Chickensoup Samba Member
Joined: January 06, 2018 Posts: 5395 Location: Good Hope, GA
Posted: Wed Jul 14, 2021 4:55 pm Post subject: stumped on choosing paint brand/line |
Hi yall, im feeling a bit lazy so imma just paste from my other thread. thought it would be better here anyways. thanks
"Warning! blabering ahead!
no updates or progress to be posted. school starts up soon and by the time i get back home all ill have time for is just cleaning up the shop and fixing a few things on my passat.
I havent been thinking much about the car lately to be honest, but ive made the shopping cart for rubber seals for the body, the heater channel, headlight hardware, etc. meaning, once i finish the body work, i need to prepared for paint.
I know what type of paint and color i want. base coat clear coat, porsche aquamarine blue non metallic.
Ive already got the gun (decent HVLP), giant air compressor, filter, and then the small consumables pieces imma just have to buy later. And for the icing on the cake, ive got access to a friends paint booth. just need to help him seal the bottoms of the side panels.
ok enough w/ the boring stuff. I did decide to write today, because i have a question.
I will be laying down the paint myself which saves some money of course, but i would like to find a middle of the road quality paint line that doesnt coast a kidney and my wee wee.
let me help you to help me. im rhino coating the underside of my car, engine compartment, trunk, fire wall, and luggage tray. So i wont be using as much paint as usual.
like i said im wanting to do a basecoat clearcoat system. How many gallons should i need of each?
Primer?
sealer?
Top coat?
clear coat?
what kinds of paint are the upper class car brands using these days? any suggestions would be much appreciated.
thanks" _________________ -'85 c10 5.3 LS, cam, heads, long tubes, x pipe, 3 inch spin tech's
-'01 e46 325ci *tree modded
'65 Tourist Delivery Build
'66 RIP |
67ctbug Samba Member
Posted: Fri Jul 16, 2021 9:51 am Post subject: Re: stumped on choosing paint brand/line |
Hahaha upper class car brands, it’s all junk paint the cheaper the paint they use, the more profit they make. I’ve read recently that some OEMs are even using 1K non activated clear coats now and just baking them. They don’t paint under the car, they don’t paint the trunks, they barely paint under the hoods and lids. I wouldn’t buy any paint until you finish bodywork, but I’ll break it down for you. I’d count at least a gallon of primer. Then inside and out, maybe 1-2 gallons of base. I used 2 gallons of single stage on mine inside and out. Sealer is optional, some guys use it some don’t. It’s an extra opportunity for dirt and orange peel. Your last coat is only as good as the ones before it. Clear coat probably 1-1.5 gallons. Paint goes up every year. Cheap paint is cheap paint. It’s thin, color match may not be 100%. I’ve heard good things about Tamco, I like Limco, I uses RM Diamont at work but that’s $$$$. PPG Omni is like water but gets it done after enough coats. But like I said, do the bodywork first, and when you’re done with the plastic work, put a polyester glaze over it to eliminate the pinholes. _________________ '67 Beetle L41
'74 Westfalia
'69 Plymouth "Adam-12"
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
World Series Champions 2016
| KentPS wrote: |
...or the PO envied the terrorists' bus in "Back to the Future".  |
| mukluk wrote: |
| He's fine, just waiting for the dragon in winklepickers to move out of his lane. |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 18054 Location: Eugene, OR
Posted: Fri Jul 16, 2021 1:03 pm Post subject: Re: stumped on choosing paint brand/line |
Buy everything at your local Paint Supplies, so you can do test sprays to check your color & technique. _________________ 69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Posted: Fri Jul 16, 2021 7:47 pm Post subject: Re: stumped on choosing paint brand/line |
Yeah what Mike said, and be friendly with them and they might give you stuff if they're feeling generous. _________________ '67 Beetle L41
'74 Westfalia
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
| KentPS wrote: |
| mukluk wrote: |
Braukuche Samba Member
Posted: Fri Jul 16, 2021 8:20 pm Post subject: Re: stumped on choosing paint brand/line |
I like TCP Global Restoration Shop line single stage. It’s about the same price as Omni but much better quality. Coverage is much better, has more depth to it. _________________ Go Reds! Smash state!
Retirement is here!
