chuckpolzin Samba Member
Joined: March 14, 2022 Posts: 147 Location: Wisconsin, USA
Posted: Mon Jun 20, 2022 6:29 am Post subject: pertronix lubrication |
hey guys, thinking about putting in a pertronix svda in my 79 westy carb conversion.
Aircooled suggests disassembly and lube of the new units but i do not see any documentation in their manuals etc about where the lube points and what grease or oil to use would be.
Does anyone have any write ups or images etc of how to properly disassemble and lube one of these dizzys?
Thanks. |
Posted: Mon Jun 20, 2022 7:09 am Post subject: Re: pertronix lubrication |
| You should read up on the Pertronix distributor. I tried that route 15'ish years ago, had multiple problems right out of the box and failures started in the dozens of miles. I ended up going back to my old distributor. |
badufay Samba Member
Joined: December 13, 2010 Posts: 376 Location: Olympia, WA
Posted: Mon Jun 20, 2022 8:55 am Post subject: Re: pertronix lubrication |
I’m sure this thread will turn into points vs pertronix… blah blah blah, but to answer your question…. Simply lube the vacuum advance plate and the springs and you’ll be fine. Ive seen a few Pertronix distributors and was impressed with their steady timing.
Ben _________________ Current: 2023 ID.4 Pro S, 2020 Golf TSi 1.4L, 2017 GTI S, 6 spd man, 76 Bus, 2.0L- 3 spd auto
Previous: 2015 Golf S TDI, 6 spd man; 2015 Jetta SE TDI, 6 spd man; 12 Jetta 2.5L, 04 Jetta 2.0L, 02 Golf 2.0L, 98 Jetta 2.0L, 98 Golf 2.0L, 98 Cabrio 2.0L, 95 Golf 2.0L, 87 golf GTI 16 valve 1.8L, 86 Cabriolet 1.6L, 80 Audi 4000 1.6L, 76 Audi Fox 1.6L, 76 VW Beetle 1.6L, 74 Audi Fox 1.5L, 69 VW Beetle 1.5L |
Posted: Mon Jun 20, 2022 10:33 am Post subject: Re: pertronix lubrication |
| any thoughts on staying with pure mechanical whether points or electronic or do i really need a svda for this type 4 2.0 motor with dual weber icts? right now it is just a 009 clone pure mechanical |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 80318 Location: Sneaking up behind you
