Dan_Lockwood Samba Member
Joined: October 03, 2023 Posts: 452 Location: Clare MI
Posted: Wed Jan 31, 2024 2:49 pm Post subject: Neal/CNC Clutch Slave Cylinder??? |
Sorry, not sure who's picture this is, but I hijacked...
When I had my Neal slave on my Type 1, it had lots of leftover adjustment like this one. BUT... On my 5-rib and using the original clutch cable retainer on the side, I cannot get the half ball ends and a nut on either end at the same time.
Is there another transaxle mounting bracket that everyone uses, or do you make a new longer base end stud and make it work?
Thanks, Dan |
jsturtlebuggy Samba Member
Joined: August 24, 2005 Posts: 4609 Location: Fair Oaks/Orangevale, CA
Posted: Wed Jan 31, 2024 4:41 pm Post subject: Re: Neal/CNC Clutch Slave Cylinder??? |
I just make a longer rod on adjustment side.
What usually I do is use a long bolt and cut off the head and use a die to cut threads on it.
The purple slave is a Speedway Motors part. It the cheapest replacement I have found and it the same inside as Neal/CNC and Wilwood. _________________ Joseph
Elrod Motorsports
Motion Tire Motorsports
Into Volkswagens since 1960 |
Posted: Wed Jan 31, 2024 5:31 pm Post subject: Re: Neal/CNC Clutch Slave Cylinder??? |
I just looked at the Speedway slave cylinder for $44.99. It says it's a .88" stroke. I have around 1.5" of stroke on my Neal cylinder. They have a Wilwood with 1.38" stroke.
I have no idea how much stroke the clutch lever actually moves once the throw out bearing is engaged with the pressure plate.
Just wouldn't want to order the wrong one. If the Speedway with .88" works for you, it should work for me...
Thanks, Dan |
Posted: Wed Jan 31, 2024 6:04 pm Post subject: Re: Neal/CNC Clutch Slave Cylinder??? |
I using the Speedway Motors #91025604 slave.
When I looked it up on their site it even said when I last purchased one. I used them on four different buggies. _________________ Joseph
Elrod Motorsports
Posted: Wed Jan 31, 2024 6:13 pm Post subject: Re: Neal/CNC Clutch Slave Cylinder??? |
jsturtlebuggy wrote: |
When I looked it up on their site it even said when I last purchased one. I used them on four different buggies. |
Thanks, that's good enough for me! |
Posted: Wed Jan 31, 2024 6:16 pm Post subject: Re: Neal/CNC Clutch Slave Cylinder??? |
I should add that I have always used a 5/8” clutch master cylinder. That is what Neal originally came with. It makes for easier to push pedal. Pedal does travel a little further.
Neal Products was originally the two Brothers, Bill and Chuck. Chuck went out on his own and started CNC Products.
Their original pedal assembly is a copy of a late 1950s Ford Anglia that a swing pedal setup the turn into a floor mount. When we first got into buggies I saw several buggies at Pismo using the Anglia pedals setup. _________________ Joseph
Elrod Motorsports
Posted: Wed Jan 31, 2024 6:43 pm Post subject: Re: Neal/CNC Clutch Slave Cylinder??? |
My Neal setup came with the buggy and had the Gerling (spelling) master cylinders. They are in very bad shape and I don't want to try to rebuild them.
The clutch was a 3/4" and the single brake was a 7/8" bore. I bought the Wilwood bail top type masters that are rated at high output. I guess that's what I need to run 4-wheel disc brakes. Since all of the braking system will be brand new, I'm not too concerned about a single piston cylinder for the four wheels.
The 3/4" master will push more fluid and be a bit harder to push than a 5/8". If I do get into a situation that I over stroke the slave, I can add a pedal stop to limit building up too much pressure and breaking something.
Thanks again, as always, for your help and replies.
Dan |
Posted: Wed Jan 31, 2024 8:07 pm Post subject: Re: Neal/CNC Clutch Slave Cylinder??? |
I use 3/4” master cylinders with 4 piston Wilwood type (JaMar) 4” pads in rear and 2 piston 2” pads on the front with a balance bar pedal setup.
The only time I would use a 7/8” master cylinder is with a 6 piston setup on the rear of.a buggy.
Wilwood makes good master cylinders. Most have a stainless sleeve in the bore like the CNC square reservoir masters.
One thing with the floor mounted pedal is the ratio is about 6 to 1 and with Wilwood swing pedals are about 7 to 1 ratio. More leverage with swing pedals.
I don’t have the best of knees is one reason I like less pedal effort. _________________ Joseph
Elrod Motorsports
