ClareSutton Samba Member
Joined: December 05, 2004 Posts: 466 Location: Sarnia Ontario
Posted: Wed Nov 29, 2017 3:16 pm Post subject: bad engine misfire...tried everything |
My '73 standard beetle is misfiring badly and will periodically backfire out of the exhaust if pushed hard. I have replaced the points, plugs, condenser and the coil. I have checked and re-checked the timing (7 deg btdc with vacuum hose off). The distributer is about 2 years old and is a single vacuum unit. The carb is also about 2 years old. The car was running like a dream for the last two years and has suddenly started this. I checked the psi compression on all cylinders:
cyl 1--100,95,100, 95
cyl 2--100,100,100
cyl 3--110, 115, 110
cyl 4-- 110,110,110
I think these look fine and should not cause this kind of issue. The only thing I have not adjusted is the carb. I can't see how it would go out of adjustment all of a sudden. I have scanned the Samba forum search engine and I don't see anything that I haven't tried. Any other ideas??? Thanks. |
oceanair Samba Member
Joined: June 09, 2013 Posts: 724 Location: Victoria, BC
Posted: Wed Nov 29, 2017 3:22 pm Post subject: Re: bad engine misfire...tried everything |
Adjust the valves -- do it stone cold. .006 all of them. _________________ 84 Vanagon Pop Top Conversion from Tin Top, 1970 Ghia - all sweet rides! Love em!
Previous: Green 72 Tin Top, White 72 Westy, Blue 64 Beetle, Yellow 71 Squareback, 2014 Jetta TDI Wagon - wish I could have them all back! |
Starbucket Samba Member
Posted: Wed Nov 29, 2017 4:41 pm Post subject: Re: bad engine misfire...tried everything |
If you don't have an inline filter or its clogged its crap in carb. How old are your plug wires one might be leaking and shorting out momentary. When was the last time you gave it a good long 65 mph drive, you might be spitting out small pieces of carbon that hold the exh. valve open till it spits it out. |
Danwvw Samba Member
Joined: July 31, 2012 Posts: 8895 Location: Oregon Coast
Posted: Wed Nov 29, 2017 4:59 pm Post subject: Re: bad engine misfire...tried everything |
Adjusting the valves is always a good step before trying to tune the carb. However popping is usually mixture related. It could be it only pops when the engine is not good and warm. Someone may have removed the thermostat or the warm air to the carb or something is making it run very cool. Case should reach a temperature 180' F to be warm enough to tune.
It could be the carb choke opens too early. You also have it over advanced, timing it that way, but I don't think that is causing the popping. The Stock DP should static time at 5' ATDC with the stock distributor and carb. But most old PICT 34 Carbs are too leaky at the throttle shaft to idle anymore with the timing set so retarded. Do you have the retard vacuum side hose connected between the PICT 34 Carb and the Distributor? It may run better with that retard blanked off. Metal shavings in the points are really hard to clean out and they cause really bad random back-firing too.
_________________ 1960 Beetle And 1679cc DP W-100 & Dual Zeniths! |
Danwvw Samba Member
Posted: Wed Nov 29, 2017 5:08 pm Post subject: Re: bad engine misfire...tried everything |
Just re reading the first statement here, It's What engine? That is a Single Port Distributor. Does this 73 Beetle have a Single Port Engine in it? Like in Europe and England you see a lot of late bugs that have the PICT-30 Carb Perhaps you have one. I have seen them pop a lot when too cool! Perhaps the pre-heat manifold clogged up, if so you will sometimes see the manifold below the carb white with frost!
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 11004 Location: Oregon
Posted: Wed Nov 29, 2017 6:27 pm Post subject: Re: bad engine misfire...tried everything |
ClareSutton wrote: |
My '73 standard beetle is misfiring badly and will periodically backfire out of the exhaust if pushed hard. I have replaced the points, plugs, condenser and the coil. I have checked and re-checked the timing (7 deg btdc with vacuum hose off). The distributor is about 2 years old and is a single vacuum unit. The carb is also about 2 years old. The car was running like a dream for the last two years and has suddenly started this. |
I just diagnosed this same issue on a friends 66 with a later DP engine. We were on a cruise a few weeks ago and all went fairly well until we went our separate ways. My buddy texted that his engine had began backfiring and lost power. He tried everything to get it right. Nothing worked!
