adjusting height on front end
BugMeister69'
BugMeister69' is offline
PostPosted: Tue Aug 05, 2003 11:16 am    Post subject: adjusting height on front end Reply with quote
I have an adjustable front end but I dont know how to adjust it,I have a 69 hard top.can someone tell me how to raise it about an inch because its really low and sometimes my tire rubs my fender?maybe a website has the information, but could someone help me?
Its all fun and games till you get RUN OVER BY A BUG!!!
Steve.
Stinger Specialist
Steve. is offline
PostPosted: Tue Aug 05, 2003 11:51 am    Post subject: Reply with quote
Idont know, I pulled out the the two bolts completely, but I'm running 125's no rubbing! sorry
'64 Java
'66 Deluxe
Wanted! East LA Atlantic VW license plate frame!
View user's profile Send private message Send e-mail AIM Address Facebook Gallery Classifieds Feedback
Steve.
Stinger Specialist
Steve. is offline
I dont know, I pulled out the the two bolts completely, but I'm running 125's no rubbing! sorry
'64 Java
'66 Deluxe
Steve.
Stinger Specialist
Steve. is offline
PostPosted: Tue Aug 05, 2003 11:52 am    Post subject: Reply with quote
Oops!
'64 Java
'66 Deluxe
FunkFlex61
Samba Athlete
FunkFlex61 is offline
PostPosted: Tue Aug 05, 2003 6:31 pm    Post subject: Reply with quote
I usually just jack up the front of the car, loosen the two bolts,the lower the jack down to where u want it to be then get back under and tighten up the bolts. They have to be cranked down or they wont hold.
'60 Kombi Walk Through
'56 Euro. Ragtop
‘56 Standard Hardtop
nobugJay
nobugJay is offline
PostPosted: Tue Aug 05, 2003 6:56 pm    Post subject: Reply with quote
My 67 had the adjusters welded in wrong, where it wasn't driveable even with it raised all the way up. So, I had to drill out the slot to be able to raise the adjuster more and get it off the ground.
DubStyle
SBS Hit Squad
DubStyle is offline
PostPosted: Wed Aug 06, 2003 4:02 am    Post subject: Reply with quote
1) Jack the front end up till the tires are off the ground.
2) Loosen the bolts that keep the adjuster in place
3) Let the tires fall how ever high you want to raise it. (Using the jack to control this helps)
4) Tighten the bolts as much as you can.
5) Drop it back to the ground remove the jack and test drive it.
Not sure how much raising you Bug will change Alignment so make sure you are good to go.
Anthony
SBS #1
SBS #1 on FB
"The original & best lowered Split Bus website/club"