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now
1989 Westfalia |
2type2 Samba Member
Joined: June 02, 2002 Posts: 1219 Location: SW Colorado
Posted: Sat Jul 17, 2021 4:11 am Post subject: Re: stumped on choosing paint brand/line |
My .02 says go with TPC also. Clearcoat isn't for old cars. _________________ "A life of peace and happiness depends on your own gratefulness" |
evanfrucht Samba Member
Joined: July 24, 2016 Posts: 2186 Location: Laurel Canyon, CA
Posted: Sat Jul 17, 2021 1:01 pm Post subject: Re: stumped on choosing paint brand/line |
I'm late to the game but this is a no brainer
I highly advice you do NOT use base/clear! Single stage will look better and age better. Ok, I said my piece there... I'll move on.
SPI brand EPOXY PRIMER, and their 2k is also good as a filler primer. Their 2k high build is extremely high build, and not neccesary in my book. They are a small family run company and you get free next day shipping if you order through them or any of their suppliers. Check the rest of the internet. Everyone loves SPI Epoxy, it has raving reviews all over. It's very affordable too, prices are on website https://www.southernpolyurethanes.com/epoxy-primer
I use Evercoat Rage gold as my filler of choice, when needed. 3M Platinum/Plus line is another decent option.
Paint. I would never use base/clear on a vintage car, or any metallic other than original. I prefer single stage paint. So, if I was on a budget I would shoot it with TCP Global Restoration Shop series single stage urethane.
Their are slightly better options for more money but honestly the TCP global stuff shoots and looks really nice. Very full of color, high solids content, you don't need to shoot half a dozen coats like other really cheap watered down brands.
I've also had good luck with Valspar TB550 2K industrial polyurethane.
Any quality caltalized urethane should work well.
If you want a fancier metallic or candy type thing House of Kolor is well regarded and not super expensive.
A gallon of each is more than enough to shoot a whole Bug twice. _________________ 1967 Bug ( the daily rod )
1964 Fury Wagon ( the pavement shredder ) |
Posted: Sat Jul 17, 2021 2:55 pm Post subject: Re: stumped on choosing paint brand/line |
I see... ok, so maybe single stage is a better option. Everyone seems to say so. I thought 2 stage would be better being that's all that's used on new cars these days but I learned it's mainly because of the voc issues and the epa regulations.
I still cant find a bad review on tamco. Heres what I'm thinking.
And then I'm not sure how much better the second option is. Twice as much and used in salt water.
'66 RIP |
Posted: Sat Jul 17, 2021 4:10 pm Post subject: Re: stumped on choosing paint brand/line |
If I was going with them I'd get their "DTA Epoxy" and "Duraflint II Single Stage" and have them make the color you want. If you are unsure and want to spend less money then check out SPI Epoxy and TCP Restoration Shop line in SS urethane.
One thing I really like about the SPI is it's very nice to sand and has a high solid content so it acts as a bit like a filler primer when you spray it on thick. Or you can use it as a DTM sealer too. I know that from first hand experience but can't say what the Tamco will behave like.
That's all you should need but get some filler too. You want a good filler so it's easy to sand, feather out, block out roof and doors and such. I like the Rage Ultra. You'll want a gallon of that, 95% will end up as dust on the floor.
Also get some of the nice reusable made in USA metal filler spreaders. They make extra wide ones which are good if your are actually doing a whole car, which you are.
Start collecting an assortment of different body hammers and dollys if you haven't already
Have fun! _________________ 1967 Bug ( the daily rod )
Joined: January 01, 2007 Posts: 17977 Location: sticksville, ct.
Posted: Sat Jul 17, 2021 7:41 pm Post subject: Re: stumped on choosing paint brand/line |
buy cheap paint then buy expensive paint. let me know which works out better.
single stage takes FOREVER to dry if you can't bake it. you can literally handle base/clear in an hour.
cheap paint once reduced for spaying has shit coverage..so you'll use more of it than you would a good paint.
i was a dupont chroma guy forever.... then found sikkens/akzo nobel. the difference was night and day
i'll never use cheap paint again. _________________
| gprudenciop wrote: |
| Jake Raby wrote: |
| Thanks for the correction. I used to be a nice guy, then I ruined it by exposing myself to the public. |
| Brian wrote: |
| Also the fact that people are agreeing with Skills, it's a turn of events for samba history |
Posted: Sat Jul 17, 2021 8:06 pm Post subject: Re: stumped on choosing paint brand/line |
| skills@eurocarsplus wrote: |
i'll never use cheap paint again. |
You do get what you pay for and I agree Akzo Nobel products are top notch, or Glassurit if you want to get super fancy and period correct... but there is some good budget single stage out there too. The TCP global restoration shop line and a couple of the other budget lines actually shoot nice and look good for years. Like I said before you can get full coverage in 2 coats with that cheap paint. I've tried others budget brands that have shit coverage compared to it... those are basically unusable... Its like the paint is candy or translucent it's a joke. The stuff I reccomended is not like that at all.