So I went to his house last Sunday with spares in the trunk of my car.
I first made sure that the carb was squirting gas from the accel pump. Good.
Checked for power to the coil. Good.
Checked static timing. Meh, close enough.
His new points were set to .016". Good.
Tried starting the car. It fired and it ran like shit.
I swapped out the dist for a known good one that I carry as a spare.
The engine fired right up. The issue was the condenser. The new(less than 500 miles on it) condenser had failed. It was a Brasil Bosch unit. The condenser on my spare is a German Bosch unit of unknown age(it's old).
If you can find a good German Bosch condenser, buy it. Otherwise in a pinch search for a Beru brand condenser. I have had decent luck with those.
Good Luck. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
2003 Astrovan? GFYS again, Xevin!  |
Multi69s Samba Member
Joined: January 24, 2006 Posts: 5552 Location: Lefty, CA
Posted: Wed Nov 29, 2017 7:54 pm Post subject: Re: bad engine misfire...tried everything |
I have already replaced the condenser (today). I have also replaced the ignition wires. I adjusted the valves last summer. I'll check them again. I am also wondering if one of the new spark plugs might be faulty. Maybe I should buy four new plugs. Thanks for the tips. I'll let you know what I find out. Also, it is a basic dual port carb that has been running great for the last two years. |
Posted: Wed Nov 29, 2017 8:10 pm Post subject: Re: bad engine misfire...tried everything |
What brand of condenser have you installed?
Seriously! Stop throwing parts at it and diagnose the problem.
Follow what I posted above and you'll likely arrive at the condenser again.
Yea, I know you just installed a new one today. But as shitty as they are these days, it's likely you have another bad one.
My buddy was convinced that it was something deeper in the engine. When It turned out to be the condenser after all.
I had a condenser fail 10 minutes after installation last year. And it was new.
Buy Once, Cry Once!
mukluk Samba Member
Joined: October 18, 2012 Posts: 7452 Location: Clyde, TX
Posted: Wed Nov 29, 2017 9:07 pm Post subject: Re: bad engine misfire...tried everything |
Step one for any rough running or tuning problem on a VW engine that the cause isn't immediately apparent: check your valve lash and adjust as required. Once that's done, check the plugs are gapped correctly, set the point gap, and then basic ignition timing.
Grab a stroboscopic timing light, connect it and start the engine up. Aim the timing light at your pulley and activate it, taking note of whether the light pulses are consistent or if they have a stutter -- repeat the check for all four spark leads, verify the advance is also functioning properly throughout the rpm range. Whichever leads have a stutter, those are the cylinders that are misfiring due to an ignition system problem. If none of them stutter yet it is still misfiring, the problem is due to a fuel delivery problem. _________________ 1960 Ragtop w/Semaphores "Inga" |
Posted: Thu Nov 30, 2017 5:30 am Post subject: Re: bad engine misfire...tried everything |
I'm going to check the valve lash again and see if I can find a good BOSCH condenser from a supplier in London Ont. The condenser I put in has been around for a few years in my parts supplies but has never been used. Not sure of the brand. I'll let you know the results. |
Randy in Maine Samba Member
Posted: Thu Nov 30, 2017 5:35 am Post subject: Re: bad engine misfire...tried everything |
Is that picture of the iced up intake/non working carb heat from your car? |
gt1953 Samba Member
Joined: May 08, 2002 Posts: 13947 Location: White Mountains Arizona
Posted: Thu Nov 30, 2017 6:43 am Post subject: Re: bad engine misfire...tried everything |
Cannot be that serious the condenser's do fail. Doubt if its plugs or wires. Like 67rustavenger has is a complete known good function distributor. When you swap that out it is like changing five items. Points, rotor, cap, condenser and the dizzy itself. That has worked for me as well eliminating those components. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
sb001 Samba Member
Joined: May 19, 2011 Posts: 10457 Location: NW Arkansas
Posted: Thu Nov 30, 2017 8:32 am Post subject: Re: bad engine misfire...tried everything |
Danwvw wrote: |
You also have it over advanced, timing it that way, but I don't think that is causing the popping. The Stock DP should static time at 5' ATDC with the stock distributor and carb. |
Except for the 73-74 dual ports that used an SVDA distributor, which the OP apparently has since they only mentioned disconnecting one vacuum hose. These were in fact timed at 7.5 BTDC so the OP has the timing set correctly.
