Paper air filters for Kadrons?
sdebaker
sdebaker is offline
PostPosted: Wed Nov 08, 2023 9:39 pm    Post subject: Paper air filters for Kadrons? Reply with quote
Is there a paper air filter element that fits the Kadron carb filter housings? If yes, what is it?
Alstrup
Alstrup is offline
PostPosted: Thu Nov 09, 2023 11:52 am    Post subject: Re: Paper air filters for Kadrons? Reply with quote
10 seconds on Google:
https://www.napaonline.com/en/p/FIL2087
https://www.thesamba.com/vw/forum/viewtopic.php?t=435993
chrisflstf
chrisflstf is offline
PostPosted: Thu Nov 09, 2023 11:57 am    Post subject: Re: Paper air filters for Kadrons? Reply with quote
Napa actually has some pretty good stock basic repair parts. No hi po stuff
sdebaker
sdebaker is offline
PostPosted: Fri Nov 10, 2023 6:05 pm    Post subject: Re: Paper air filters for Kadrons? Reply with quote
Thanks for this. It is slightly narrower and a little shorter than the Kadron filter, but I'm going to try it.
The Kadron filter is a terrible bit of craft, IMHO, to filter dirt out of the air. I have seen a rigorous test of various filters, paper vs oil-wetted fiber in wire mesh. Paper is far superior.
APPLEGREENVW
APPLEGREENVW is offline
PostPosted: Fri Nov 10, 2023 6:18 pm    Post subject: Re: Paper air filters for Kadrons? Reply with quote
Those Napa air filters, are made to fit inside the original style Kadron filter assemblies.
https://www.thesamba.com/vw/classifieds/detail.php?id=2108469
Parts for sale https://www.thesamba.com/vw/classifieds/search.php?username=APPLEGREENVW
02/76 Beetle sedan
View user's profile Send private message Send e-mail YouTube Gallery Classifieds Feedback
DesertSasquatchXploration
DesertSasquatchXploration is offline
PostPosted: Sat Nov 11, 2023 1:42 am    Post subject: Re: Paper air filters for Kadrons? Reply with quote
Paper filters are not even close to being superior over wet filters but ok.
I built one of my Off-road filter housings to use a stock replacement paper filter the inside was full of silt after one weekend made an oiled foam pre filter lasted a few weekends then went to a cotton filter (Airaid) with the oiled foam pre filter went the whole year still clean.
Alstrup
Alstrup is offline
PostPosted: Sat Nov 11, 2023 6:58 am    Post subject: Re: Paper air filters for Kadrons? Reply with quote
I thought that was what you were after. But fair enough.
If it is a replacement filter for the later type gauze filter I´m not quite sure what fits. That said, if you drive in normal enviroment the oiled gauze filters are fine. If you drive in dusty enviroments a set of Outerwears over the gauze filters will work a long way. If you drive in the desert under extreme conditions a set of dual layer Unifilters or similar is probably the way to go.
Alstrup
Alstrup is offline
PostPosted: Sat Nov 11, 2023 7:09 am    Post subject: Re: Paper air filters for Kadrons? Reply with quote
I thought that was what you were after. but fair enough.
Backtotheeightiesagain
Backtotheeightiesagain is offline
PostPosted: Wed Nov 22, 2023 11:56 am    Post subject: Re: Paper air filters for Kadrons? Reply with quote
I think I did this before..
Kadron kits were designed in the day from what was laying around to fit. Like sixties US car parts. Think corvair and pontiac gto tri power...
Some maybe less tall to help clear engine lids etc just cut down the wire meshing.
MANN filter made the orig I had, I asked the question to the factory, and no was the answer. Maybe if you want several hundred payment up front....
But any better solution post pics I'm all ears (pointy ones).
Not seen any good ones for type 4 either.
