Can someone school me on EZ30 engines?
Sir Sam
Sir Sam is offline
PostPosted: Mon Oct 12, 2015 5:16 pm    Post subject: Can someone school me on EZ30 engines? Reply with quote
Doing a bit of research trying to decide what I need to look for in a donor car. While its very cheap to get an engine and other donor parts at a junkyard I don't really want to run a 2.2 or 2.5 in my syncro. I wouldn't mind going SVX but its a hard enough to find engine that I would prefer to go with something that is more common these days.
I've been watching auctions recently and donor cars are cheap, and since it saves me the hassle of finding one at a junkyard and trying to pull everything I need I'm looking at going that route.
Research so far shows that the 2000-2002 EZ30 has the single exhaust port per head, and the 03+ the three exhaust ports per head.
Neither small car or RMW offer a 3 port exhaust, is this a deal killer enough to look for an older engine? I don't really want to spend a bunch of time fabricating my own headers or looking for someone else to build an exhaust, the bolt on solutions for the single header seem nice.
Is there a year cutoff for the electronics for running as standalone? IE would a 2009 EZ30 be an engine only donor requiring an older ECU and wiring harness to run?
So far I'm planning on KEP adapter and RMW engine carrier since I have these components already.
'91 Carat Westy
87' Syncro + '87 Westy conversion coming soon
insyncro
Banned
insyncro is offline
PostPosted: Mon Oct 12, 2015 5:33 pm    Post subject: Reply with quote
First off, H6s are not $3000 Subaru conversions.
I do NOT recommend using an adapter plate and 228mm clutch pack with an H6.
An RJES with the 240mm clutch pack and flywheel is.
The triple port exhaust is not a problem, the complete system runs about $3500 when built properly.
Wiring isn't an issue either if you are willing to use aftermarket management.
2000-2004 EZ30d engines have cast intakes, if the engine you are looking at has a plastic intake, it is NOT a 30d.
Small Car has the most parts for the 30d conversion.
Derek Drew has a PRIVATE group to support the 30d in Yahoo Groups.
You have to apply to be included.
This keeps out the banter and BS.
insyncro
Banned
insyncro is offline
PostPosted: Mon Oct 12, 2015 5:40 pm    Post subject: Reply with quote
Derek's Vanapolooza Build Thread :
http://www.thesamba.com/vw/forum/viewtopic.php?t=440872&highlight=infestation
wcdennis
wcdennis is offline
PostPosted: Mon Oct 12, 2015 5:44 pm    Post subject: Reply with quote
Seems like 2006-07 was the transition to can bus, but this opens up more possibilities for engine choices:
http://www.subarugears.com/subatronics/index.html
insyncro
Banned
insyncro is offline
PostPosted: Mon Oct 12, 2015 5:55 pm    Post subject: Reply with quote
All CAN BUS EZ engines have triple port exhausts.
I have the exhaust systems for these.
I am not selling them but can assist in having them made if one wants.
Big dollars Exclamation
Sir Sam
Sir Sam is offline
PostPosted: Mon Oct 12, 2015 7:34 pm    Post subject: Reply with quote
Who sells a complete exhaust for $3500? Do you have a link to a company that I can order it from? For me to pull this swap off I need to be able to order parts off the shelf - not mess around with fabbing my own, which is one reason I have ruled the SVX out.
If I need to fabricate an exhaust and buy a small car engine mount then I might as well find another SVX engine. This has the added benefit of me having lots of spare SVX parts already.
What years do I need to use aftermarket engine management for? I have several ECUs here that are fully customizable and I have all control over the operating software, dual wideband 02s, dual knock sensors, cam+crank synchronization completely customizable, self learning fuel/timing maps. etc, very slick setup.
While I have the knowledge and skillset, I don't want to spend the time to put that together, I would rather rewire a stock ECU for my purposes.
2004? Wikipedia indicates that the plastic intake started in 2003, which also correlates to the 6 port exhaust.
RMW also has a complete exhaust system, two off the shelf solutions for the 2 port exhaust to choose from.
In summary as best I can tell so far:
2000-2002:
2 port exhaust, known ECU compatibility.
2003-2009:
6 port exhaust, plastic intake. Some years require aftermarket engine management(unknown year breakdown).
