Madumi Samba Member
Joined: February 11, 2016 Posts: 88 Location: Northern Arkansas
Posted: Mon Jul 25, 2016 3:44 pm Post subject: Suggestions how to fix collapsed jacking point |
I'm looking at a weld/fix for one of the jacking points on my '75 bus. It has already had a plate welded to its side in the past.
At first glance, it looks like I might be able to grind the upside down "U" from the inside (the bit that's now missing the top) & weld a new one in, but I'd love to hear how others have done this,
thanks!
Here's the present situation:
_________________ '75 sportsmobile |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 53016 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Mon Jul 25, 2016 4:13 pm Post subject: Re: Suggestions how to fix collapsed jacking point |
Looks like a job for a long wrecking bar shoved in there and stepped on. But if the jack point is that sketchy already why bother?, I'm guessing you've never seen the carnage that results when one decides to let go because of rust? It's likely safer you can't get the stock jack in there as it is now. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
borninabus  Samba R&D Dept.
Joined: May 18, 2006 Posts: 4757 Location: Arizona Highways
Posted: Mon Jul 25, 2016 5:44 pm Post subject: Re: Suggestions how to fix collapsed jacking point |
would need to see a much better picture(s) of the surrounding area to make any suggestions.
"colapsed" jack point to me, means the whole area is rotten and the jack point cannot be used anymore because it will not support the weight of the bus.
if the bottom is just bent like your photo shows, then do what BD says  _________________ 88 Van WBX, A/T - 93 Multivan 5cyl 5M/T - 13 JSW TDI 6M/T - 2012 Touareg TDI Sport |
1967250s Samba Member
Posted: Mon Jul 25, 2016 6:18 pm Post subject: Re: Suggestions how to fix collapsed jacking point |
Yeah, looking at your other pics shows lots of problems. Without a good area above the Jack point, a repair there will not help. First fix the pillar, sides, rockers (both inside and out) , floor, then replace the Jack point. Btw, as a regular jacking point, better to use a floor Jack and the torsion tube. The og Jack point's just for emergencies.ok _________________ '72 Elm Green Deluxe |
mikedjames Samba Member
Joined: July 02, 2012 Posts: 3389 Location: Hamble, Hampshire, UK
Posted: Tue Jul 26, 2016 11:56 am Post subject: Re: Suggestions how to fix collapsed jacking point |
That jacking point is toast. No metal visible above the hole where an OG jack would push up with a peg inside the jacking point.
It is just like one of mine, I have purchased a new jacking point but expect to have to weld a lot of structure between the floor (all three rocker panels inner middle and out) , the 'top hat' beam across under the floor , and the jacking point in the next few years.
Jack up on the torsion tubes or carefully on the chassis rails. But not on the bottom of the stock jacking points in any case. _________________ Ancient vehicles and vessels
Madumi Samba Member
Posted: Thu Jul 28, 2016 2:54 pm Post subject: Re: Suggestions how to fix collapsed jacking point |
Thanks so much for replies...
Definitely helps narrow down the "to-do" list.
The inside of the frame looks OK, but yes the rocker panel is in need of repairs (it's fibreglassed for now)... I'll put it off till I do the rocker panels/pillars+dog legs...
Not looking forward to fixing that one... Some time this winter
haha, here's a pic of what the fiberglass covered
Posted: Thu Jul 28, 2016 3:37 pm Post subject: Re: Suggestions how to fix collapsed jacking point |
Yeah, not the worst I've seen by any stretch, but I sure wouldn't want to try using the stock jack under a weak area like that. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
