Mystery brown wire under dash
Pastelweis
Pastelweis is offline
PostPosted: Wed May 12, 2021 7:25 am    Post subject: Mystery brown wire under dash Reply with quote
Dear fellow Sambans,
Does anybody know what this brown wire under dash is for? Is it perhaps the answer to why my break signal is always on? (My breaks are just fine thank you) ... any suggestions greatly appreciated.
__________________________________________________
CURRENT
1975 VW Kombi Bus L90D [Stockholm, Sweden]
1979 Westfalia Deluxe L13A [Stockholm, Sweden]
1979 Westfalia Deluxe L13A [Pasadena, CA]
PAST
1989 Vanagon GL Camper LB3V
busdaddy
busdaddy is offline
PostPosted: Wed May 12, 2021 7:42 am    Post subject: Re: Mystery brown wire under dash Reply with quote
You'll have to find the other end and tell us what it's attached to, there lots of brown wires in that area.
Слава Україні!
kreemoweet
kreemoweet is offline
PostPosted: Wed May 12, 2021 9:27 am    Post subject: Re: Mystery brown wire under dash Reply with quote
Solid brown wires are mostly used for grounds to some connection on the body - but not always. The only
brown wire involved in brake stuff is the ground wire to the warning light, but that being disconnected
would just mean the light never comes on.
'67 bug: seized by the authorities
germansupplyscott
germansupplyscott is offline
PostPosted: Wed May 12, 2021 10:20 am    Post subject: Re: Mystery brown wire under dash Reply with quote
Kreemo has it?
With a .110" terminal, which is what it looks like, that is most likely supposed to be connected to the brake warning light. It could also be for the switch on the handbrake lever (which is also part of that warning light circuit) but I don't think a '75 has that switch.
SL
Anchovy
Anchovy is offline
PostPosted: Wed May 12, 2021 3:14 pm    Post subject: Re: Mystery brown wire under dash Reply with quote
As noted, likely the ground wire for the brake warning light. See here:
https://www.thesamba.com/vw/forum/viewtopic.php?p=3115325&highlight=#3115325
