How are center hub caps held onto steel wheels?
wilkins12
wilkins12 is offline
PostPosted: Sat Aug 06, 2016 3:50 pm    Post subject: How are center hub caps held onto steel wheels? Reply with quote
I have a 2002 Eurovan chassis with standard 16 inch steel wheels and lug bolts. It had full size generic hub caps on it when I bought it but I want to change to the center hub caps. I found four used ones, part number 701601149A, but they do not snap tightly enough over the lug bolts to stay on.
Can someone look at the pictures and tell me if this combination will work? Do I need to buy the plastic lug bolt caps (7M360117301C) or some other part to make them work? You can see from the picture that they fit perfectly in the center but they will not stay in place. Also, what is the purpose of the two holes opposite the logo in the hub cap?
