Bredberger Samba Member
Joined: January 28, 2009 Posts: 56 Location: Massachusetts
Posted: Wed Apr 06, 2016 10:41 am Post subject: towing with a dolley |
I have to tow my bug from Texas to Massachusetts, behind a 10 ft uhaul truck. It's a '72 manual that runs and has new tires. I have never towed with one of those dolleys that the front wheels sit on, so I have a few questions.
Just leaving the car in neutral does not cause any damage to the transmission, right?
Should I leave the steering wheel locked, or unlocked?
Can I go 70mph? Or do I need to go slower? 60 or 65 max?
Are there any other tips or things to look out for? I don't want to damage my car, and I really don't want anyone to get hurt, so any bits of advice are welcome and appreciated. |
Cusser Samba Member
Joined: October 02, 2006 Posts: 33109 Location: Hot Arizona
Posted: Wed Apr 06, 2016 10:58 am Post subject: Re: towing with a dolley |
Bredberger wrote: |
Just leaving the car in neutral does not cause any damage to the transmission, right? |
Correct. make sure parking brake is off.
Bredberger wrote: |
I have never towed with one of those dolleys that the front wheels sit on, so I have a few questions. Should I leave the steering wheel locked, or unlocked? |
That won't matter, because those wheels will not touch the ground !!!
Have you investigated by a VW tow bar, and use that behind the U-Haul? I bet that would be easier and less expensive, plus you'd own the tow bar. Note that Super Beetle and standard beetle tow bars are different !! _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
beetlenut Samba Member
Posted: Wed Apr 06, 2016 11:11 am Post subject: Re: towing with a dolley |
I used the tow dolly to move my car about 40 miles a while back. The dolly has its own pivot when you turn, so you would want to lock your steering wheel in the straight ahead position. I can't remember if the pivot has a lock position on it or not?
I wondered when I towed mine if I could have backed on to the tow dolly and locked my steering wheel straight, if that would have been better? More weight on the dolly, and no stress on your transmission? I would say ask the U-Haul people, but I doubt they know anything about an old beetle and what would work best. _________________ scrapyards are for quitters
Wetstuff wrote: |
... I spend more time shaking it than directing it?! I get a pretty decent blast for 8sec. then have to shake it again. |
- Words to live by right there!
My 74 Super rebuild thread: http://www.thesamba.com/vw/forum/viewtopic.php?p=6507104#6507104 |
Posted: Wed Apr 06, 2016 11:14 am Post subject: Re: towing with a dolley |
Thanks, Cusser
I wasn't sure if the front wheels needed to still let the back wheels pivot around the dolley through turns.
I do have a vw Tow bar. But my front end alignment is pretty out of whack, and the tow bar itself is in need of an overhaul. I wouldn't really feel good about using it over so large a distance just yet.
So is speed more a "play it by ear", or should I stick to 60? |
Posted: Wed Apr 06, 2016 11:33 am Post subject: Re: towing with a dolley |
Beetlenut
I agree I'm going to double check everything with the uhaul guy, but I expect he doesn't know much in the way of old bugs. I thought it would be best to check with the experts first. |
Air-Cooled Head Samba Member
Joined: October 15, 2002 Posts: 4070 Location: Chicago Suburbs
Posted: Wed Apr 06, 2016 11:56 am Post subject: Re: towing with a dolley |
Bredberger wrote: |
Thanks, Cusser
A tow bar probably wouldn't work, due the the height diff (depending on the truck). I brought a Bug from Hartford, CT to Chicago on a dolly. No problems.
As for speed, as long as the car is secure on the dolly, and the dolly secure to the truck, go as fast as you'd like. Or as fast as the U-Haul truck will go, which will be about 65.  _________________ Everything known to man has been written.
Readers are Leaders! |
Coffee Freak Samba Member
Joined: August 07, 2015 Posts: 137 Location: Lexington, NC
Posted: Wed Apr 06, 2016 12:08 pm Post subject: Re: towing with a dolley |
Since I can't think of a route between the two that doesn't involve mountains, I'd suggest spending a few more bucks and rent a flatbed trailer instead of a dolly. Most have surge brakes as well, which are very nice for slowing down in the mountains, even with a light vehicle like a Beetle. Price difference should be small, but the benefit for that long of a drive is HUGE.
