Alternator stand stripped bolt
crankbait09
crankbait09 is offline
PostPosted: Mon Oct 10, 2022 4:10 pm    Post subject: Alternator stand stripped bolt Reply with quote
At the base of my alternator stand, the previous owner(s) have removed the original engine stud , and put an M8 bolt in it's place. The other 3 engine studs are fine and I can place nuts on them as needed. The bolt will not tighten into the threaded hole. It will only get so far before it pops loose again. I removed the bolt and the alternator stand and attempted to clean the threads in the hole, hoping that would fix the problem. not so much. What is the next best option? I have heard negative and positive reviews on the helicoil, but a lot of negative. I'm not sure the best way to fix this. Fix the hole, or buy a stud to return the set up back to the normal nut configuration.
I'm a little nervous about drilling into the case for this but I don't think I have any other option. Here is the current set up, you can see the bolt. Right now I have iut sitting in the hole, it goes in a little further before stripping.
1963 Ragtop
FarmerBill Premium Member
FarmerBill is offline
PostPosted: Mon Oct 10, 2022 4:23 pm    Post subject: Re: Alternator stand stripped bolt Reply with quote
If you don't want to use a heli-coil you can probably get away with using a stepped stud. Just tap the stripped hole the next size up and install an appropriately sized stepped stud. McMaster/Carr probably has just what you need.
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Mon Oct 10, 2022 4:26 pm    Post subject: Re: Alternator stand stripped bolt Reply with quote
You can always put a steel insert in. I did all 4 so i can use bolts instead of studs so I can remove the alternator without removing the fan shroud.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
crankbait09
PostPosted: Mon Oct 10, 2022 4:44 pm    Post subject: Re: Alternator stand stripped bolt Reply with quote
never having done this before, you don't actually use an M10x1.25 tap in the M8 hole right? You have to drill no matter what, right?
I guess there is no way around drilling. I do like both options above. 1. stepped stud, and 2. the steel insert. Option 1 might be the easiest option.
1963 Ragtop
Mr. 010
Glenn is offline
PostPosted: Mon Oct 10, 2022 4:50 pm    Post subject: Re: Alternator stand stripped bolt Reply with quote
Put a stud in with some JB Weld.
It's a hack but will work.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
PostPosted: Mon Oct 10, 2022 5:02 pm    Post subject: Re: Alternator stand stripped bolt Reply with quote
Yep, always drill the proper sized hole before tapping. I like JB weld too. Lab-Metal also works great.
crankbait09
PostPosted: Mon Oct 10, 2022 5:04 pm    Post subject: Re: Alternator stand stripped bolt Reply with quote
so if i go that jb weld route. i already have a M8 hole, minus the fouled up threads. would you screw in the M8 stud as is, as far as it would go, and let it set up?
1963 Ragtop
Mr. 010
Glenn is offline
PostPosted: Mon Oct 10, 2022 5:06 pm    Post subject: Re: Alternator stand stripped bolt Reply with quote
I'd double nut the stud and drive it in as far as it will go and let it setup for a day or 2.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
crankbait09
PostPosted: Mon Oct 10, 2022 5:10 pm    Post subject: Re: Alternator stand stripped bolt Reply with quote
would you happen to know the stud length? I actually have M8x1.25 studs here that are 40mm long. would that work?
jb weld - is there a specific one to use? I have experience with one of them, but it was a putty.
1963 Ragtop
Mr. 010
Glenn is offline
PostPosted: Mon Oct 10, 2022 5:13 pm    Post subject: Re: Alternator stand stripped bolt Reply with quote
M8x38mm. You should be able to get a 40mm at any ACE Hardware store.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
allamaabroad
allamaabroad is offline
PostPosted: Mon Oct 10, 2022 5:14 pm    Post subject: Re: Alternator stand stripped bolt Reply with quote
I would just fix it correctly. A decent (offbrand) helicoil kit for m8 can be bought off amazon for less than $20. If I remember correctly, that hole doesn't go all the way through into the crank case, so there really is no reason to be scared of drilling. Even if it does go through to the crank case, small amount of magnesium chips that might get into the crank case are harmless and will likely just drain out on your next oil change.
