Mallory Distributor Vacuum Advance Canister Adjustment
Scott Novak
Scott Novak is offline
PostPosted: Fri Aug 21, 2015 8:29 pm    Post subject: Mallory Distributor Vacuum Advance Canister Adjustment Reply with quote
[email protected] wrote:
The adjustment screw on the Mallory can is a LIMIT SCREW. It does nothing for when it starts advancing, only where it stops.
Actually that is only partially true. The adjuster is actually intended to be a diaphragm spring preload adjuster. It adjusts the sensitivity of the vacuum caninster.
To make adjustments to vacuum advance sensitivity, you remove the vacuum hose from the nipple on the vacuum canister. You insert a 3/32" Allen wrench through the nipple on the vacuum canister and turn the adjuster.
You turn the adjuster counter clockwise to increase the spring preload which decreases the sensitivity and requires a higher amount of vacuum to actuate the diaphragm. It does have the side effect of limiting the maximum amount of vacuum when the spring is fully compressed.
You turn the adjuster clockwise to reduce the spring preload which increases the sensitivity and requires a lower amount of vacuum to actuate the diaphragm. With the preload spring less compressed it allows more vacuum advance.
The engine will only create a certain amount of vacuum. At that point of maximum vacuum you can turn the adjuster to give you the maximum amount of vacuum advance that is desired. (Assuming the vacuum signal from the carburetor is large enough.)
Scott Novak
74 Thing
74 Thing is offline
PostPosted: Fri Aug 21, 2015 9:17 pm    Post subject: Reply with quote
Does the can provide a certain amount of advance (ie from 8 degrees up to 15 depending on how the screw is set)?
Scott Novak
PostPosted: Fri Aug 21, 2015 10:22 pm    Post subject: Reply with quote
I don't remember how many degrees of advance the vacuum canister will provide. I think it may be 12°.
It takes a certain minimum amount of vacuum before the diaphragm will begin moving. Turing the adjuster counter clockwise will increase the minimum amount of vacuum required before the diaphragm begins to move.
When your engine is producing the maximum amount of vacuum from the vacuum port on the carb, you adjust the canister for the maximum amount of vacuum advance that you desire.
Scott Novak
j-dub
j-dub is offline
PostPosted: Mon Aug 24, 2015 8:31 pm    Post subject: Reply with quote
Scott,
Did you test the vacuum can with a vacuum pump? Do you know how low of vac pressure will start the can moving assuming the preload on the spring is not maxed out? More specifically can you make it start at 2-3 inches of vacuum?
Thanks,
Jeremy
1957 Oval rag
"POLICE STATION TOILET STOLEN ... Cops have nothing to go on."
Scott Novak
PostPosted: Mon Aug 24, 2015 9:24 pm    Post subject: Reply with quote
I have taken the vacuum canister apart to see how it was constructed.
I am about to measure the actual vacuum versus degrees of advance. I need to pick up more vacuum hose and a few T fittings.
But I did in fact confirm that with the adjuster turned fully clockwise it takes less vacuum to actuate than when the adjuster is turned counter clockwise.
I also need to confirm whether my Weber 40 IDF provides enough vacuum to advance the distributor sufficiently.
HOWEVER, be aware that Mallory supposedly makes two versions of the vacuum canister and that one of them requires less vacuum to actuate.
Also, the vacuum canister on the Mallory Comp 9000 distributor that I am using connects to a pin staked to one of the outer holes on the rotating baseplate. So my results aren't going to be quite the same as the Mallory SVDAs most people are using where the vacuum canister is connected to a post staked to one of the inner holes of the rotating baseplate.
Imageshack lost a bunch of my photos including one showing the baseplate and the vacuum canister connection. I'll have to take some new photos. So far I've had NO response back from Imageshack about my photos, even though they claim to have them backed up 3 different ways.
Scott Novak
j-dub
j-dub is offline
PostPosted: Mon Aug 24, 2015 10:05 pm    Post subject: Reply with quote
Thanks Scott, Looking forward to your results.
For what is is worth my engine makes about 9" of vacuum so I lowered the vacuum spring pressure on my VJU4BR8 so it starts at about 2.5" vacuum and at 9" I have an additional 13 degrees advance.
I just googled Mallory Comp 9000, I see what you are talking about now and how different this is than the unilite. Interesting build. I have heard mixed reviews of the minimum amount of vacuum you need to get a unilite to start advancing, possibly people did not know they were adjustable or they adjust differently than yours.
1957 Oval rag
Scott Novak
PostPosted: Tue Aug 25, 2015 9:17 am    Post subject: Reply with quote
The Comp 9000 uses the same lower shaft and spring advance system as the Unilite. They don't make Comp 9000 distributors for for 4-cylinder engines so I had to do some part swapping and grind the extra 4 teeth off of the reluctor to make it work on my engine.
The rotating baseplate is basically the same as the Unilite except for some screw holes in different locations. Because the Comp 9000 distributor has a larger diameter bowl, they had to move post for the vacuum canister linkage to a hole on the outside of the rotating plate. You will see these extra holes in the Unilite baseplate. The baseplates are made for left or right hand rotation and small bowl or large bowl distributors. They just stake the post for the vacuum canister in the appropriate holes as needed.
9" of vacuum should be more than enough to actuate a Mallory vacuum canister. You just turn the adjuster counterclockwise to reduce the sensitivity to the correct level. But there is a point where turning the adjuster counter clockwise will compress the spring enough that it will begin to limit the maximum amount of advance.
