Dauphine Redux.
yankee1919
yankee1919 is offline
PostPosted: Thu Jun 16, 2016 7:58 am    Post subject: Dauphine Redux. Reply with quote
Hello All,
I will be convert my 57 Renault Dauphine using 69 bug pan and running gear.
I will post and document the swap.
Tony Very Happy
pondoras box
pondoras box is offline
PostPosted: Thu Jun 16, 2016 9:07 am    Post subject: Re: DAUPHINE REDUX. Reply with quote
Please do, there was another one that was started and it looked like it was going to be really nice but it just stalled out.
I would like to do exactly the same thing one of these days and am very interested in seeing the progress on your project.
1961 23 Window (Bobo)
1965 13 Window (Lucas)
1957 Oval ragtop
1960 hardtop
1964 hardtop
1965 hardtop (Arschloch)
1973 standard bug (Dirty Gertie)
https://www.thesamba.com/vw/forum/viewtopic.php?t=804912
1988 Cabriolet VR6 conversion
yankee1919
PostPosted: Thu Jun 16, 2016 12:00 pm    Post subject: Re: DAUPHINE REDUX. Reply with quote
Hello Pondoras Box,
Thank you, yes very much inspired by Jdoisher 12/2011 build of "Dauphine Project".
I always had an interest in the Dauphines but the reliability and parts were the deciding factor in doing the swap. Wink
Tony
yankee1919
PostPosted: Thu Jun 16, 2016 12:03 pm    Post subject: Re: DAUPHINE REDUX. Reply with quote
Here is the Dauphine ready to be taken to the next area for deconstruction.
yankee1919
PostPosted: Thu Jun 16, 2016 12:04 pm    Post subject: Re: DAUPHINE REDUX. Reply with quote
Here is the donor, 69 with front beam damage.
It has papers and have the necessary parts to start.
yankee1919
PostPosted: Thu Jun 16, 2016 12:09 pm    Post subject: Re: DAUPHINE REDUX. Reply with quote
The info so far,
69vw wheelbase is2400mm/94.5in(will confirm)
Dauphine 2267mm/89.3 in.
That is the reason you have to shorten it.
Taken off vw body parts today.
Tony
yankee1919
PostPosted: Fri Jun 17, 2016 11:58 am    Post subject: Re: DAUPHINE REDUX. Reply with quote
Hello All,
[/img]
A couple of friends and beers and "presto"! Very Happy
Removal of the body was fairly simple but where the front beam is damage the steering box hung up the body when trying to lift it.
Did the old lift and twist and go.
I will remove the front beam this weekend and find another stripped pan for a front horn replacement.
Tony
Jacks
Jacks is offline
PostPosted: Fri Jun 17, 2016 2:54 pm    Post subject: Re: DAUPHINE REDUX. Reply with quote
Perhaps you could shorten the horn a few inches to correct the wheelbase.
Jack Staggs
Actual name
andk5591
andk5591 is offline
PostPosted: Fri Jun 17, 2016 6:49 pm    Post subject: Re: DAUPHINE REDUX. Reply with quote
You need 5" - I suspect it would greatly reduce the amount you can turn the front wheels before they hit the pan. Would guess you do what you do with a buggy, just cut out less.
Whats the track width difference? Just curious....
D-Dubya Manx clone 1914. Ex wifes car.
Maxine 61 Cal-look bug - Ex-wifes car.
There's more, but not keeping them...
yankee1919
PostPosted: Mon Jun 20, 2016 12:49 pm    Post subject: Re: DAUPHINE REDUX. Reply with quote
Hello Jacks and Andk5591,
Will look at your suggestions, there is a ton of cutting and welding to do.
Making a priority list and locating parts.
yankee1919
PostPosted: Mon Jun 20, 2016 12:54 pm    Post subject: Re: DAUPHINE REDUX. Reply with quote
You can tell the rear left is slightly bent in. Switch front good tire for bad left rear tire.
yankee1919
PostPosted: Mon Jun 20, 2016 12:59 pm    Post subject: Re: DAUPHINE REDUX. Reply with quote
Here is the bad, will have to replace front bulkhead.
I found
http://www.socalautoparts.com/product_info.php/zito-pereira-frame-head-bug-amp-ghia-complete-p-13980
I was thinking of using another pan but I feel that metal might be fatigued? Confused
Let me know what you guys thinks.
andk5591
andk5591 is offline
PostPosted: Mon Jun 20, 2016 8:00 pm    Post subject: Re: DAUPHINE REDUX. Reply with quote
You are in for a fight trying to get both ends of that pan straightened out. If you had another one, I would start with that. Keep in mind that depending on what you do, you will be shortening something and keeping everything square is very important.
I would suggest looking at som previous builds of something similar and see how they did it.
yankee1919
PostPosted: Wed Jun 22, 2016 7:43 am    Post subject: Re: Dauphine Redux. Reply with quote
Hello ANDK5591,
Thank you for your suggesting, yup plumb lines and jigs will make the process less of a nightmare.
Have a master welder within my group, just need to give him beer after he welds up. Wink
Will keep you guys posted.
nezz
nezz is offline
PostPosted: Sun Jun 26, 2016 3:26 am    Post subject: Re: Dauphine Redux. Reply with quote
there's a topic of someone doing the same conversion
The Dauphine Project
http://www.thesamba.com/vw/forum/viewtopic.php?t=491343
pondoras box
PostPosted: Mon Jun 27, 2016 12:08 pm    Post subject: Re: Dauphine Redux. Reply with quote
Yep, this is the one I was referring to in my earlier post.
1957 Oval ragtop
1960 hardtop
1964 hardtop
yankee1919
PostPosted: Tue Jul 05, 2016 3:12 pm    Post subject: Re: Dauphine Redux. Reply with quote
Hello,
That was a great build and I took notes and I will cover the same process with a little more detail.
Just got a donor motor for the project.
I cant find the link that gives more detail about motor Rolling Eyes
Ordering front bulkhead this week.
yankee1919
PostPosted: Fri Jul 08, 2016 2:59 pm    Post subject: Re: Dauphine Redux. Reply with quote
Got the bulkhead.
yankee1919
PostPosted: Tue Jul 12, 2016 7:51 am    Post subject: Re: Dauphine Redux. Reply with quote
Hello All,
Will post pics of the removal and installation of bulkhead.
yankee1919
PostPosted: Mon Jul 18, 2016 3:54 pm    Post subject: Re: Dauphine Redux. Reply with quote
Hello All,
I ordered the underside of the bulkhead. I realized it would take me to long to take out the old piece from damaged bulkhead.
I was able to loosen the IRS pivots and set them aside until I can figure out how much I will have to narrow the rear end.
I will take pics of the process.
Will keep you posted.
Tony Very Happy
Page 1 of 8
