Timing with Degree Pulley - Questions
Craigbro
Craigbro is offline
PostPosted: Sat Apr 02, 2022 3:38 pm    Post subject: Timing with Degree Pulley - Questions Reply with quote
So just getting my engine installed after replacing seals, pushrod tubes, etc.
I have adjusted points and valves and looking to check timing.
I have a old school timing gun so no advance. I did static timing to get started.
I have a pully with degree markings and used this to set the valves.
So the questions-
When I start the engine and check timing I get about 29 degrees at idle. I idle up to 3000 and get around 50 degrees. These are rough numbers.
I'm guessing that with an timing gun with advance the 29 would read zero like it should?
What should I read idling at 3000? How does the math work?
Never did this before, just been reading. Is there another way that I should be doing this?
c21darrel
c21darrel is offline
PostPosted: Sat Apr 02, 2022 4:24 pm    Post subject: Re: Timing with Degree Pulley - Questions Reply with quote
I use mechanical 010 distributor so at 3000 rpm I get 30 degrees total advance. Mech or vacuum distrib? they are done differently i believe.
GhiaBuild
1967 DC build
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Sat Apr 02, 2022 4:27 pm    Post subject: Re: Timing with Degree Pulley - Questions Reply with quote
Mechanical only, set 28-32º BTDC @ 3500rpm
Vacuum/mechanical, remove the vacuum line, plug the port on the carb, then set to 28-32º BTDC @ 3500rpm
Vacuum only, remove the vacuum line, plug the port on the carb, set to 7/5º BTDC @ 800rpm
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
NoDents
NoDents is offline
PostPosted: Sat Apr 02, 2022 5:10 pm    Post subject: Re: Timing with Degree Pulley - Questions Reply with quote
NEVER GO OVER 32 at any RPM.
No Dents
1963 Bug - Sold in 1980
1966 Karmann Ghia Convertible - Stolen in 1988
1971 Karmann Ghia Convertible, resto/mod COMPLETED 10/2020
Craigbro
Craigbro is offline
PostPosted: Sat Apr 02, 2022 6:53 pm    Post subject: Re: Timing with Degree Pulley - Questions Reply with quote
Glenn wrote:
Mechanical only, set 28-32* BTDC @ 3500rpm
Vacuum/mechanical, remove the vacuum line, plug the port on the carb, then set to 28-32* BTDC @ 3500rpm
Vacuum only, remove the vacuum line, plug the port on the carb, set to 7/5* BTDC @ 800rpm
Alright, so its a Mechanical distributor (0 231 178 009 JF 4) no vacuum line so set at 28-32 BTDC @3500. I will take a look tomorrow and report back.
Thanks for the replies!
Craigbro
Craigbro is offline
PostPosted: Sun Apr 03, 2022 11:03 am    Post subject: Re: Timing with Degree Pulley - Questions Reply with quote
Alright, think I'm on the right track. Not sure why the readings were so off yesterday but I believe everything looks more normal today.
With the static timing I was idling around 12 and mid 30s at 3500. I lowered it at idle to 7.5 and at 3500 its right at 30.
Looking at the degrees while timing I'm looking at the markings to the right of TDC. To clarify, this is correct?
runamoc Premium Member
runamoc is offline
PostPosted: Mon Apr 04, 2022 8:18 am    Post subject: Re: Timing with Degree Pulley - Questions Reply with quote
The setting you choose will depend on the octane of the gas you use.
Daily driver: '69 Baja owned 45 yrs - Plan B: '72 Ghia
Yard Art: 2 Sandrails
Outback: '69 Ghia - '68,'69,'70,'72 Beetle - '84 Scirocco, GTI - Pair of '02 Golfs- '80 Rabbit Diesel
VW Wiring = It's just wires
Tom K.
Tom K. is offline
PostPosted: Mon Apr 04, 2022 9:15 am    Post subject: Re: Timing with Degree Pulley - Questions Reply with quote
Yes, your timing light will illuminate a mark on your pulley that is to the right of TDC. Your timing now looks good based on your latest numbers.
'91 Vanagon Westfalia
'70 Beetle Convertible
'71 Super Beetle Semi-Automatic: https://www.thesamba.com/vw/forum/viewtopic.php?t=714131&highlight=
'65 Ghia: https://www.thesamba.com/vw/forum/viewtopic.php?t=762478&highlight=