Your base/clear dries fast because it is a "production" type also sometimes referred to as a euro clear. It's meant to dry fast to keep production fast in a setting where that is the priority... and things need to get sanded, polished, handled, out the door fast. It's actually worse for durability and pretty much everything else. I wouldn't use that stuff for a personal project.
Also the various single stage I use does not take forever to dry. It's basically a high quality urethane clear coat with toner, why would it be different? Not sure what you use that takes forever. All the single stage I've tried is dry to the touch next day or less and fully cured within a week or so. Patience is key. For a paint job he will do oncr himself the dry time is very low on the list of priorities IMO.
Only benefit to base/clear is it's easier to shoot and less fussy. You can shoot the color over and over till you get it right... you don't have to really try that hard and it turns out like it's supposed to, easier to fix runs or dry spray or whatever, etc.
Single stage looks a million times better, it's not even a comparison. _________________ 1967 Bug ( the daily rod )
Posted: Mon Jul 19, 2021 9:53 am Post subject: Re: stumped on choosing paint brand/line |
I would dare say that clear coat is just clear single stage  _________________ '67 Beetle L41
'74 Westfalia
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
| KentPS wrote: |
| mukluk wrote: |
Posted: Mon Jul 19, 2021 11:10 am Post subject: Re: stumped on choosing paint brand/line |
| evanfrucht wrote: |
Single stage looks a million times better, it's not even a comparison. |
we can agree to disagree on that.
SS has its place for sure.
a home garage with no dust control.... not worth the decade you'll spend nibbing out the junk.
i use SS on occasion. i would much rather use b/c
even applying SS takes way more time due to flash times. pork it on too hard and fast then it's drips, sags and solvent pop. _________________
| Jake Raby wrote: |
| Brian wrote: |
Posted: Mon Jul 19, 2021 3:34 pm Post subject: Re: stumped on choosing paint brand/line |
| evanfrucht wrote: |
even applying SS takes way more time due to flash times. pork it on too hard and fast then it's drips, sags and solvent pop. |
Same will happen with clear if you spray heavy.
I wouldn’t say base or SS is better or worse, I use SS because I only paint vintage VWs and Porsches and to my eye it has a similar depth of shine as original. It also ages well if your goal is for the car to acquire natural patina from use and exposure vs having a cloistered museum piece. It’s all what your goal is. _________________ Go Reds! Smash state!
Retirement is here!
1960 double cab
1960 Baja Bug
1963 356 B coupe
1963 Notchback
1989 Westfalia |
Posted: Mon Jul 19, 2021 8:06 pm Post subject: Re: stumped on choosing paint brand/line |
thanks for the help guys. ive decided on going with the tamco duraflint 2 SS. just got a price and or a gallon kit of color, its only 300 and something shipped. and 240 ish if you want black, white, or red.
the car will be taken down to bare metal. should i use DTM? or is DTA still appropriate?
thanks _________________ -'85 c10 5.3 LS, cam, heads, long tubes, x pipe, 3 inch spin tech's
'66 RIP |
Evil_Fiz Samba Member
Joined: May 06, 2011 Posts: 1113 Location: Jacksonville, FL
Posted: Wed Jul 21, 2021 3:43 pm Post subject: Re: stumped on choosing paint brand/line |
| Chickensoup wrote: |
thanks |
If you are going down to bare metal, and won't be treating the car with Phosphoric acid, SPI Epoxy is your best option (SPI will delaminate over improperly neutralized acid). It is highly regarded, well priced, and has a huge support community. Check out the SPI user forums for more info on auto paint and painting than you will ever be able to fully process. (http://www.spiuserforum.com/index.php) If you call their tech line you will most likely get Barry, the owner, on the phone.