If you blow a back tire on your Beetle while the fronts are on a dolly, you may not know for MILES and by then, you will have caused a lot of damage. I've seen it happen. One had a trail of sparks about 20 feet because the tire shredded off and it rode on the rim. Driver didn't see it because it was day time and the truck blocked his view of the car. |
Multi69s Samba Member
Joined: January 24, 2006 Posts: 5559 Location: Lefty, CA
windfish Samba Member
Posted: Wed Apr 06, 2016 12:48 pm Post subject: Re: towing with a dolley |
^ ^^ Owch.
uHaul's car trailers are decent and not much more expensive than the dolly iirc, used one to haul a Ford Galaxie 500 last year (pic).
Might be something to think about; call uHaul and see what size truck they'll allow to pull the trailer with a bug on it, they've got a lookup chart.
It's hard to beat all four tires off the road for peace of mind.
edit - was curious width-wise, as the bugs are a bit narrower than average.
Looks like they fit, if just barely - http://www.thesamba.com/vw/forum/viewtopic.php?t=597094 |
hotsam Samba Member
Joined: December 02, 2015 Posts: 368 Location: Ashburn, VA
Posted: Wed Apr 06, 2016 5:11 pm Post subject: Re: towing with a dolley |
It's a tight fit on a UHaul trailer, but it works.
_________________ 1968 Beetle |
volksworld Samba Member
Joined: November 26, 2011 Posts: 2580 Location: formerly NY currently NC
Posted: Wed Apr 06, 2016 6:42 pm Post subject: Re: towing with a dolley |
personally i'd fix the front end and use the tow bar....i flat towed from new york to florida every year for over 20 years...also made an adapter to use a regular bug tow bar on 2 different sciroccos....if you dont feel the car is roadworthy, go for a trailer... at least you can back up a trailer...my last choice would be the dolly....but if you do use it, DO NOT lock the column....the one year we dragged my wifes fwd automatic caravan to florida cause there was too much baby crap to put in the vw we used a dolly....and proceded to bend the tongue on a tight turn in a gas station....cause even though the beds on some dollys swivel, its not enough to match the angle the car will be on in a real tight turn |
wcfvw69 Samba Purist
Posted: Wed Apr 06, 2016 6:49 pm Post subject: Re: towing with a dolley |
I'd also recommend a trailer vs. tow dolly. You won't incur any wear and tear on your bug. Just plan on burning a bit more fuel as those U-haul trailers are HEAVY.
I drove from Phoenix to LA and back to pick up my 67 bug with a Ford F-250 truck and the U-haul trailer. By the time I got home and added up the fuel bills and my time, it would have been cheaper to pay a hauling company to bring it to me.
Something to keep in mind. _________________ Contact me at [email protected]
The Samba member since 2004.
Cali_Army_Guy Samba Member
Joined: March 19, 2015 Posts: 2094 Location: Stockton, CA
Posted: Wed Apr 06, 2016 7:38 pm Post subject: Re: towing with a dolley |
I vote for the flatbed trailer as well. Just make sure you're paying attention when driving on or have someone guide you. It's a tight fit.
Also, the driverside fender will fold down on the trailer. Do this before you load the car. Otherwise when you go to get out you could be an idiot like me and smack your door into the trailer fender  _________________ 2015 VW Passat Wolfsburg Edition
1966 VW Beetle - Sold |
gt1953 Samba Member
Joined: May 08, 2002 Posts: 13948 Location: White Mountains Arizona
Posted: Thu Apr 07, 2016 6:48 am Post subject: Re: towing with a dolley |
Advantage of flatbed is no wear and tear on the VW. Safer too.
Disadvantage fuel cost. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
Wolfgangdieter Samba Member
Joined: June 25, 2008 Posts: 1995 Location: FL Panhandle
Posted: Thu Apr 07, 2016 7:42 am Post subject: Re: towing with a dolley |
I flat towed a '71 bug from FL to VA years ago with old dry rotted "MAYPOP" tires - sweated they whole trip. 20 years later I towed the now transformed Porsche Speedster replica back to FL (retired there). Towed with a 4 cyl vehicle both ways with no issues - 1k miles one way. Go to Harbor Freight and buy the magnetic towing lights (about $10) for added safety. _________________ CMC '57 Porsche Speedster Replica and Dolphin boat tailed full pan VW MOD-T Street Buggy |
