Early 68 9 Pin Flasher Mounting
Bryan67
Bryan67 is offline
PostPosted: Wed Mar 13, 2024 1:06 pm    Post subject: Early 68 9 Pin Flasher Mounting Reply with quote
I have an early 68 (September) Squareback. I’m in the process of trying to figure out the wiring as I’m installing an ISP West reproduction harness. A lot of you may know that this is not an easy task on an early 68. And I’m trying to keep the wiring mostly original. It’s been two years since I took it apart, and I can’t remember where the flasher relay mounts under the dash. Apparently not the same as a 67, or a later 68 as those use a different relay. Any help, and pictures would be greatly appreciated.
If you`re going to do something, do it right.
CalLookVdub
CalLookVdub is offline
PostPosted: Mon Mar 18, 2024 4:29 pm    Post subject: Re: Early 68 9 Pin Flasher Mounting Reply with quote
Check this out. Found on here while searching. I have been looking for the same thing basically, but I have a '67. My wiring was totally butchered.
https://www.thesamba.com/vw/forum/album_page.php?pic_id=2032285
My Rides
'58 beetle - L335 Capri Blue
'63 15 window Deluxe
'67 Squareback
'68 Sunroof beetle - 1st bug, bought back
'70 Bay window deluxe
'14 Jetta SE 1.8T
CalLookVdub
PostPosted: Mon Mar 18, 2024 4:31 pm    Post subject: Re: Early 68 9 Pin Flasher Mounting Reply with quote
Or this? I was able to find using "relay" in the type 3 gallery search.
My Rides
'67 Squareback
'14 Jetta SE 1.8T
Bryan67
Bryan67 is offline
PostPosted: Tue Mar 19, 2024 10:27 am    Post subject: Re: Early 68 9 Pin Flasher Mounting Reply with quote
Afraid not. Thats a later 68 setup. Different relay. But the bracket may be the same. Or at least similar.
