engine swap
27ram71
27ram71 is offline
PostPosted: Sat Jul 03, 2004 11:07 pm    Post subject: engine swap Reply with quote
Can you put a type 3 engine intoa bus?
keifernet
Samba Search & Rescue
keifernet is offline
PostPosted: Sun Jul 04, 2004 9:32 am    Post subject: Reply with quote
If you have a 71 or ealier upright engine, yes, you can take all the type 3 components off and the longblock is basically the same. Put all the type 1/2 upright components on and get a block of plate for the hole in the case for the type 3 oil fill /dipstick.
Other oddities may include needing to re-position the distributor drive gear and if the case is tapped for the oil pressure sending unit.
the oil cooler, and the heater boxes/ exhaust must be changed to the Type1/2 parts
