Interesting new rods, thoughts?
Page: 1, 2, 3  Next
sled
sled is offline
PostPosted: Thu Jan 09, 2020 6:36 pm    Post subject: Interesting new rods, thoughts? Reply with quote
Never seen these before, seems like a new product release?
Lighter and stronger than H beam? That’s quite a claim, but could be an awesome rod to use if so!
Thoughts?
https://www.thesamba.com/vw/classifieds/detail.php?id=2342801
drive your split.
Alstrup
Alstrup is offline
PostPosted: Thu Jan 09, 2020 6:46 pm    Post subject: Re: Interesting new rods, thoughts? Reply with quote
As a rule of thumb an I beam rod is generally stronger than an H beam (not looking at bolts and caps) A strong I beam that is ligther than an average H beam,,,,,, interesting. Now we just need to get around the QC and the fact that maybe, just maybe that company has made a product that we dare put inside a high power engine.
Lightweight parts are always intriguing.
mcmscott
mcmscott is offline
PostPosted: Thu Jan 09, 2020 7:26 pm    Post subject: Re: Interesting new rods, thoughts? Reply with quote
5/16 bolts, thet should have did them with 3/8 and tried to compete with scat
There are no stupid questions, only stupid people,
68 Ghia
67 T-1
65 Notch
02 Mexican beetle
74 Thing
15 Long travel rail
07 Nomad
05 f-250
Clatter
Clatter is offline
PostPosted: Thu Jan 09, 2020 8:16 pm    Post subject: Re: Interesting new rods, thoughts? Reply with quote
You go first..
Bus Motor Build
It does not exist!
bugguy1967
bugguy1967 is offline
PostPosted: Thu Jan 09, 2020 8:27 pm    Post subject: Re: Interesting new rods, thoughts? Reply with quote
That doesn't look like it'll even be 50g lighter than their standard. I guess every bit helps, but this isn't groundbreaking.
We should be talking about Pauter's newer lightweight steel rods that weigh about 500g. Strength and comparable weight to a lot of titanium rods.
"A petrol engine can start readily, run smoothly and give every appearance of being in good order, without necessarily being in good tune." - Colin Campbell, "The Sportscar Engine"
sled
sled is offline
PostPosted: Thu Jan 09, 2020 8:49 pm    Post subject: Re: Interesting new rods, thoughts? Reply with quote
Link?
Cost?
drive your split.
vwracerdave
vwracerdave is offline
PostPosted: Thu Jan 09, 2020 8:59 pm    Post subject: Re: Interesting new rods, thoughts? Reply with quote
I won't even look at them for two years until they prove themselves. Somebody else can spend the money and be the crash test dummy.
I've never needed a 5.5" rod with VW journals.
slalombuggy
slalombuggy is offline
PostPosted: Thu Jan 09, 2020 9:52 pm    Post subject: Re: Interesting new rods, thoughts? Reply with quote
That rod looks a lot lighter. I've always found empi rods to be right on spec as far as machining and weights. I had to hone the small end on a set of scat rods I had in my first big engine, 2 were small.
We can talk about Pauters new rods but not many guys are going to stop up to the plate for a thousand dollar set of rods. I'm more interested in the 3D printed rods Nissan tuners are working with, will support 1100hp and weight 75grams each.
brad
jpaull
jpaull is offline
PostPosted: Thu Jan 09, 2020 10:28 pm    Post subject: Re: Interesting new rods, thoughts? Reply with quote
The piston pin oiling route is abit different. If thats not a issue, I wanna try some fo show
[email protected]
roy@mofoco.com is offline
PostPosted: Fri Jan 10, 2020 7:52 am    Post subject: Re: Interesting new rods, thoughts? Reply with quote
Thoughts?
I have been using these exact same rods but stock length for many years. Never had one problem. Dead on weight, and dead on measurements.
I've used a few of the 5.5 sets so far without any problems. I only use the 5.5's in 1914's because it makes setting the deck height and C/R much easier.
These rods from EMPI are very good. Again, I am building NA street motors under 200hp so that is all I can testify to for how they hold up.