I agree with starbucket- crap in the carb. It's the most logical explanation IMO. Since the OP did a compression test I would assume they would have noticed a bad plug or wire when removing those to do the test.
I won't completely rule out a bad condenser though. _________________ I'm the humblest guy on this board.
1600 SP engine
Solex 30 PICT 3 carburetor
Posted: Thu Nov 30, 2017 8:41 am Post subject: Re: bad engine misfire...tried everything |
Test your condenser using a DVOM. Connect the leads to the condenser and set the DVOM to the 200 OHM scale and watch the numbers rise until you reach overload then switch the leads. The scale should climb back down, if not you have a bad condenser. Quit guessing and always carry a spare that you have tested. |
richardc Samba Member
Joined: September 06, 2010 Posts: 269 Location: New Jersey & North Carolina
Posted: Fri Dec 01, 2017 10:30 am Post subject: Re: bad engine misfire...tried everything |
check firing voltage at coil wire, does it jump a good 1/2 inch and if it does hold coil wire over distributor rotor and see if it jumps to rotor while cranking ( if it does you have defective rotor).
Rich _________________ 1970 Ghia vert |
ashman40 Samba Member
Joined: February 16, 2007 Posts: 16552 Location: North Florida, USA
Posted: Fri Dec 01, 2017 6:00 pm Post subject: Re: bad engine misfire...tried everything |
Please provide specific details as follows:
Make/model of your carb?
Make/model of your distributor? (use a mirror to see stamping on distributor body)
Spark plugs make/model?
Spark plug wires... solid wire core or suppression core? What brand?
Tune-up (replace cap, rotor, points, condenser) when was it last done?
Where you able to do the valve adjustments? Were any valves tight or loose?
While you are adjusting the valves for each cylinder in turn, confirm that the distributor rotor is pointing to the spark plug wire that runs to the same cylinder you are adjusting the valves on (valve adjustments are done when the cylinder is at the end of the compression stroke so the rotor should be nearly in position to deliver a spark to the same cylinder).
Report back with your details.
I suggest you read thru Speedy Jim's page on Engine No start troubleshooting. Walk thru his troubleshooting steps and they may help you isolate something that is not right.
http://www.speedyjim.net/htm/eng_strt.htm _________________ AshMan40
Posted: Sat Dec 02, 2017 6:23 am Post subject: Re: bad engine misfire...tried everything |
My distributer is an SVDA vacuum adv which I bought new from CIP in June 2015 (part no. VWC-043-905-205). My carburetor is a Euromax 34 PICT-3 bought new from CIP in 2013 (part no, C24-113-129-031K. The SVDA is supposed to work well with a 34 PICT but not a 30 or 31 PICT. This combination has worked extremely well up until now. I would have to pull my plugs to check the exact numbers but they are NGK and were purchased at NAPA as designated for my car. The spark plug wires are NAPA brand premium. I adjusted the valves last summer and replaced the air filter at the same time. The condenser that I just installed has never been used but was in my parts supply for a few years. I'll try replacing with a new one. The dist cap and rotor were also changed with new un-used parts from my parts supply but are at least two years old. |
vamram  Samba Member
Posted: Sat Dec 02, 2017 6:56 am Post subject: Re: bad engine misfire...tried everything |
My distributer is an SVDA vacuum adv which I bought new from CIP in June 2015 (part no. VWC-043-905-205). |
Definitely do as Ashman says and follow the speedy Jim troubleshooting procedure.
That said, I would be highly suspicious of this distributor. YMMV, but I've never had success w/Pertronix distributors, coils or their electronic ignition unit. I bought that same distributor new a few years back and the vacuum can failed w/in a year. After that, it was useless even as an 009 because it's timing bounces all over the place. I still have it in my parts stash, although i'm not sure why. _________________ "Men are qualified for civil liberty in exact proportion to their disposition
Click to view image
Save the Supers!! |
Posted: Sat Dec 02, 2017 2:52 pm Post subject: Re: bad engine misfire...tried everything |
Ok, I took a quick look under the air cleaner today to see if the accelerator pump was squirting fuel into the carb......and it wasn't. I didn't think to check that earlier since the carb isn't that old. So I guess there may be a fuel clog somewhere in the carb (fuel pump is working well because there was pressure in the line) or there is something wrong with my accelerator pump. I'll have a closer look tomorrow. |
