jpsport Samba Member
Joined: February 28, 2004 Posts: 38 Location: Seattle
Posted: Sun Oct 27, 2019 7:34 pm Post subject: IDF 40 mm carb jetting suggestions/help |
I am struggling with my carbs. Here is my challenges and I can’t be the only one who is done something dumb. Pulled off kadrons
IDF, dual 40mm, standard jets, Venturi 28, f11 tubes .50 idle, air, mains out of the box etc.
Engine AE code 1972:
1641cc
041 heads
Stock rockers
C/W crank balanced with 12 lb flywheel
009 distributor with points
Here we go,
Engle 110 cam
Can’t get an idle to save my life, runs super rich just horrible. Very frustrating
What jetting and Venturi combination would work best for a decent idle and runs good not great.
What timing?
Help Samba group? |
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15598 Location: Deep in the 405
Posted: Sun Oct 27, 2019 7:44 pm Post subject: Re: IDF 40 mm carb jetting suggestions/help |
try some 45 or 47.5 idle jets from ACN. http://vwparts.aircooled.net/Weber-IDF-DCNF-Idle-Jets-p/74405.htm _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
Posted: Sun Oct 27, 2019 8:49 pm Post subject: Re: IDF 40 mm carb jetting suggestions/help |
I did try the .45 idle and ran less rich but still struggled with idle and he air flow adjustment screws had no impact the idle did not fall of in either direction in or out. |
QRP Samba Member
Joined: April 27, 2008 Posts: 1886 Location: NORTH HOLLYWOOD,CA
Posted: Sun Oct 27, 2019 9:53 pm Post subject: Re: IDF 40 mm carb jetting suggestions/help |
jpsport wrote: |
If adjusting the idle screws have no effect I would guess your idle jets are plugged or throttle plates are to far advanced.
Did you do a pre set before installing? |
madmike Samba Member
Joined: July 11, 2005 Posts: 5299 Location: Atlanta,Michigan
Posted: Mon Oct 28, 2019 3:20 am Post subject: Re: IDF 40 mm carb jetting suggestions/help |
check the enrichment plungers, had a pair stuck once  _________________ 'Black Ice'Drag Buggy 'Turbo'
Rail Buggy 1915 turbo
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 10856 Location: Oregon
Posted: Mon Oct 28, 2019 4:56 am Post subject: Re: IDF 40 mm carb jetting suggestions/help |
Any carb/s I buy. Get cleaned and the floats set before installation.
It does not matter who I get them from. The carbs get a rough handling during shipping.
Did you check the float level? _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
tattooed_pariah Samba Member
Joined: April 24, 2006 Posts: 2053 Location: El Cajon, CA
Posted: Mon Oct 28, 2019 6:04 am Post subject: Re: IDF 40 mm carb jetting suggestions/help |
madmike wrote: |
check the enrichment plungers, had a pair stuck once  |
I've always been under the impression that unless you are using the chokes, those plungers have no impact anyway, which is why some many people shove them all the way down (closing off the circuit) and install plugs.  _________________ -pariah
'72 Volksrod |
Posted: Mon Oct 28, 2019 6:17 am Post subject: Re: IDF 40 mm carb jetting suggestions/help |
What is a enrichment plunger never heard of that one. |
KROC Samba Member
Joined: February 20, 2006 Posts: 364 Location: Vancouver B.C.
Posted: Mon Oct 28, 2019 6:37 am Post subject: Re: IDF 40 mm carb jetting suggestions/help |
What is your fuel pressure? 50 idles will be close enough.
Check your float heights
Re sync. them, make sure your throttle linkage is dead nuts even on each carb
You need to have responding A/F mixture screws at idle on all 4 holes before you move forward with tuning. |
Posted: Mon Oct 28, 2019 6:45 am Post subject: Re: IDF 40 mm carb jetting suggestions/help |
jpsport wrote: |
They are behind a backing plate on 99% of the IDF bodied carbs.. hardly anyone actually uses a choke circuit these days...
https://www.thesamba.com/vw/forum/viewtopic.php?p=5560887 _________________ -pariah
'72 Volksrod |
udidwht Samba Member
Joined: March 06, 2005 Posts: 3802 Location: Seattle, WA./ HB, Ca./ Shizuoka, Japan
Posted: Mon Oct 28, 2019 9:52 pm Post subject: Re: IDF 40 mm carb jetting suggestions/help |
47.5 idles
10-11mm float height with gasket in place ball NOT depressed
Fuel pressure 3-3.5psi max (critical)
115 mains
190 air corrector jets
And get an SVDA on it. _________________ 1972 Westy Hardtop/Type-4 2056cc
96mm Biral AA P/C's~7.8:1CR
71mm Stroke
73 Web Cam w/Web solids
Bosch W8CC plugs
S&S 4-1 w/Walker QP 17862
3 rib 002 Trans
185R14 Hankook tires |
Posted: Sun Nov 03, 2019 8:30 am Post subject: Re: IDF 40 mm carb jetting suggestions/help |
Will a SVDA actually work with a cam that big on a 1641 cc engine. |
Posted: Sun Nov 03, 2019 9:13 am Post subject: Re: IDF 40 mm carb jetting suggestions/help |
jpsport wrote: |
Optimally? Likely not. Other option pony up for a CB black box _________________ 1972 Westy Hardtop/Type-4 2056cc
71mm Stroke
Bosch W8CC plugs
3 rib 002 Trans
