Bonesberg55 Samba Member
Posted: Thu Jul 30, 2020 4:07 am Post subject: NF Differential seals |
I have a 1977 010 automatic transaxle. I purchased a Transtar 010/087/089/090 master overhaul kit with the optional seals for the differential side. All of the transmission parts were correct, but none of the differential seals supplied matched. I contacted the vendor where I got the kit and they sent me a list of seals with descriptions which I used to order the correct seals. The replacement seals were identical to the first ones supplied so again, none fit. Is there something unique about the NF differential from other years? The torque converter seal has the correct ID, but the OD is too big. The output seals have the wrong ID, but the OD appears to be correct. Has anyone out there run into this problem?
SGKent  Samba Member
Joined: October 30, 2007 Posts: 42700 Location: at the beach
Posted: Thu Jul 30, 2020 6:50 am Post subject: Re: NF Differential seals |
go here, find the page with the parts you need, find the part, click on it, and get a part number then google the part number. See what is called for. Most likely trans seals will still be a valid part.
http://www.michaelknappmann.de/bulli/michaelk/vw_bus_d/fiche/t200100.html _________________ "Most people don't know what they're doing, and a lot of them are really good at it." - George Carlin |
Posted: Thu Jul 30, 2020 11:46 am Post subject: Re: NF Differential seals |
Thanks SGKent. I'd still like to know why Transtar & the vendor have the wrong info. |
SGKent  Samba Member
Posted: Thu Jul 30, 2020 11:55 am Post subject: Re: NF Differential seals |
Rich Latsch wrote: |
that would be a question for them. All we can do is point you to the correct ones. _________________ "Most people don't know what they're doing, and a lot of them are really good at it." - George Carlin |
kerian159 Samba Member
Joined: February 24, 2008 Posts: 344 Location: Pensacola, FL
Posted: Thu Jul 30, 2020 12:10 pm Post subject: Re: NF Differential seals |
090 or 010? _________________ 1976 Type II Westy P22
"Growing older, but not up!" |
ToolBox Samba Member
Joined: January 27, 2004 Posts: 3439 Location: Detroit, where they don't jack parts off my ride in the parking lot of the 7-11
Posted: Mon Aug 03, 2020 10:06 am Post subject: Re: NF Differential seals |
If you have your old seals go to your local bearing supply or seal supply and they will be able to set you up. |
Posted: Tue Aug 04, 2020 5:00 am Post subject: Re: NF Differential seals |
I did not want to remove the old seals if new ones were not available. However, since my original post, I used a high magnification glass to read the numbers on the seals. They are VW #s 003519089D and 018409399. I have procured those seals. |
