67' Bus Front Seat Frame Removal
Hawaiianguy808
Hawaiianguy808 is offline
PostPosted: Wed Jan 13, 2016 7:18 pm    Post subject: 67' Bus Front Seat Frame Removal Reply with quote
Hello my fellow bus owners. I need some help! I'm having a hard time removing the drivers seat frame. My bus does not have any padding on the seat frames so I just have the frame, springs, etc. How do you remove it? Any suggestions?
busdaddy
busdaddy is online now
PostPosted: Wed Jan 13, 2016 7:36 pm    Post subject: Re: 67' Bus Front Seat Frame Removal Reply with quote
Remove the frame from what?, the bus?
Слава Україні!
Hawaiianguy808
PostPosted: Wed Jan 13, 2016 9:23 pm    Post subject: Re: 67' Bus Front Seat Frame Removal Reply with quote
Sorry busdaddy! Remove the seat frame from the seat rails. I have a walk through bus and on the drivers side I can't get it off to the seat rails. I want to re-upholster it, but I'm having a hard time removing it. It seems as though it slides out of the seat rails, but I'm not too sure.
joe56vw
joe56vw is offline
PostPosted: Wed Jan 13, 2016 9:28 pm    Post subject: Re: 67' Bus Front Seat Frame Removal Reply with quote
there should be a knob in front of the seat pull up on it to release the seat then push it forward
sometimes they are very sticky so if it doesn't move spray some WD-40 or PB blaster on it and the rails
'60 15 window walkthrough
why is there no sarcasism button on here?
PostPosted: Wed Jan 13, 2016 10:54 pm    Post subject: Re: 67' Bus Front Seat Frame Removal Reply with quote
Check out this thread for more comments and photos
http://www.thesamba.com/vw/forum/viewtopic.php?t=635567
Hawaiianguy808
PostPosted: Fri Jan 15, 2016 1:20 pm    Post subject: Re: 67' Bus Front Seat Frame Removal Reply with quote
Got it!! Thanks guys! I had to take a small wood block and line it up on the back part of the frame and hammer it out. I used WD-40 also.
