Need help identifying bolt
Mickey Thompson Bill
Mickey Thompson Bill is offline
PostPosted: Wed Nov 22, 2017 3:02 pm    Post subject: Need help identifying bolt Reply with quote
Hey guys, i need to replace my engine cage hardware and i am trying to identify the size of the bolt that is the bottom. It attaches the tube the cage slides on to to the chassis. I can’t seem to figure out what it’s called. I think it is a 27mm but i am not 100 percent. Thanks!
Dark Earth
Dark Earth is offline
PostPosted: Wed Nov 22, 2017 4:03 pm    Post subject: Re: Need help identifying bolt Reply with quote
Here's a link ...
https://www.thesamba.com/vw/forum/viewtopic.php?t=491244
My Build: '69 Baja - Dark Earth Version
~I'm almost done. I just lack finishing up.~ Anxious
Dark Earth
PostPosted: Wed Nov 22, 2017 5:58 pm    Post subject: Re: Need help identifying bolt Reply with quote
Empi makes them too ...
http://vwcatalog.empius.com/newitems/7/1.html
dustymojave
dustymojave is offline
PostPosted: Thu Nov 23, 2017 2:16 pm    Post subject: Re: Need help identifying bolt Reply with quote
Its this part:
The term "Trans Strap Bolt" they use demonstrates the ignorance of the person who entered the item in the catalog. Companies should REALLY use people who are familiar with the things they are working with.
The trans strap is an aftermarket piece to hold the front of the trans down from trying to angle up when power is applied. That application would use 3/8" to 1/2" diameter bolts from the hardware store.
The bolts you need are Factory VW Bug bolts available only from a used VW Bug or from a company that specializes in VW Bug parts. Not New Beetle. Not general auto parts. You won't find one at an O'Reilly's. You won't find them on Rock Auto. JUST VW parts houses.
Richard
SoCalBajas Member
dustymojave
PostPosted: Thu Nov 23, 2017 2:28 pm    Post subject: Re: Need help identifying bolt Reply with quote
Why do you need to replace those bolts anyway? Chrome not shiny enough?
The "8.8" on those bolt heads tells you that the bolt is metric. Similar strength to an inch size grade 5 bolt. But even at a place that carries metric hardware, you won't find those bolts. You MIGHT find a sorta similar bolt, the same thread and overall length and maybe even the same head size. They are a special bolt designed for the job. The amount of smooth shank and the diameter of that shank are special to the job. If you were building a tube frame buggy with fabricated frame horns, you could use different bolts such as 3/4" fine thread grade 8. But for the factory frame horns, the special bolts are the best for the job.
Richard
SoCalBajas Member
Dark Earth
PostPosted: Thu Nov 23, 2017 2:57 pm    Post subject: Re: Need help identifying bolt Reply with quote
dustymojave wrote:
Its this part:
Weird they call it a "Trans Strap Bolt".
I found this website ...
http://oacdp.org/type1part.html
And, in the transmission section ...
They're calling it a " Bolt - Transmission carrier "
PostPosted: Fri Nov 24, 2017 12:49 pm    Post subject: Re: Need help identifying bolt Reply with quote
I’m going to use the same bolt, but the tubes that the engine cage slide onto are cracked and rusted so i needed to find out what size socket i need to remove those bolts so i can put on the new cage hardware.
jsturtlebuggy
jsturtlebuggy is offline
PostPosted: Fri Nov 24, 2017 1:57 pm    Post subject: Re: Need help identifying bolt Reply with quote
The size of the bolt head is 1-1/16in or 27mm. You can use either size of socket as they are the same dimension.
My Snap-on socket has both size stamp on it.
I always referred to it as a frame horn bolt.
Joseph
Fair Oaks/Orangevale, CA
Elrod Motorsports
Motion Tire Motorsports
Into Volkswagens since 1960
Dark Earth
PostPosted: Fri Nov 24, 2017 3:36 pm    Post subject: Re: Need help identifying bolt Reply with quote
Oops ... I really misread what you were asking d'oh!
I bought a set of these calipers and they have helped me with bolt sizes a lot on my project. I just convert from inches to mm after I make my measurements. They're a very worthwhile investment in my opinion.
https://www.harborfreight.com/6-inch-dial-caliper-66541.html
dustymojave
PostPosted: Sat Nov 25, 2017 11:05 pm    Post subject: Re: Need help identifying bolt Reply with quote
Better yet...
https://www.harborfreight.com/6-in-digital-caliper-61585.html
The digital calipers convert from inch to metric or vice versa at the push of a button. I have an identical caliper to the picture that I bought many years ago for use when I was worried about using my expensive caliper. But I haven't used my good ones for most of that time. And my good ones don't convert. They only do inches. The HF cheap ones have never failed or caused me any reason to not like them.
Richard
SoCalBajas Member
