Weird cut metal under Oval window
RustPatch
RustPatch is offline
PostPosted: Thu Apr 27, 2023 11:02 am    Post subject: Weird cut metal under Oval window Reply with quote
In the process of metal work we found weird cuts to the metal under the back window at the corner of the the decklid. Has anyone else seen this? Before we fix it, is there any reason it should be there? The only thing I can think of was that the folded back metal helped keep in those socks they started shoving up there ...
It's on both sides but my second picture was blurry Embarassed
I've been known to be wrong.
BulliBill
BulliBill is offline
PostPosted: Thu Apr 27, 2023 11:50 am    Post subject: Re: Weird cut metal under Oval window Reply with quote
No reason that Volkswagen would have approved of, almost certainly hacked in by a previous owner... I'd fix it if it were mine.
Bill
Mission VW - San Fernando
Thornton VW - Stockton
Thanks for any help!
2Dokas
2Dokas is offline
PostPosted: Sun Apr 30, 2023 6:23 am    Post subject: Re: Weird cut metal under Oval window Reply with quote
Someone trying to cram in some large dual carbs and larger air cleaners?
87 Doka 2WD Ej22,
56 Convertible
RustPatch
PostPosted: Sun Apr 30, 2023 5:19 pm    Post subject: Re: Weird cut metal under Oval window Reply with quote
Thanks guys, I will fix it.
Dual Carbs ... that's probably it. Makes sense since they did this to it also ...
