Stance after Dropped Spindles, too high?
63ragtopDud3
63ragtopDud3 is offline
PostPosted: Fri Mar 08, 2024 7:23 am    Post subject: Stance after Dropped Spindles, too high? Reply with quote
1963 Ragtop
drum brakes
stock beam
2.5" Drop Spindles
145/65-15 smoothies in front
165/80-15 smoothies in rear
1 or 2 outer clicks in rear (cant remember)
KYB 343144 Excel-G Gas Shock front and rear
The car is sitting too high in the front and I feel like the spindles didn't do anything. Not sure if its because I have smaller tires in the front and/or lowered the rear too much? I've been reading about people advising to not use gas shocks. Should I switch to crappy oil shocks? Keep in mind, there's no weight in the front right now (gas tank, seats, spare tire, etc) either, so I know I can close the gap by an inch after everything is said and done. But thats still too high.
I literally just put the body back on, would really hate to replace the beam at this point, but I feel like that's my solution. Not much for the tucked in look, so I'm thinking a 2" narrowed beam w/ adjusters is what I need to close the gap between the tire and fender.
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Fri Mar 08, 2024 7:25 am    Post subject: Re: Stance after Dropped Spindles, too high? Reply with quote
Did you install them upside down?
Something is not right. Should look more like this...
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
63ragtopDud3
PostPosted: Fri Mar 08, 2024 7:34 am    Post subject: Re: Stance after Dropped Spindles, too high? Reply with quote
Man, I freakin hope not. Not sure how I could have. Can you post a pic of your spindles for me, please?
Mr. 010
Glenn is offline
PostPosted: Fri Mar 08, 2024 7:36 am    Post subject: Re: Stance after Dropped Spindles, too high? Reply with quote
Not my car and I don't know if it's possible... I have an adjustable beam so I can dial in the exact height I want.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
63ragtopDud3
PostPosted: Fri Mar 08, 2024 7:42 am    Post subject: Re: Stance after Dropped Spindles, too high? Reply with quote
Referencing this screenshot from Jbug's installation video, I installed them like this...
Busstom
Busstom is offline
PostPosted: Fri Mar 08, 2024 8:10 am    Post subject: Re: Stance after Dropped Spindles, too high? Reply with quote
Why don't you post pics of your spindles so we can see what's up?
cory464 wrote:
63ragtopDud3
PostPosted: Fri Mar 08, 2024 8:15 am    Post subject: Re: Stance after Dropped Spindles, too high? Reply with quote
Busstom
Busstom is offline
PostPosted: Fri Mar 08, 2024 8:17 am    Post subject: Re: Stance after Dropped Spindles, too high? Reply with quote
Damn, they're on correctly...something else going on Confused
Hard to tell without being there, taking some measurements and looking all over. The rear end looks really low, but that doesn't change what's going on up front. Maybe take the shocks off and roll it around to settle it? Bounce on it and see if springs are stuck? But the torsion arms look pretty normal.
Edit: by the way, I just re-read your post and saw your comments on shocks; I think you'll be way more pleased with oil shocks, they're not crappy, and even gas shocks have oil in them, they just ride way harder than OE style shocks.
I don't think that's affecting the ride height much, not that much, but still take 'em off just to troubleshoot right now.
cory464 wrote:
djfordmanjack
djfordmanjack is offline
PostPosted: Fri Mar 08, 2024 8:24 am    Post subject: Re: Stance after Dropped Spindles, too high? Reply with quote
you mentioned correctly: No weight on the front. gas shocks. That's enough. maybe you tightened the link pins too much, or something in suspension is frozen. should be springy when you jump on the front. here's my dropped spindles, otherwise stock suspension. oil shocks. 62.
54 Oval project
62 Dickholmer, Seeblau L360
63ragtopDud3
PostPosted: Fri Mar 08, 2024 8:53 am    Post subject: Re: Stance after Dropped Spindles, too high? Reply with quote
Removed the shocks, bounced on the front a good bit. Very springy. Not really any difference though. Still 4" gap between tire and fender.
No gap between the frame and napoleon hat. All body bolts are fastened.
Maybe I screwed something up when I took off the torsion arms off to replace the seal? But if I recall, there was really only one way to put them back on.
djfordmanjack
PostPosted: Fri Mar 08, 2024 9:57 am    Post subject: Re: Stance after Dropped Spindles, too high? Reply with quote
do you still have the big rubber stops on the beam or did you cut the arms off ?
the rubber stop also stops the trailing arms in lower direction. If it's missing, your suspension will back of much further. it appears that way. your wheels are very much tucked forward.
don't worry so much. you got no glass, no interior, no tank, no sparewheel, no bumper. easily 150-200pds missing on the front end. it's sprung very softly. it will give in once you add the weight.