If anyone talks about the minimum vacuum needed to actuate the vacuum canister, unless they specify that the adjuster is turned fully clockwise they don't know what they are talking about. Also, there are supposed to be two different versions of the vacuum canister with different sensitivities.
Scott Novak
Scott Novak
PostPosted: Fri Sep 04, 2015 10:08 pm    Post subject: Reply with quote
I measured the sensitivity of my Mallory Comp 9000 Vacuum advance canister tonight. Unfortunately the results are not as accurate as I would have liked. I discovered that my vacuum gauge has a sticky needle. I tapped the meter as I was taking measurements to reduce the errors as much as I could.
With the adjuster inside the vacuum canister fully clockwise, with somewhere between 4.5" Hg and 5.0" Hg to the vacuum advance diaphragm, the baseplate began to rotate and begin advancing the spark timing.
5" Hg = 0 Crank Degrees Vacuum Advance
6" Hg = 8.4 Crank Degrees Vacuum Advance
7" Hg = 11.2 Crank Degrees Vacuum Advance
8" Hg = 16.3 Crank Degrees Vacuum Advance
9" Hg = 17.3 Crank Degrees Vacuum Advance
10" Hg = 19.1 Crank Degrees Vacuum Advance
11" Hg = 20.6 Crank Degrees Vacuum Advance
12" Hg = 23.1 Crank Degrees Vacuum Advance
I don't think that my Weber 40 IDF's have anywhere near the amount of ported vacuum needed for the vacuum advance canisters. The Mallory vacuum advance canister really needs changeable preload springs inside and also a physical stop for maximum advance.
Scott Novak
Scott Novak
PostPosted: Sun Sep 06, 2015 12:13 am    Post subject: Reply with quote
I'm probably going to have to break down and buy one of these Anti-Pulse valves:
http://vwparts.aircooled.net/Anti-Pulse-Valve-for-Vacuum-Advance-Distributors-p/anti-pulse-valve.htm
I think it's just a quick acting check valve with an air bleed across it. I actually tried making one of these today. It did help a little, but the check valve isn't sensitive enough.
I'm also going to open up another Mallory vacuum advance canister. I'll take some photos this time. I want to be able to replace the spring with a lighter one to make the advance more sensitive. There is a limit on how light a spring I can use. If the spring is too light it wont overcome the friction of the rotating baseplate.
It's also possible that I need to find a vacuum advance canister that is physically larger in diameter.
Scott Novak
j-dub
j-dub is offline
PostPosted: Sun Sep 06, 2015 8:28 am    Post subject: Reply with quote
Did you measure how much vacuum your engine makes yet? I am guessing it makes somewhere between 8 and 10 inches and if that equates to 16 to 19 degrees advance you will already have to start limiting that down. Are you hoping it starts advancing sooner with the softer spring so your vacuum advance curve is softer, not so much like a step function?
1957 Oval rag
Scott Novak
PostPosted: Sun Sep 06, 2015 10:26 am    Post subject: Reply with quote
34 PICT puts out. about 8" Hg to the vacuum port. Unfortunately the 40 IDF takes it's vacuum from only one cylinder and provides about 2" Hg of vacuum, which is about 1/4 of 8" Hg which is close to what you might expect.
A weaker spring would allow the advance to start sooner. I'm not sure how I'll do it yet. I'll have to figure out something once I have the vacuum can opened up.
Scott Novak
udidwht
udidwht is offline
PostPosted: Mon Sep 07, 2015 7:11 pm    Post subject: Reply with quote
Pull from each IDF to a T. Also use the APV between the T and the distributor. This is how I'm set up and out on the highway I've seen vacuum as high as 6hg at times while cruising on the flats.
The APV will dampen any pulses in the line and help steady it. It's hit or miss with IDF's & vacuum.
1972 Westy Hardtop/Type-4 2056cc
96mm Biral AA P/C's~7.8:1CR
71mm Stroke
73 Web Cam w/Web solids
Bosch W8CC plugs
S&S 4-1 w/Walker QP 17862
3 rib 002 Trans
185R14 Hankook tires
raygreenwood
raygreenwood is offline
PostPosted: Tue Sep 08, 2015 7:08 am    Post subject: Reply with quote
I know it probably does not help you carb guys because your options of where to pull vacuum from are limited with carbs. In fuel injected plenum style systems...the vacuum "quality" or stability varies widely from where you pull it in the center manifold...even if the inches of mercury may not vary.
You can duplicate this effect with a small chamber pulling from both manifolds. Not as a balance pipe ...but the same effect. It feeds advance only. Ray
webebuggin
webebuggin is offline
PostPosted: Wed Sep 09, 2015 1:57 pm    Post subject: Reply with quote
The Mallory can is WAY to stiff,even with a mild cam, I used a can from a big cap cast iron distributor,in conjuction with the anti-pulse, t'd to both weber 44's, it pulls to 42 degrees, piks are in the gallery, The can was from a Bosch ZV/PAU 4r5 distributor, I added a return spring,and it works great,
Tuna Tim
Tuna Tim is offline
PostPosted: Thu Jun 27, 2019 6:02 pm    Post subject: Reply with quote
Scott Novak
Scott, did you get that Unilite vacuum can mod (lighter spring) to work? If so, what kind of results did you get?
1974 Bay
CSII
091
Dual 40 Dells
Unilite
Thunderbird Extractor
