motor locked up
madmike
madmike is offline
PostPosted: Fri Jun 25, 2021 4:51 am    Post subject: motor locked up Reply with quote
Here one for the engine builders, specs are:
2074cc
5.5 Heams
fk 8 w 1:4's
044 heads , turned over with about 2 fingers ,so no pinched bearings,,
I had this on my test stand with oil in it and 'turned over repeatedly w/starter"
then decided to sell the deep sump off it Rolling Eyes now it won't turn over CLOCKWISE ,,only backward counterclockwise Embarassed WTF? I'm tearing it down Mad Maybe a chipmunk got an acorn stuck in there???
'Black Ice'Drag Buggy 'Turbo'
Rail Buggy 1915 turbo
"If I'm ever on Life Support,UNPLUG Me, Then Plug me back In see if that Works"
busdaddy
busdaddy is offline
PostPosted: Fri Jun 25, 2021 8:21 am    Post subject: Re: motor locked up Reply with quote
Is there a distributor in it?
Слава Україні!
madmike
madmike is offline
PostPosted: Fri Jun 25, 2021 8:29 am    Post subject: Re: motor locked up Reply with quote
Ha ,1st thing I checked Wink , pulled dizzy,, then the drive gear,, same , pulled the cover off the pump too,, then slid the pump out a bit ,,SAME DAMN THING Confused tanking a break,,,,,,,
evanfrucht
evanfrucht is offline
PostPosted: Fri Jun 25, 2021 8:52 am    Post subject: Re: motor locked up Reply with quote
Is it fully stuck or does it move slightly and then hit something?
Pickup tube thing got twisted around when you yanked out that sump? Think
Did you leave the ratchet on the crank pulley? Laughing just kidding
1967 Bug ( the daily rod )
1964 Fury Wagon ( the pavement shredder )
74 Thing
74 Thing is offline
PostPosted: Fri Jun 25, 2021 9:51 am    Post subject: Re: motor locked up Reply with quote
Did you take the rockers and pushrods out?
I am assuming the flywheel is on and torqued to spec with correct endplay.
mark tucker
mark tucker is offline
PostPosted: Fri Jun 25, 2021 9:55 am    Post subject: Re: motor locked up Reply with quote
I would think something in the gear housing thats acting like a ratshit letting it rotate one way but not the other. have you fliped the engine around? was there a nut or somethen on a sump stud that came loose like the puckup sttd nut and it's posiably doing that to the crank agnist the case? have you asked your chip monk?
madmike
madmike is offline
PostPosted: Fri Jun 25, 2021 11:24 am    Post subject: Re: motor locked up Reply with quote
Funny thing is it turns over backasswards ,then turn the right way and it only goes a 1/4-1/2" and stops
pulled the rockers & heads right after fuckin with the dizzy Rolling Eyes
siding with Mark on this Chip Or Dale ? Laughing
madmike
madmike is offline
PostPosted: Sat Jun 26, 2021 8:00 am    Post subject: Re: motor locked up Reply with quote
"ALVIN" Rolling Eyes Embarassed Shocked Laughing
RWK
RWK is offline
PostPosted: Sat Jun 26, 2021 8:06 am    Post subject: Re: motor locked up Reply with quote
Come on Mike,Chipmunks store there nuts in the fall, here in MI, looks like a Mike stud!
73 Type 181
63 Type 113
63 Type 261- 428 071
62 Type 241-378 025 178 530
mark tucker
PostPosted: Sat Jun 26, 2021 8:36 am    Post subject: Re: motor locked up Reply with quote
yup that will do it. one of the chip&dale studs took up residence there trying to get geared up for a hot summer stripping off threads.
txoval
txoval is offline
PostPosted: Sat Jun 26, 2021 8:47 am    Post subject: Re: motor locked up Reply with quote
That definitely sucks
67rustavenger
67rustavenger is offline
PostPosted: Sat Jun 26, 2021 8:53 am    Post subject: Re: motor locked up Reply with quote
Well there's your problem, right there! Very Happy
Curious where that stud came from and how it got there.
Oh, and I dropped a FP stud into the obis a few years ago. It was the last fastener I needed to install to complete the build.
Got to do the build all over as the stud was lodged behind the cam gear. Shocked
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
busdaddy
busdaddy is offline
PostPosted: Sat Jun 26, 2021 9:04 am    Post subject: Re: motor locked up Reply with quote
Sooooo much better to find that now, opposed to at speed during break in. Cool
Слава Україні!
madmike
madmike is offline
PostPosted: Sat Jun 26, 2021 9:14 am    Post subject: Re: motor locked up Reply with quote
and nobody caught that defector is bassackwards Laughing
probably won't matter I run sand seals Wink
Yea I probably had a stud finger started and removed the turbo drain Embarassed Rolling Eyes ,can I use a stock 3 bolt 'flat'cam gear on my engel??
I chipped a cpl. teeth on this one Crying or Very sad
txoval
txoval is offline
PostPosted: Sat Jun 26, 2021 9:20 am    Post subject: Re: motor locked up Reply with quote
It will fit, but need to check gear lash
Xevin Premium Member
Xevin is offline
PostPosted: Sat Jun 26, 2021 9:24 am    Post subject: Re: motor locked up Reply with quote
Brilliant Applause Applause Applause
Keep on Busin'
67rustavenger wrote:
Clatter wrote:
skills@eurocarsplus wrote:
SGKent wrote:
chrisflstf
chrisflstf is offline
PostPosted: Sat Jun 26, 2021 9:38 am    Post subject: Re: motor locked up Reply with quote
So what exactly happened? How did that stud get there?
madmike
madmike is offline
PostPosted: Sat Jun 26, 2021 9:50 am    Post subject: Re: motor locked up Reply with quote
Embarassed Embarassed I had started the stud with fingertorque, was mocking up the turbo ,flipped the motor to remove the sump : Manure Occureth Rolling Eyes
evanfrucht
PostPosted: Sat Jun 26, 2021 1:50 pm    Post subject: Re: motor locked up Reply with quote
Keep up the good work Laughing Applause You almost made me shit my pants this morning with that one... good thing I was only on my first cup Cool
toxicavenger70
toxicavenger70 is offline
PostPosted: Mon Jun 28, 2021 2:25 pm    Post subject: Re: motor locked up Reply with quote
hahahaha