Here is a link to an article on the SPI site that may be useful.
The Perfect Paint Job:
http://www.spiuserforum.com/index.php?threads/perfect-paint-job.6286/post-66965
This link covers alternative budget paint companies.
What's a good basecoat to use nowadays:
http://www.spiuserforum.com/index.php?threads/whats-a-good-basecoat-to-use-nowadays.7899/
And another.
The proper way to wipe down a vehicle:
http://www.spiuserforum.com/index.php?threads/the-...aint.6622/
Another option is to use Master Series Silver over bare metal. That is the option I am following because I DID treat the metal with Phosphoric acid before I knew about the SPI epoxy. Here is information I got directly from vwsplitman (Samba member who sells and uses Master Series products) about what is needed to paint a VW with MS Silver and AG-111:
"Here is some info on the MasterSeries questions you have:
If you are doing the entire inside of a Ghia , you will need more than the 2 quarts of silver primer. We recommend 2 coats of the silver primer, then topcoating with another paint. If just using the silver alone, 3 coats is recommended. Given that, I would say you need a couple more cans of the silver MasterSeries. Pretty much all of the work I do I try to spray on the coatings. Both the AG111 and silver primer, I thin with urethane reducer about 15 percent, and spray it out of a cheap Harbor Freight $14 spray gun. I sandblast the items, or sometimes the entire car and chassis, then spray on the MS. Two coats of the silver, then seam sealer if needed, then the AG111 topcoat when doing the chassis. When I do the body of the car, I sandblast everything, apply the 2 coats of silver primer, then seam sealer. Then it goes to the paint shop where they apply filler on top of the MS silver primer as needed. Then they scuff the entire body, apply Dupont products gray .
primer and proceed to apply single stage Dupont products.
i have a friend that works on VWs of his own in the St Augustine area and he sprays the MasterSeries products on a regular basis. You need to pick the lower humidity days if possible and you might have to wait until the humidity tapers down a little where you live.
When you open those cans, mix the product , pour it off, and return the lids to the cans asap. Should last in the can a few weeks. Remember the more you open and close the can, the more moisture and air get introduced into the paint , and the quicker it will set up. The AG111 can be used in small batches. Just mix 2 parts of paint to one part of hardener. It can be 2 spoonfuls of paint(part a) to 1 spoon of hardener(partB). Or if you use a measuring cup, 2 ounces of A to 1 ounce of B. Once you mix the two parts together you have a pot life of about 6 hours before it starts hardening.
Your prep process sounds OK. The metal prep we sell, you apply it with a rag , sponge, hand sprayer. Then within a few minutes wipe it with a clean rag or paper towel. Then let it dry for most of the day. Then the next day ready for paint. Our stuff doesnt require washing it off. Read the directions on what products you are using for best results. Hopefully I have answered some of your questions. Thanks for using our products. Chuck"
"My Harbor Freight gun has a tip that is 1.4 and that has worked fine for the silver primer, thinned 15%. Now the AG111 is a thicker paint, but if you have a 1.8 tip , which is a primer gun size tip, that should work OK. Once again thin the paint 15%. If it still doesnt want to work, go a little more on the urethane reducer. I wouldnt recommend on drilling out the tip. I think it might be an easy way to screw up a gun. Chuck"
I hope this helps
Emil _________________ “…It's not just about what's interesting. It's also about what's helpful, and it's helpful even if it helps just one other guy working on a Ghia.”
kiwighia68
See my build on TheSamba at:
The K_R_A_K_E_N_N : a 70 Ghia Convertible reinterpreted |
Posted: Wed Jul 21, 2021 4:45 pm Post subject: Re: stumped on choosing paint brand/line |
Awesome thanks for the tips! I will check out spi epoxy. The cleaning tips are especially helpful. I've used master series before. I used it on my chassis. The stuff cures FAST. I haven't shot it but foam brushing it was a real big pain. Didn't go on smooth and took forever.
Everyone has told me prep it everything. Bondo will only be used for skim coat. Im leaning towards the spi epoxy or tamco dta. Car will be taken down to bare metal 100 percent.
Thanks for the links! _________________ -'85 c10 5.3 LS, cam, heads, long tubes, x pipe, 3 inch spin tech's
'66 RIP |