54 Oval project
djfordmanjack
PostPosted: Fri Mar 08, 2024 10:02 am    Post subject: Re: Stance after Dropped Spindles, too high? Reply with quote
adjusted axle left vs stock height right. you can easily see where the missing rubber stop will let it back out much further.
ignore the german text, was meant for my buddy.
also the spring holes are square with the trailing arms, so even mounting them upside down won't change the ride height.
54 Oval project
63ragtopDud3
PostPosted: Fri Mar 08, 2024 11:01 am    Post subject: Re: Stance after Dropped Spindles, too high? Reply with quote
Yes, bumper stops are still in place. If I sit on the front of the car (my whole 175 pounds), the car drops a couple inches and the wheel also looks as though it is more center with the well.
Maybe you are right missing all that extra weight in the front.
banana split
banana split is offline
PostPosted: Fri Mar 08, 2024 11:25 am    Post subject: Re: Stance after Dropped Spindles, too high? Reply with quote
That thing is sitting Baja status with those dropped spindles.
I bet these are the problem : KYB 343144 Excel-G Gas Shock front
Take them off and see if the front settles down. I would never run a stiff shock like that up front... especially on a lowered Bug. An oil shock will be much better suited... in my opinion.
My Beetles :
1953 Zwitter
1964 Chop Top
Busstom
Busstom is offline
PostPosted: Fri Mar 08, 2024 11:58 am    Post subject: Re: Stance after Dropped Spindles, too high? Reply with quote
Playing devil's advocate:
A front bumper is only 14 pounds, a tank FULL of gas is ~90 pounds. Glass and interior won't contribute much at all because that's all over the CG of the vehicle.
If the beam and spring configuration is stock, and the arms aren't resting on the torsion bump stops, then those aren't a factor.
Test for yourself, stack a hundred and fifty pounds right where the gas tank goes and see what you get (20 lb concrete stepping stones are one of my favorites).
cory464 wrote:
petrol punk
petrol punk is offline
PostPosted: Fri Mar 08, 2024 3:11 pm    Post subject: Re: Stance after Dropped Spindles, too high? Reply with quote
Don't switch to crappy oil shocks, switch to Sachs or Boge oil filled shocks. They're better than KYBs for everything that doesn't require a stiffer front end. The gas shocks act as a spring of their own. Get some stock shocks in there, finish the car with all the extra weight that brings, settle the suspension, and you should be looking much better.
36hp '56 European DeLuxe oval
'70 bug 1835cc
Jeff Geisen
Samba Chaplain
Jeff Geisen is offline
PostPosted: Fri Mar 08, 2024 5:46 pm    Post subject: Re: Stance after Dropped Spindles, too high? Reply with quote
Appears to me you installed something other than drop spindles.
I Corinthians 4: 1 thru 5
‘63 ragtop - ‘68 single cab
jbannon
jbannon is offline
PostPosted: Sat Mar 09, 2024 8:52 am    Post subject: Re: Stance after Dropped Spindles, too high? Reply with quote
Have you checked if you over tightened the link pins? If they are too tight and were tightened when the beam/car was on stands, you essentially locked the trailing arms on place.
Another question: Did you replace the torsion plates with new ones? That will have an effect on ride height as well.
63ragtopDud3
PostPosted: Sat Mar 09, 2024 12:41 pm    Post subject: Re: Stance after Dropped Spindles, too high? Reply with quote
@jbannon .. I did not replace the torsion plates, only the bushings.
I think I found the issue... or atleast one of them. I put three 60lb sand bags in the trunk and removed the shocks. That got me a couple inches down to a more reasonable stance. I then realized that the passenger fender seems to flare out more than down, if that makes any sense. I took measurements of both fenders and found that the drivers side is essentially wider by about an inch. After doing some research on here, I believe my drivers side is from a 59 due to the conduit coming out of the back of the headlight bucket and other contributing factors. Would someone else with a early 60s beetle be able to take some measurements for me where I have it taped off? Thanks!
Busstom
Busstom is offline
PostPosted: Sat Mar 09, 2024 3:34 pm    Post subject: Re: Stance after Dropped Spindles, too high? Reply with quote
63ragtopDud3 wrote:
...I put three 60lb sand bags in the trunk and removed the shocks...
That should be about right, I forgot to include the spare and a stock jack, which would add ~35 lb to the full gas tank and bumper.
Fenders should all the the same through the years...but I measured a couple mid-60s fenders just now and came up with ~12 inches where your long piece of tape is. I'd be more curious about the arch of the fender, if a fender gets pushed in on the front, the arch will tighten up and grow upwards slightly.
cory464 wrote:
