Water in tailpipe
mpablazer
mpablazer is offline
PostPosted: Tue Jun 26, 2018 12:05 pm    Post subject: Water in tailpipe Reply with quote
Hi, Whenever it rains I seem to get an excess of water in teh tailpipe/exhaust. The tailpipe is of course scalloped with the short end sticking up to the sky - so water just gets in it when it rains.
The issue is that I will stall or have to nurse the accelerator while idling until the water blows out of the taillpipe - so I believe it is enough to cause an exhaust blockage.
Ive looked for some tailpipe ends to maybe loop the tailpipe opening down. I cant find anything that looks quite right.
Has anyone had this problem, and any links to parts you may have used to resolve it?
PDXWesty
PDXWesty is offline
PostPosted: Tue Jun 26, 2018 12:12 pm    Post subject: Re: Water in tailpipe Reply with quote
The tail pipe should be able to rotate down. Unbolt it and rotate it to the correct position.
89 Westy 2.1 Auto
Wildthings
Wildthings is offline
PostPosted: Tue Jun 26, 2018 3:44 pm    Post subject: Re: Water in tailpipe Reply with quote
Your muffler may not be mounted correctly. Is this a conversion?
fleet_maintenance
fleet_maintenance is offline
PostPosted: Tue Jun 26, 2018 7:14 pm    Post subject: Re: Water in tailpipe Reply with quote
If it is a cobbed aftermarket system and you can't rotate the tailpipe, there's always the Sawzall. Post a pic before cutting
Edit: the more I think about it, please post a video, I'm wondering if the rough post rain startup has more to do with dampness under your distributor cap, etc, than water in the tailpipe.
mpablazer
PostPosted: Fri Jun 29, 2018 9:51 am    Post subject: Re: Water in tailpipe Reply with quote
thanks all for the replies! I didnt think about removing and reinstalling the tailpipe, I just assumed it only bolted on one way. When I start the car in this condition it spews out about a pint of water before it will run normally - so I dont think its the distributor (which I also just replaced two weeks ago in a tune up).
If I cant easily get the tailpipe off due to rusty bolts - I may just go the sawzall route!
MarkWard
MarkWard is offline
PostPosted: Fri Jun 29, 2018 11:20 am    Post subject: Re: Water in tailpipe Reply with quote
Drill an 1/8 inch hole in the low spot of the tailpipe to keep water from collecting. That's if you don't have access to a welder or the ability to remove the bolts.
Wildthings
PostPosted: Fri Jun 29, 2018 12:59 pm    Post subject: Re: Water in tailpipe Reply with quote
I just bought a piece of SS tubing with a 45° bend in it and welding it in place of the original rotting steel elbow at the angle of my choice. Had the local muffler shop swell the end to get a perfect fit before doing the welding. Looks nice and should last for decades if it doesn't get crunched.
