AZ Landshaper Samba Member
Joined: February 08, 2009 Posts: 1706 Location: The Old Pueblo
Posted: Fri Jan 26, 2018 6:13 am Post subject: Install this tach? |
Trying to decide wether to attempt the installation of a 86 tachometer and instrument panel into my 81 vanagon w subaru conversion.
Im not that entertained by the clock but would like to see the tach reving w my suby swap. In addition my instrument panel has three broken attachment clips and the lights no longer work so i drive in total darkness.
Old Volks supposedly has the info but their site looks to be down. Is this a hard conversion? Ideally I will connect the coolant temp gauge and the tach and all those things I dont currently have. Ive read what I can but the info is elusive w/o direct access the OVH site and PDF.
Whos done this? Was it that difficult? Any warnings to heed? _________________ Support Small Business.
85 Weekender w/ EJ22
Previously
64, 71, 72, 73, 76, 81, 84, 85 & 87 Campmobiles and Westfalias
and a 67 bug. |
Jake de Villiers Samba Member
Joined: October 24, 2007 Posts: 5938 Location: Tsawwassen, BC
Posted: Fri Jan 26, 2018 8:25 am Post subject: Re: Install this tach? |
I put an '87 cluster with tach into my '86 with clock and it wasn't hard. I used the help from the site you mentioned.
Being the hoarder I am, I saved the PDF. Shoot me an email and I'll send it to you!  _________________ '84 Vanagon GL 1.9 WBX
@jakedevilliersmusic1
www.crescentbeachguitar.com
www.thebassspa.com |
slowcoach Samba Member
Joined: December 28, 2010 Posts: 21 Location: West Yorkshire, UK
Posted: Fri Jan 26, 2018 11:16 am Post subject: Re: Install this tach? |
That's the guide to use. If your 81 cluster has the vertical multiplug, you'll have to reorder the pins in your harness plug to match the newer horizontal one. But that's easy plug and play, just follow the guide closely and make your notes. You'll need to convert the suby rev signal into one that's compatible with the vw vdo gauge though for the tach to work. Here in the UK Richard at rjes engineering makes a module to do that . You can prob get a similar unit?  _________________ EJ20 Subaru Trakka 1984 |
jacob. Samba Member
Posted: Fri Jan 26, 2018 4:03 pm Post subject: Re: Install this tach? |
| AZ Landshaper wrote: |
Whos done this? Was it that difficult? Any warnings to heed? |
No need for somebody to send you the PDF. Save it for yourself. Great invention called the wayback machine internet archive.
https://web.archive.org/web/20160315123038/http://www.oldvolkshome.com/late_van_cluster_install.pdf _________________
| RCB wrote: |
| jacob gets razzed a lot cause he has the only GEX engine thats lasted longer than half an oil change. |
Posted: Fri Jan 26, 2018 7:57 pm Post subject: Re: Install this tach? |
I have the vertical plug. I also have the screw in speedo cable. Would it be a better route to install the Gowesty blue foil replacement and just a VW stock tach? Or is the instrument panel still the best way to go. _________________ Support Small Business.
Previously
and a 67 bug. |
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 10465 Location: Orbiting San Diego
Posted: Fri Jan 26, 2018 8:03 pm Post subject: Re: Install this tach? |
It is pretty simple to do. Your old speedo will work in the tach cluster fine.
Post a photo of the back side of the new cluster.
Mark |
Posted: Fri Jan 26, 2018 9:52 pm Post subject: Re: Install this tach? |
Gotcha. THat makes sense. Old speedo in new cluster to retain screw on feature. Foil should be able to handle this as a simple speedo replacement.
I see light at the end of the tunnel. _________________ Support Small Business.
Previously
and a 67 bug. |
Posted: Sat Jan 27, 2018 9:26 am Post subject: Re: Install this tach? |
Having a working oil pressure warning light is pretty important. Depending of the version of blue foil this may take an extra step. There are 4 versions of the tach foil that I know of. Most tach foils need the extra step when an earlier speedo is used.
Mark |
