1977 Bay New dual carbs without vacuum line ports for the Servo
mwilkerson
mwilkerson is offline
PostPosted: Sat Sep 05, 2020 5:59 pm    Post subject: 1977 Bay New dual carbs without vacuum line ports for the Servo Reply with quote
I am putting in my 1977 VW Bus 2L some Weber 40 IDF dual carbs but when I was removing the old set of 34 ICT I noticed that there is a vacuum line running from the old manifold to the break Servo. The new 40 IDFs do not have the port for that vacuum line. I am not sure what to do with it can I just cap it off or will that totally defeat the purpose of the servo all together. Any ideas would be very appreciated.
old DKP driver
old DKP driver is offline
PostPosted: Sat Sep 05, 2020 6:21 pm    Post subject: Re: 1977 Bay New dual carbs without vacuum line ports for the Servo Reply with quote
Look at my pictures in my gallery. 40 idf carburetors from Spain and Italy
Have the ports.
Your choice without ports is to run a fully mechanical distributor
V.W.owner since 1967
busdaddy
busdaddy is offline
PostPosted: Sat Sep 05, 2020 6:23 pm    Post subject: Re: 1977 Bay New dual carbs without vacuum line ports for the Servo Reply with quote
Welcome!
Some of the answer depends on how strong your leg is, if it's not up to the task try reading some of the topics below to answer your question:
https://www.thesamba.com/vw/forum/search.php?searc..._chars=200
Слава Україні!
old DKP driver
PostPosted: Sat Sep 05, 2020 7:21 pm    Post subject: Re: 1977 Bay New dual carbs without vacuum line ports for the Servo Reply with quote
I misread your post
Manifold vacuum for your brake booster has nothing to do with your idf carbs.
Both intake manifolds Not carburetors supply that vacuum
Drilled and tapped and booster hose teed together.
Wildthings
Wildthings is offline
PostPosted: Sat Sep 05, 2020 8:33 pm    Post subject: Re: 1977 Bay New dual carbs without vacuum line ports for the Servo Reply with quote
Just get a shop to weld up a boss on each manifold (if there isn't already a boss there) and drill and tap if for a suitably sized pipe fitting.
Zed999
Zed999 is offline
PostPosted: Sun Sep 06, 2020 12:24 am    Post subject: Re: 1977 Bay New dual carbs without vacuum line ports for the Servo Reply with quote
Connection to one manifold is enough. A little less pipework that way.
Abscate
Abscate is offline
PostPosted: Sun Sep 06, 2020 3:41 am    Post subject: Re: 1977 Bay New dual carbs without vacuum line ports for the Servo Reply with quote
Drilling both manifolds is unnecessary and pointless.
