sbatie Samba Member
Posted: Sun Sep 06, 2020 11:54 am Post subject: Brake light problem: |
I have a 72 bus with no brake lights. The old brake light assembly was weathered and falling apart so my brake lights, tail lights and blinkers only worked half the time. The brake lights rarely worked. I just installed new tail light assembly on both the passenger and driver side. I now have blinkers and tail lights but nothing for brake lights. I can’t find a bad ground anywhere and don’t know where to look next.
Can someone give a list or place to start?
Thanks! |
Jeff Geisen Samba Chaplain
Joined: December 21, 2004 Posts: 1944 Location: N.W. Georgia
Posted: Sun Sep 06, 2020 12:05 pm Post subject: Re: Break light problem: |
Checking brake light function with the key on, right?
With the key on check for power at brake light switch at the master cylinder. If power there, jump the two wires together that connect to the switch and check for brake light action.
If no power at the switches, check for a fuse problem and for power at the fuse box. _________________ I Corinthians 4: 1 thru 5
‘63 ragtop - ‘68 single cab |
hazetguy Samba Member
Joined: April 06, 2001 Posts: 10804 Location: the past
original housings are wired slightly differently than (some/most/all?) replacement housings.
you often need to do minor modification to make things work.
how do you have yours wired?
also, make sure the bulbs are not corroded or worn out at the posts, and are making good contact with the terminals in the bulb holder. or just put new bulbs in.
original housing:
replacement housing:
