggies over 30 years ago. Both the Ford and International ends date back to the 1940s. Replacement parts are pretty much the same as then and the Fords are readily available. Nothing has changed that would cause new concerns. _________________ Richard
SoCalBajas Member
Posted: Fri Jun 26, 2015 12:17 am Post subject: |
Thank you! _________________ 1965 Type 1 sunroof Baja / about 70k miles on self-rebuilt '74 1600 and counting / SP heads and aftermarket valve keepers / non-doghouse shroud with external cooler and filter / 1.5 qt extended sump / Weber 32/36 DFAV progressive carb / 009 dist with Pertronix / 1.25 ratio rockers and ball adjusters / 1.5" stainless steel J-pipes and carbon steel baja exhaust |
wildgoose Samba Member
Posted: Wed Dec 07, 2016 8:53 pm Post subject: Re: Tie rod end taper angles |
Does anyone really know the angle of post 68 tie rod end? they are not close to the 7 degree common taper reamer .
I see many postings that people are using the 7degree taper when reaming the spindles for the larger tie rod end---- BUT it is NOT the correct angle the correct angle is almost 6 degrees, most folks do not seem to know or care .
Can anyone help with a source for the CORRECT reamer??
Thanks
dick |
jeremyrockjock Samba Towbar Builder
Joined: January 01, 2002 Posts: 5008 Location: Richmond, Verjinya
Posted: Sun Feb 11, 2018 7:59 pm Post subject: Re: Tie rod end taper angles |
I used a 5 degree on my 67 bus spindles and it fit perfect _________________ Why buy what you can build.
Step away from the fiberglass and no one gets hurt!! |
Vanillagurilla Samba Member
Joined: November 21, 2017 Posts: 1061 Location: California
Posted: Sun Feb 11, 2018 8:03 pm Post subject: Re: Tie rod end taper angles |
Heim joint and don't worry about it? |
