Type 2 nose cone and CB front mount
harrycrackerdog
harrycrackerdog is offline
PostPosted: Sat Jan 07, 2017 10:57 am    Post subject: Type 2 nose cone and CB front mount Reply with quote
got a type 2 nose cone for a rancho pro street gearbox going in a 59 ghia, decided on the cb rhino mount and said fits type 2 to 67
when to fit up and noticed it did not sit flat
do i start taking some of the mount away to get this flat or work a little off the nose cone or both ?
Or try again with a different mount ?
any one had experience of this
thanks
Paul.
60ragtop
Bonneville Belt Bitch
60ragtop is offline
PostPosted: Sat Jan 07, 2017 11:27 am    Post subject: Re: Type 2 nose cone and CB front mount Reply with quote
have you tried to rotate the mount 180 degrees?
Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote:
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote:
maybe he just snapped cause his car sucked Wink
slalombuggy
slalombuggy is offline
PostPosted: Sat Jan 07, 2017 11:44 am    Post subject: Re: Type 2 nose cone and CB front mount Reply with quote
Die grinder, aluminum burr, 30 seconds, problem solved.
mark tucker
mark tucker is offline
PostPosted: Sat Jan 07, 2017 11:54 am    Post subject: Re: Type 2 nose cone and CB front mount Reply with quote
x3 Wink on the mount. although I wont use a solid mount.
harrycrackerdog
PostPosted: Sat Jan 07, 2017 12:35 pm    Post subject: Re: Type 2 nose cone and CB front mount Reply with quote
Yup tried both ways,
thanks guys just wanted a bit of reassurance before I start grinding
I will carry on now , cheers Laughing
