earthquake Samba Member
Joined: January 10, 2008 Posts: 4001 Location: SANDY VALLEY, NEVADA
Posted: Sat Sep 26, 2015 5:55 pm Post subject: Will this combo of parts work? |
I need to put together a motor pretty quick to move a car in a month, I want to use parts I have on the shelf, ok this is what I have...
Dual relief case [type 3]
Revmaster 049 heads [not ported]
AA 94A P&C's
Engle 110 cam [new]
DPR 69mm counterweighted crank
CB Perf 5.4" Uni Tech HD rods
Used steel push rods
stock rockers on solids shafts
40mm Weber IDF's [I have a set of 44's if the 40's are too small]
VW doghouse shroud and all the tin
1 3/8" single QP [I might buy a 1 1/2"]
I need to pick up all the small stuff for the build as I go.
I know the 110 cam is a bit old fashion but I have it on hand, I also have a 30mm oil pump but I might pick up a 26mm instead.
do you guys think it will work and what kinda power do you think it will make? _________________ 74 CLASS 11 LOOK-A-LIKE
69 DUNE BUGGY
79 INTERNATIONAL SCOUT II
05 SCION XB SERIES RELEASE 2[#437]
95 Chevy C3500 dually
98 Ford E150
Link to Kelly J. Nolte 3/20/53 - 11/6/08
https://time-zonelabs.blogspot.com/p/about-kelly.html
DEATH TO CHINGERS!
[From a military recruitment poster in the novel "The Stainless Steel Rat" By Harry Harrison] |
Matthew Samba Member
Joined: January 29, 2004 Posts: 1760 Location: Eastern Tennessee
Posted: Sat Sep 26, 2015 6:35 pm Post subject: |
That's a pretty nice engine just to move a car. What's it going in?
The 26mm oil pump is best and you should have 1 1/2" exhaust with the bigger valves. What size valves are in those heads? _________________ 1965 Beetle sedan
Click to view image |
bugguy1967 Samba Member
Joined: January 16, 2008 Posts: 4368 Location: Los Angeles, CA 90016
Posted: Sat Sep 26, 2015 6:56 pm Post subject: |
Oldest combo ever. It'll work together just fine. It should make 110 HP. Those ports are larger than stock, right? _________________ "A petrol engine can start readily, run smoothly and give every appearance of being in good order, without necessarily being in good tune." - Colin Campbell, "The Sportscar Engine" |
Posted: Sat Sep 26, 2015 8:28 pm Post subject: |
The heads have 40mm intake and 35mm ex.
This motor will be for my 74 class 11 look a like, I had been planing to build a 1914 for awhile but now I have to get it running sooner then I thought I had. I need to find a cheap 1 1/2 exaust system for now. To bad its not a Baja, I have a brand new Tri mil Bobtail on the shelf.
Casey _________________ 74 CLASS 11 LOOK-A-LIKE
69 DUNE BUGGY
98 Ford E150
DEATH TO CHINGERS!