'91 Carat Westy
Sir Sam
Sir Sam is offline
PostPosted: Mon Oct 12, 2015 7:38 pm    Post subject: Reply with quote
Very interesting product. Saves the DIYer from trying to program up a CAN enabled PIC to do the same job.
'91 Carat Westy
insyncro
Banned
insyncro is offline
PostPosted: Mon Oct 12, 2015 7:46 pm    Post subject: Reply with quote
Call RMW and SC for off the shelf stuff.
I use custom parts designed by Eric Abercrombie, who sold the entire H6 design lot to SC.
They have sold all of Eric's parts SC no longer supports the later engines.
There are many versions of the EZ platform available.
If you are looking at USDM, that will be one set of years that work...JDM, a totally different story.
The wiring needs to be USDM if you want it to work properly with mixed and matched parts.
I have a ton of all this stuff I have collected and pulled from donor vehicles I purchased so I would have matching engines, harnesses, ECUs and the rest.
No interest in ala carte sales at this point.
Complete turnkey, that would work, but it sounds like you want to do it yourself.
The link and yahoo group are advised for DIY research and trouble shooting.
Sir Sam
Sir Sam is offline
PostPosted: Mon Oct 12, 2015 9:37 pm    Post subject: Reply with quote
Ok so I guess that means the later 6 port EZ is out.
Dylan can you confirm the Model year the 6 port exhaust models started?
If I did choose to have a custom exhaust made up what year does CANBUS kick in and make the ECU harder to deal with? 2007? Or was it earlier? 2007 is a watershed year for canbus across the board much like 1996 was for obdii, but like with obdii some vehicles got it a little earlier than others. With 2005 being the first year for the new body of outback I can see how it much have gotten the canbus setup a little sooner.
'91 Carat Westy
Sir Sam
Sir Sam is offline
PostPosted: Sun Mar 11, 2018 7:58 am    Post subject: Re: Can someone school me on EZ30 engines? Reply with quote
Update: pulled a 2003 EZ30 at a junkyard, got ECU and wiring but couldn't find the fuel pump controller.
So the Question:
Is the fuel pump controller needed? From looking at the wiring diagrams it seems like as soon as key is on the fuel pump controller gets power and does it thing.
Is the fuel pump controller needed or will a relay for powering the vanagon fuel pump be fine?
If its needed where the heck is the fuel pump controller located in a 2003 outback? Small car website says right rear of vehicle but I couldn't for the life of me find it. Other internet searches haven't helped me figure it out, lots of talk about it but I haven't figured where it is.
'91 Carat Westy
Sir Sam
Sir Sam is offline
PostPosted: Sun Mar 11, 2018 8:00 am    Post subject: Re: Can someone school me on EZ30 engines? Reply with quote
Also. I see mention of security system in there, but it doesn't seem tied to the ECU, if the wiring just bypass's the security module will all of it be ok or is there anything else the ECU needs to read from the security system?
'91 Carat Westy
brokengun
brokengun is offline
PostPosted: Sun Mar 11, 2018 8:33 am    Post subject: Re: Can someone school me on EZ30 engines? Reply with quote
I don't have the answers to your questions unfortunately Sam, but I did want to recommend the Subaru Six Cylinder VW van group on Facebook. It's pretty active and often has recommendations for where to get the odd parts/pieces to put together one of these projects.
Seems to me like the EZ30 of that vintage is the way to go as far as parts availability and converting the wiring harness over (pre-CANBUS).
1984 Vanagon Adventurewagen with EJ22 conversion
1975 Beetle - Big whole in the floorboards
1974 Westy - Will be on the road one day!
1973 Bus - sold
Sir Sam
Sir Sam is offline
PostPosted: Sun Mar 11, 2018 10:36 am    Post subject: Re: Can someone school me on EZ30 engines? Reply with quote
Got a link?
I found this group, but it didn't seem H6 specific:
https://www.facebook.com/groups/864424797008986/
I started stripping down my donor harness, I need to work on redlining the factory drawings or make new drawings for this engine.
Might just make new as I hate the subaru(and nissan) methodology for drawings.
'91 Carat Westy
brokengun
PostPosted: Sun Mar 11, 2018 5:51 pm    Post subject: Re: Can someone school me on EZ30 engines? Reply with quote
https://www.facebook.com/groups/SubieSixVwVAN/
That should work for you (I hope)!
1973 Bus - sold
