rearenddude Samba Member
Posted: Tue Jul 02, 2019 11:45 am Post subject: 914 transaxle |
is it possible to reverse the output direction in a 914 transaxle ?
simple flip over like vw transaxle or different ring and pinion required ?
I have a 71 Fiat 850 with a VW 1776cc coupled to a VW transaxle (freeway flier). but I need more gears. Thinking of the 914 tranny but it's a pusher..
any input would be nice...Thanks |
Joined: December 28, 2016 Posts: 311 Location: atlanta ga
Posted: Tue Jul 02, 2019 1:28 pm Post subject: Re: 914 transaxle |
rearenddude wrote: |
yes you can take out the ring gear and pinion and reverse it. no problem |
Wolfgangdieter Samba Member
Joined: June 25, 2008 Posts: 1992 Location: FL Panhandle
Posted: Wed Jul 03, 2019 5:33 am Post subject: Re: 914 transaxle |
YES - slight issue with needing to plug/move breather valve. The big cost is changing the nose cone/hockey puck to mate to the VW engine. Remember early 914 til '73 were called tail shifters - BUT shifter is really off to side unlike the 911/912 which were true tail shifters. The later '74 914 were called side shifters and in the 914 configuration shifted smoother (w/less slop) - they are more difficult to make into a tail shifter (and cost more as they are more desirable in a 914). Plus you need to fabricate some kind of support cradle. And of course you need a 5 speed shifter - the VW 4 speed shifter won't work.
Good sources of info and parts are (they are in Germany so shipping can be costly):
https://www.bugat5speed.de/en/beetle-co/transmissions/conversion-parts-porsche-transmission-901-914
https://www.aircooled.net/vw-transmission-porsche-5-speed-conversion/ _________________ CMC '57 Porsche Speedster Replica and Dolphin boat tailed full pan VW MOD-T Street Buggy |
Jacks Samba Member
Joined: July 15, 2006 Posts: 2428 Location: San Clemente, Ca.
Posted: Thu Jul 04, 2019 1:15 am Post subject: Re: 914 transaxle |
Hockey puck?  _________________ Jack Staggs
Actual name |
Posted: Thu Jul 04, 2019 8:06 am Post subject: Re: 914 transaxle |
Opps - not engine - meant to say mate to the shift rod in the VW tunnel. Hockey puck should have been hockey stick (the shaft that does the gear selection). _________________ CMC '57 Porsche Speedster Replica and Dolphin boat tailed full pan VW MOD-T Street Buggy |
