m12 x 1.5 x 25-30mm bolts......why so hard to find?
crankbait09
crankbait09 is offline
PostPosted: Fri Mar 30, 2018 11:13 am    Post subject: m12 x 1.5 x 25-30mm bolts......why so hard to find? Reply with quote
I have googled, and called all the local auto part stores in my area, and no one carries this bolt. All the threads on here from years past, say its very easy to find. auto part stores, home depot, lowes, etc...nope nope nope
I found some on amazon with the tapered face, for lug bolts, but i have to buy a pack of 10. all stores in my area carry nothing more than a 10mm in the size i need.
is anyone else having this problem?
i only need 2
(this is for the torque meister tool)
Brick wall Brick wall Brick wall Brick wall Brick wall Brick wall Brick wall Brick wall
Cusser
Cusser is offline
PostPosted: Fri Mar 30, 2018 12:46 pm    Post subject: Re: m12 x 1.5 x 25-30mm bolts......why so hard to find? Reply with quote
Try Ace Hardware or True Value Hardware, in the little drawers.
Here's why: 12mm x 1.5mm pitch is considered "fine pitch". (12mm x 1.25mm is called "very fine pitch"; common thread is 12mm x 1.75mm)
crankbait09
PostPosted: Fri Mar 30, 2018 5:18 pm    Post subject: Re: m12 x 1.5 x 25-30mm bolts......why so hard to find? Reply with quote
I've seen plenty of 1.25, and 1.75. but no one likes that 1.5.
i even tried Fastenal, and got denied.
I have an Ace, and a True Value pretty close to me. I'll try them tomorrow.
thanks for the suggestions.
turbotype1
turbotype1 is offline
PostPosted: Fri Mar 30, 2018 6:31 pm    Post subject: Re: m12 x 1.5 x 25-30mm bolts......why so hard to find? Reply with quote
https://www.belmetric.com/12x15-fine-c-533_541_389/?zenid=jd7kp2r6vdc89u70eh0e6655a7
117harv wrote:
This new fad of get it the lowest, or run it with the worst looks, (patina) isn't cool, it's for the hey everyone look at me crowd, i'm driving a beat down ratty, unsafe, VW, how cool am I ???...your not....
Pissing off the purists since 1997
Wanted: Boyd Motors plate frame
57 Turbo Oval Sliding rag
67 13 window delux walk-thru- now 21
64 all original for the misses
83 Sinka m-TDI diesel
crankbait09
PostPosted: Sat Mar 31, 2018 1:37 pm    Post subject: Re: m12 x 1.5 x 25-30mm bolts......why so hard to find? Reply with quote
ACE came through. They only had the smallest length being 40mm, but I bought washers to decrease that length. $5 and I had what I needed.
thank you!!!!!
