ECU wiring question
Igottaquit
Igottaquit is offline
PostPosted: Sun Nov 25, 2018 7:49 pm    Post subject: ECU wiring question Reply with quote
I'm actually working on a sand rail. It sat outside uncovered for about 20 years, so the original engine got water inside and it started to fall apart. I picked up a 1980 Vanagon drivetrain (engine number CV043944), took a little fabricating to get it mounted. My issue now is the wiring. Every single wire on the ECU harness is white.... There are only 2 connectors to the vehicle, a 6-wire rectangular and one that looks almost like a relay connector. I have the relay that was attached to the starter.
All the wiring diagrams I see have color-coded wires, so I am at a loss how to get this up and running. I assume that at a minimum I need power and ground to the ECU and power from the ECU to the fuel pump. I will have other wiring questions later, but I'll settle for this now.
Vanagon Nut
Vanagon Nut is offline
PostPosted: Sun Nov 25, 2018 8:09 pm    Post subject: Re: ECU wiring question Reply with quote
This should help for part of what you're doing. Info on the "double relay" wiring, operation, and possible substitute of 2 generic relays for the VW part:
http://www.ratwell.com/technical/DoubleRelay.html
The Bay Window forum here should have more info on the fuel injected 2.0 as it was used in late model year Bays
If you don't have a Vanagon Bentley manual, a Haynes air cooled version should help and may have an ECU pin out test table that would help ID ECU pin numbers to their parts.
Neil.
1981 Westy DIY 15º ABA
(VW Gas I4)
1988 Westy DIY 50º ABA
VE7TBN
