Lpec900 Samba Member
Joined: February 23, 2015 Posts: 45 Location: Henderson, NV
Posted: Tue Mar 28, 2017 9:55 pm Post subject: Need help identifying transmission asap |
Can any tell me if this transmission is a "freeway flier". Here are the numbers stamped on it. Thank you.
This number is stamped on the case of the tranny.
vw 113.301.103L
45 is under that number.
And this number is on the side plates
113.301.183F
And another number
AT 28 11 2
nickfancher1 Samba Member
Joined: February 03, 2014 Posts: 282 Location: Phoenix, AZ
Posted: Tue Mar 28, 2017 10:08 pm Post subject: Re: Need help identifying transmission asap |
I'm pretty sure "freeway flyer" is an aftermarket name, so the numbers are now meaningless.
Does it have a 5th gear? _________________ 1970 Beetle |
Posted: Tue Mar 28, 2017 10:33 pm Post subject: Re: Need help identifying transmission asap |
The guy claims it came out of a 73 super. So I am trying to figure if it's a freeway flyer. He bought the car as a project and doesn't know much about the tranny. It was already out of the car when he got it. |
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 13475 Location: West Coast, USA
Posted: Tue Mar 28, 2017 11:41 pm Post subject: Re: Need help identifying transmission asap |
What is your tire size?
Then:
Hook up a tach, and a gps, and tell us the speed of the car on the freeway at 3,600 RPM. Then tell us the speed of the engine at 60mph in 4th gear.
Robbie _________________ One-on-one tech help for your vintage Volkswagen:
www.airschooled.com
https://www.patreon.com/airschooled |
Bashr52 Samba Member
Joined: July 16, 2006 Posts: 5669 Location: On an island in VA
Posted: Wed Mar 29, 2017 5:18 am Post subject: Re: Need help identifying transmission asap |
Lpec900 wrote: |
Can any tell me if this transmission is a "freeway flier". Here are the. Umbers stamped on it. Thank you.
vw 113.301.103L
113.301.183F |
Your trans should have a 2 letter code on it, which will tell you what the originally installed gear stack would be. |
Posted: Wed Mar 29, 2017 7:58 am Post subject: Re: Need help identifying transmission asap |
I am looking to buy the transmission off the guy if it's a "freeway flyer". So I am trying to identify the numbers. |
Posted: Wed Mar 29, 2017 10:56 am Post subject: Re: Need help identifying transmission asap |
Lpec900 wrote: |
Unfortunately, the numbers only tell you what VW installed in it in the seventies. Unless the seller has a receipt from a transaxle rebuilder shop showing the gear ratios with a serial number that matches the transaxle, there is no way to tell without measuring the input shaft to output shaft ratios in degrees.
If you are willing to get a little dirty, put the transaxle in fourth, and spin the input shaft EXACTLY one turn. Count in turns + degrees, using a protractor, how much the output flanges turn. (Do both sides and make sure they are identical, so you're not getting any differential difference.) Then repeat the test, but this time spin the input shaft four times, and count the number of turns + degrees the output flanges move. Do each side. Report back.
Unfortunately, unless you have x-ray vision, there is no other way to determine this. Fortunately, freeway flyers reduce power, reduce cooling, and reduce oil pressure, so you probably don't want one anyway.
www.airschooled.com
jgcooney Samba Member
Joined: December 02, 2013 Posts: 21 Location: North Carolina
Posted: Wed Mar 29, 2017 2:54 pm Post subject: Re: Need help identifying transmission asap |
asiab3 wrote: |
Lpec900 wrote: |
Robbie |
X2 |
Posted: Thu Mar 30, 2017 7:16 am Post subject: Re: Need help identifying transmission asap |
Freeway flier is just a marketing term. It refers to the 3.88 r&p and .89 fourth gear VW installed in later cars. I believe VW changed to these gears as highway speeds increased in the 70's to lower cruising RPM's.
Find out what the two letter code is on the trans and we can tell you if it originally came equipped with the 3.88 |
neil68 Samba Member
Joined: March 17, 2007 Posts: 3448 Location: Calgary, Canada
Posted: Thu Mar 30, 2017 10:12 am Post subject: Re: Need help identifying transmission asap |
Lpec900 wrote: |
vw 113.301.103L
113.301.183F
And another number
AT 28 11 2 |
The AT code matches the 3.875 R/P from the 1973 Super Beetles (1303), provided that the transmission is the original and has not been rebuilt with different R/P and/or gears. _________________ Neil.
Der Kleiner Rennwagens
‘68 Beetle 2332 cc, 204 WHP
12.5 seconds @ 108 mph
Dynojet Test: https://www.youtube.com/watch?v=M9B_H3eklAo |