Pickup a thread repair kit and a regular 8mm stud and you'll be all set. The 8mm thread repair sets are nice to have anyways, odds are this won't be the only stripped out hole you'll come across in your time with this car.
Mr. 010
Glenn is offline
PostPosted: Mon Oct 10, 2022 5:19 pm    Post subject: Re: Alternator stand stripped bolt Reply with quote
Or get circulated and imbedded in the crank or rod bearings.
Magnesium is not magnetic so there's a good chance they could float around.
The smart thing is to measure the depth of the hole and put a piece of tape on the drill bit to mark how deep you go.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
67rustavenger
67rustavenger is offline
PostPosted: Mon Oct 10, 2022 5:30 pm    Post subject: Re: Alternator stand stripped bolt Reply with quote
CB,
Careful with that fastener hole. It's open to the inside of the case there.
If you are thinking of drilling and tapping that fastener hole.
Stuff a clean rag into the filler penetration and fish it under the hole.
Like this,
Grease your drill bit to catch the case material being cut. Then tap the threads, with a greased tap. Carefully remove the rag.
If this were mine. I'd install a Time-Sert, available from amazon.
https://www.amazon.com/M8x1-25-Thread-Repair-1812-...13d670b6bc
ACN does not list this as a rental tool. At this time. Even though I have rented one there before.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
Mr. 010
Glenn is offline
PostPosted: Mon Oct 10, 2022 5:36 pm    Post subject: Re: Alternator stand stripped bolt Reply with quote
67rustavenger wrote:
Picture is worth 1000 words... good job Wink
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
67rustavenger
PostPosted: Mon Oct 10, 2022 5:56 pm    Post subject: Re: Alternator stand stripped bolt Reply with quote
Thank. I try to help, where I can! Wink
Buy Once, Cry Once!
esde
esde is offline
PostPosted: Mon Oct 10, 2022 7:33 pm    Post subject: Re: Alternator stand stripped bolt Reply with quote
JB weld the stud in now, fix it correctly someday when the engine has to come apart.
modok wrote:
Vanapplebomb
Vanapplebomb is offline
PostPosted: Tue Oct 11, 2022 12:31 pm    Post subject: Re: Alternator stand stripped bolt Reply with quote
For a normal STI tapped hole, a Helicoil is going to be the strongest repair. Most don’t want to hear it, but they are stronger than Timeserts. With Magnesium and aluminum, you need to use a prewinder to instal them properly. If you don’t use a prewinder tool to instal the Helicoil, the repair will almost certainly be weak. Prewinders are a bit pricey for what they are, but worth every penny, especially if you end up doing lots of Helicoils of that particular size.
1800 Type 4 Berrien 295
crankbait09
PostPosted: Tue Oct 11, 2022 1:24 pm    Post subject: Re: Alternator stand stripped bolt Reply with quote
I think I'm going to go the route of drilling out the hole to make it large enough for an M10. I'll order a M10 1.5 x M8 1.25 step stud and be done with it. (I hope)
I saw some step studs but they were only 38mm, is the 40mm stud the best option?
1963 Ragtop
RCP Phx
RCP Phx is offline
PostPosted: Tue Oct 11, 2022 1:31 pm    Post subject: Re: Alternator stand stripped bolt Reply with quote
Heli-coil is the only thing to do!
74 Thing
74 Thing is online now
PostPosted: Tue Oct 11, 2022 1:51 pm    Post subject: Re: Alternator stand stripped bolt Reply with quote
There are e-z loks too
https://www.amazon.com/Z-LOK-Threaded-Insert-Metal/dp/B07V5WSZNJ
