Rafo67PE Samba Member
Posted: Wed Mar 30, 2022 2:01 pm Post subject: Steve Tims Stage II -webcam 86c |
Hi
I am finishing my new engine 2276 94*82 5.5 rods, 10.1:1 CR webcam 86C 1.4 rockers Steve Tims Stage II (650 springs) , weber 48 IDF with Berg venturies , A1 1 5/8 sidewinder
Anyone has any expirience with Steve Tims' stage II heads and web 86C combo? |
Paul.H Samba Member
Posted: Wed Mar 30, 2022 2:35 pm Post subject: Re: Steve Tims Stage II -webcam 86c |
That's a race engine with small heads |
DerrickfromNC1 Samba Member
Joined: October 24, 2008 Posts: 1394 Location: North Carolina
Posted: Wed Mar 30, 2022 2:38 pm Post subject: Re: Steve Tims Stage II -webcam 86c |
Rafo67PE wrote: |
Hi
No real world experience but from reading here I believe the Tims stage II would be a better match with the 86b. If you want to stay with the 86c consider the CB wedgeports or better. |
Posted: Wed Mar 30, 2022 3:29 pm Post subject: Re: Steve Tims Stage II -webcam 86c |
I forgot to mention that the engine is for my bug. Street use (some weekends only) |
Ohio Tom Samba Member
Joined: February 09, 2006 Posts: 1662 Location: Marshallville Ohio
Posted: Wed Mar 30, 2022 4:10 pm Post subject: Re: Steve Tims Stage II -webcam 86c |
It will work. Perhaps not as much mid-range with the C cam. We found the C has a big hole in the midrange over the B.
Top end will be limited by head flow.
The C is a big cam. Yes, back in the day, they put really big cams in small port/valve heads.
It was the best thing they could do with what they had. The motor will have a strong, but narrow power band. 4,000-6,500. Can your gears handle that??
Are you OK with waiting for 4,000rpm to get on power? |
evanfrucht Samba Member
Joined: July 24, 2016 Posts: 2186 Location: Laurel Canyon, CA
Posted: Wed Mar 30, 2022 4:15 pm Post subject: Re: Steve Tims Stage II -webcam 86c |
I might bump up the compression to 10.5 or so, OR change the cam to an 86B. You might like it better for a strictly street driver, more usable power under around 2500 rpm.
The 86C is starting to get into race territory, high rpm power at the expense of less low end. It may feel sluggish when you are out of the power band.
To take advantage of the 86C, you might be better off with different heads. They don't need to be that much bigger, as since you say this is a street car max HP is not the priority.
I think it could work for you as is. Whether it is the best choice tho really depends on your style of driving and how much you are potentially willing or able to change plans to suite. _________________ 1967 Bug ( the daily rod )
1964 Fury Wagon ( the pavement shredder ) |
Posted: Wed Mar 30, 2022 4:19 pm Post subject: Re: Steve Tims Stage II -webcam 86c |
Ohio Tom wrote: |
1st and 2nd stock. 3rd 1.42 4th 1.04 4,12RC |
Posted: Wed Mar 30, 2022 4:31 pm Post subject: Re: Steve Tims Stage II -webcam 86c |
Ohio Tom wrote: |
I expect the power band start at 3000 or 3500 rpm.for me it would be fine |
74 Thing Samba Member
Posted: Wed Mar 30, 2022 4:53 pm Post subject: Re: Steve Tims Stage II -webcam 86c |
Run it and report back |
Posted: Wed Mar 30, 2022 5:07 pm Post subject: Re: Steve Tims Stage II -webcam 86c |
evanfrucht wrote: |
I think it could work for you as is. Whether it is the best choice tho really depends on your style of driving and how much you are potentially willing or able to change plans to suite. |
I agree that with the 86c I am at the limit.
I'll advance it two degrees and run it |
Dan Ruddock Samba Member
Joined: October 25, 2012 Posts: 3668 Location: Sarasota, in my adopted state of Florida
Posted: Wed Mar 30, 2022 7:18 pm Post subject: Re: Steve Tims Stage II -webcam 86c |
Maybe a 86b+3 if you can find one, I am all sold out. |
UK Luke 72 Samba Member
Joined: September 07, 2011 Posts: 2875 Location: Little Britain
Alstrup Samba Member
Joined: July 12, 2007 Posts: 7786 Location: Videbaek Denmark
Posted: Thu Mar 31, 2022 12:40 am Post subject: Re: Steve Tims Stage II -webcam 86c |
Been there done that. With 11-1 cr and premium fuel. With the smmallerports and relatively long header primaries the power comes in sooner, like around 3500. We replaced the muffler with one that has a better layout (in our opinion) That really helped the performance off cam and also helped the engine pul better peak power and a wider torque band. _________________ https://www.thesamba.com/vw/forum/viewtopic.php?t=435993 |
