Elvin4899 Samba Member
Joined: November 24, 2018 Posts: 11 Location: Kuala Lumpur, Malaysia
Posted: Sat Dec 08, 2018 12:19 am Post subject: My car pulls to the left when i brake |
As the subject says, my 67 pulls to the left when under any type of braking, any ideas on what's wrong? _________________ RHD 1967 Beetle Sedan (Phoebe)
RHD 1991 Mercedes W124 230E Manual
RHD 2000 Mercedes W210 E280 |
Tim Donahoe Samba Member
Joined: December 08, 2012 Posts: 11796 Location: Redding, CA
Posted: Sat Dec 08, 2018 12:49 am Post subject: Re: My car pulls to the left when i brake |
Hopefully, it’s just a matter of adjusting your brakes.
Tim _________________ Let's do the Time Warp again!
Richard O'Brien |
66brm Samba Member
Joined: January 25, 2010 Posts: 3676 Location: Perth Western Australia
Posted: Sat Dec 08, 2018 5:17 am Post subject: Re: My car pulls to the left when i brake |
First is the easiest, check tyre pressures all round, adjust the brakes, raise each wheel off the ground and have someone press the brake pedal, check each locks up.
After that it's time to dig deeper, focus on the right front, I suspect there's an issue there _________________ Aust. RHD 66 Type 1
Aust. RHD 57 Type 1 Oval
modok wrote: |
I am an expert at fitting things in holes, been doing it a long time |
Ojai63dbl Samba Member
Posted: Sat Dec 08, 2018 6:13 am Post subject: Re: My car pulls to the left when i brake |
if it pulls to left, left I clamping down harder than right side.
this can be caused by a collapsed brake hose (fairly common) - I usually change them in pairs to be on safe side
But Id start with adjusting brakes, bleed air from brake cylinder and flush line with fresh brake fluid by bleeding more volume than air (not a bad idea to refresh brake fluid every so often - I have seen it come out black before it looks clear on some cars) , if still an issue ,most likely brake lines or leaking brake wheel cylinder (or is it a caliper on a 67). Both are cheap. |
Sharp64 Samba Member
Joined: August 27, 2015 Posts: 5304 Location: Central Florida
Posted: Sat Dec 08, 2018 8:01 am Post subject: Re: My car pulls to the left when i brake |
Perhaps it can work the other way, but in my case a collapsed brake line resulted in a temporarily locked drum that would eventually release not the other way around. As said. I would agree with checking your adjustment first.
Here’s a quick link if you’re not familiar with it. Takes only a jack and simple hand tools to accomplish.
http://www.vw-resource.com/brake_adjust.html _________________ 1960 Indigo Blue Ragtop (Blue Barry)
1967 Ghia
1985 Westy Money Pit
“...some men aren't looking for anything logical, like money. They can't be bought, bullied, reasoned, or negotiated with. Some men just want to watch the world burn.” - Michael Caine |
anthracitedub Samba Member
Posted: Sat Dec 08, 2018 8:20 am Post subject: Re: My car pulls to the left when i brake |
If it pulls left your issue is most likely with the RH front brake. Pull the drum,look for issues... wet shoes, leaky/frozen wheel cylinder and of course the brake line could be internal blocked. Plan on treating the whole axle to some brake repair/maintenance. |
Joined: May 17, 2003 Posts: 4876 Location: Harmony, PA
Posted: Sat Dec 08, 2018 9:42 am Post subject: Re: My car pulls to the left when i brake |
^^^^^this^^^^^
If it’s pulling to the left, it’s most likely that the left brake is working, while the right is not.
When I worked at an Aircooled shop, brake jobs were inspecting the hard lines, and replace everything else. Once you start replacing individual components, other non-replaced components are most likely not far behind from failing. Sure, you may be able to continue to use shoes, and drums, but if you’re having an issue with one wheel cylinder/hose, I’d replace all four. |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 26109 Location: Olympia Wash Rinse & Repeat
Posted: Sat Dec 08, 2018 9:49 am Post subject: Re: My car pulls to the left when i brake |
Could also be the right wheel cylinder has started to leak slightly enough to dampen the shoe so it grabs more. _________________ In Stereo, Where Available! |
Lrodri64 Samba Member
Joined: August 05, 2013 Posts: 34 Location: Puerto Rico
Posted: Sun Dec 09, 2018 5:42 am Post subject: Re: My car pulls to the left when i brake |
Check for different diameter brake cilinders.
Happened to me. |
Cusser Samba Member
Joined: October 02, 2006 Posts: 33199 Location: Hot Arizona
Posted: Sun Dec 09, 2018 9:20 am Post subject: Re: My car pulls to the left when i brake |
Lrodri64 wrote: |
Check for different diameter brake cylinders.
Happened to me. |
Yes, but original poster did not say whether this pulling started right after he "did something" to the VW, or if it was doing fine and then all of a sudden started happening. That's an important piece of information for us to help through a computer.
Yes - one must take a hands-on look-see. I'd say an under 30 minute diagnosis. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
