Heat riser insulation kit
butlern
butlern is offline
PostPosted: Sun Nov 01, 2020 4:36 am    Post subject: Heat riser insulation kit Reply with quote
Seems these are no longer sold. Asbestos the primary reason?
https://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=113119597
Any alternatives out there?
Thanks
Noah
1962 Ghia Cabriolet (why did I sell you?!)
1970 Ghia Coupe (glad I sold you)
1964 Ghia Coupe (I will never sell you!)
rbsurfguy
Location: Fairfax, Northern Virginia Formerly Huntington Beach, SoCal
rbsurfguy is offline
PostPosted: Sun Nov 01, 2020 8:13 am    Post subject: Re: Heat riser insulation kit Reply with quote
Since Wolfsburg West is in California, most likely. Look at the warnings on almost every part you see online, and it has the California warning that it may cause some abnormality....being from Cali, I have some idea!
There's got to be some alternative out there, hopefully someone here will advise.
Jeff
1971 Ghia convertible (Body off rebuild)
2019 VW Atlas 4Motion
2012 Passat-Sold
See my build on The Samba at:
Jeff's 71 Vert Restoration/Reassembly http://www.thesamba.com/vw/forum/viewtopic.php?t=6...highlight=
PostPosted: Sun Nov 01, 2020 9:05 am    Post subject: Re: Heat riser insulation kit Reply with quote
They are not asbestos and I read that page as them being out of stock, not removed from sale.
Maybe they are available from another source?
Try cip1.com
Edit: cip1.com is out of stock too
https://www2.cip1.com/ProductDetails.asp?ProductCode=VWC-113-119-597
If you google
MANIFOLD HEAT RISER INSULATION
Some other sites come up but they are in Europe
I don't know if there are other US sources at this time but try doing more searches...
