82' Westie DK shifter linkage
Bristolwave
Bristolwave is offline
PostPosted: Mon Mar 06, 2017 1:23 pm    Post subject: 82' Westie DK shifter linkage Reply with quote
good day all,
im having trouble with my 82' westie shifting from 2nd to 3rd and ultimately 4th. I bought some replacement bushings from gowestie because the car would originally not shift into reverse, once I had the shift mechanism housing off, as named in the Bentley Manuel, I stripped off the rubber stop plate because I didn't know what it was and since then I cant get the trans to shift into 3rd and 4th. does anyone know where I can buy a rubber stop plate for a 4-speed 091 dk trans shifter linkage? or if I can make one with epoxy what dimensions I need to make this item i.e. thickness and LxW?
MarkWard
MarkWard is offline
PostPosted: Mon Mar 06, 2017 7:42 pm    Post subject: Re: 82' Westie DK shifter linkage Reply with quote
Here is a recent thread on the early shift linkage. Yes, a replacement block can be made. Read this thread through. It addresses many of the problems you will encounter. http://www.thesamba.com/vw/forum/viewtopic.php?t=672670&highlight=
NobyDoby
NobyDoby is offline
PostPosted: Mon Mar 06, 2017 11:58 pm    Post subject: Re: 82' Westie DK shifter linkage Reply with quote
I'm in the process of developing/reproducing/testing this rubber stop plate.
Tested the plate for the last 2500km and it seems to hold up very nicely.
It will take probably one to two months before i can start the first production run.
Anyone interested in a newly produced stop plate that fits like the original?
1980 Aircooled Type 4 CU 2.0L T3 Westfalia:
Flowed AMC 39x33mm heads with Porsche swivel adjusters and CR 8.0:1
94mm Mahle dished P/C's & 71mm Stroke
Original VW CU Bus Hydro Cam w/Febi Hydro Followers
Dual Dellorto's DRLA 40 - 32 Venturi's
SyncLink Throttle System
MSS Central Airfilter
123Ignition Tune & NGK BP6ET
Vintage Speed Dual Side Super Flow Type 4 Exhaust
