Looking for Pinch Bolts for Link Pin front end
rrcade
rrcade is offline
PostPosted: Wed Aug 19, 2015 6:51 pm    Post subject: Looking for Pinch Bolts for Link Pin front end Reply with quote
I can't find them at any hardware store Supposedly they are Hardened but my stock ones that are chewed up have an 8 on them.
Where can I find the CORRECT replacement M10x1.5x45 bolts?
61SNRF
61SNRF is offline
PostPosted: Wed Aug 19, 2015 7:34 pm    Post subject: Reply with quote
Metric grade 8 is roughly equivalent to common SAE grade 5, hardened would be 10.9 or better...
https://sizes.com/tools/bolts_metric_standards.htm
You should be able to match them at a well stocked hardware store or a nut/bolt specialist...
https://www.boltdepot.com/Product-Details.aspx?product=6242
If you're looking for exact replacements as far as thread vs shoulder length with 17mm hex head with OEM maker's marks on their heads, you're probably best off searching out some good used ones from the classifieds.
-Bruce
An ounce of prevention is worth a pound of cure.
rrcade
rrcade is offline
PostPosted: Sat Aug 22, 2015 11:31 pm    Post subject: Reply with quote
Found this online:8G/8.8 is equivalent to a US grade 5 bolt,
and 10K/10.9 is equivalent to a US grade 8 bolt. 8.8/8G are the
"standard" metric bolts you can get at the hardware store
So my original(I assume)pinch bolts are marked 8G, so does that mean these bolts aren't actually hardened? What should I use 8.8 or 10.9?
MMW
MMW is offline
PostPosted: Sun Aug 23, 2015 6:29 am    Post subject: Reply with quote
Grade 5 or 8.8 are hardened to a certain degree. They have less strength than a grade 8 or 10.9 but have more than a grade 2 or 5.8. In my opinion metric 8.8 will be fine for your application.
US Grade 2 = approx metric property class 5.8
US Grade 5 = approx metric property class 8.8
US Grade 8= approx metric property class 10.9
Mic
1959 356 coupe
Missing the original engine 72488
Update - third pc. found!
Now just need the case halves.
1965 fenderless beetle
61SNRF
61SNRF is offline
PostPosted: Sun Aug 23, 2015 2:07 pm    Post subject: Reply with quote
Never assume when it comes to safety. Look in your Bentley manual for front end bolt specs if you are not sure. VW only marked the bolts with their quality grade which is 8G, but their tensile class is actually 8.8.
Not going to do any harm by using 10.9K, but you may be spending more money for extra strength you don't need.
-Bruce
rockerarm
rockerarm is offline
PostPosted: Tue Sep 01, 2015 2:22 pm    Post subject: Re: Looking for Pinch Bolts for Link Pin front end Reply with quote
Hi. Did you find the hardware you wanted? I'm here in Los Angeles. At a local hardware store here they have something you may be interested in.
Bolt- 10mm x 50mm, 1.50 pitch, 10.9 hardness, the shank is 21mm long, 17mm hex head, $1.10 each.
Nut- 17mm hex, .45 each.
Flat washers- .40 each.
Lock washers- .25 each
Country of origin can be anywhere as containers state many countries.
USPS has a small flat rate box. Ships anywhere for about $15.
Pay me $5 for my time.
Hope this helps, Bill.
rrcade
rrcade is offline
PostPosted: Tue Sep 01, 2015 6:44 pm    Post subject: Reply with quote
Thanks, I found them at Fastenal 10.9 with correct shank and head