I like them much better than the Kuhltech rods. The Kultech rods are also very good EXCEPT the tang grove for the bearing is too narrow and you have to grind and file on each rod bearing half or the rods will be tight.
Please "LIKE" us on facebook to see what we are working on.
https://www.facebook.com/mofoco?ref=ts&fref=ts
www.mofoco.com
Cylinder Head Reference Sheet
[email protected]
PostPosted: Fri Jan 10, 2020 8:00 am    Post subject: Re: Interesting new rods, thoughts? Reply with quote
$1000 set of connecting rods? That's almost as funny as people using $400 tool steel lifters in their 1776 street engine.
I will build an engine that will last longer with stock German connecting rods and Brazil lifters....
www.mofoco.com
Chickensoup
Chickensoup is offline
PostPosted: Fri Jan 10, 2020 8:05 am    Post subject: Re: Interesting new rods, thoughts? Reply with quote
I think this release a way for empi trying to prove that they really are improving their quality in products? If they keep going down this route we may not have to fear their products. But still, 1000 bucks isn’t worth it for me at least.
sled
sled is offline
PostPosted: Fri Jan 10, 2020 8:09 am    Post subject: Re: Interesting new rods, thoughts? Reply with quote
Ive never seen these rods before, but the doesn't mean they haven't been around. You sure you don't mean the regular I-beams everyone has been making for a while, like CB unitech, etc? I searched for Kuhltek rods that look like these, and all I found was regular I-beams on their website.
and yeah...I don't see how comparing pauter rods to these is fair, or even has a point? Tabari, do you have pauter rods in your engines?
I am not an empi advocate particularly, but I do find new products interesting.
drive your split.
_MidlifeCrisis_
_MidlifeCrisis_ is offline
These aren't $1,000 they're $260
Alstrup
Alstrup is offline
PostPosted: Fri Jan 10, 2020 8:11 am    Post subject: Re: Interesting new rods, thoughts? Reply with quote
Well, I/we must have been really unlucky then, since we have seen cracked rods (at the small end) after only 1500 miles, three times, and funny enough all engines from the same builder, oval big ends, too small big ends, too large big ends and wonky bolt seat areas. But yes, the weights were almost always good.
Chickensoup
PostPosted: Fri Jan 10, 2020 8:12 am    Post subject: Re: Interesting new rods, thoughts? Reply with quote
Should of clicked on the link.
slalombuggy
PostPosted: Fri Jan 10, 2020 9:07 am    Post subject: Re: Interesting new rods, thoughts? Reply with quote
AAAAAAAHHHHHHH FFS it's should HAVE.....HAVE NOT OF....HAVE clicked on the link
There, I finally said it, now I feel better, carry on...sorry Smile
brad
[email protected]
PostPosted: Fri Jan 10, 2020 10:04 am    Post subject: Re: Interesting new rods, thoughts? Reply with quote
Ha, ha......apparently I should have clicked on the link too Embarassed
I will amend my statements. I have used the standard I-Beam 5.4 and 5.5 rods from EMPI but not these new ones. All my statements and experience are with the standard I-Beam chromoly rods.
That being said, with my success using those rods, I wouldn't hesitate to try these as well.
www.mofoco.com
SBD
SBD is offline
PostPosted: Fri Jan 10, 2020 10:34 am    Post subject: Re: Interesting new rods, thoughts? Reply with quote
brad
Cool
"Just $99 down and $64 a month for 36 months buys you a brand new Volkswagen Beetle!"
mark tucker wrote:
I wouldent waste $ or thyme on building a small motor. build it big so it dosent have to work hard.remember it's only as fast as your foot alows it to be unless you build a small turd then it just stinks as it squishes up through your toes when you step on it.
TomSimon
TomSimon is offline
PostPosted: Fri Jan 10, 2020 1:59 pm    Post subject: Re: Interesting new rods, thoughts? Reply with quote
Clatter wrote:
You go first..
Laughing Laughing Laughing Laughing Laughing
2-time NASA Pro Racing Champion, Bonneville 130 Club and 150 Club Memeber, BRS Pro Gas racer
Page: 1, 2, 3  Next
