1976 T2 Transporter - fuel sending unit question
muzikmark
muzikmark is offline
PostPosted: Sat Jul 13, 2024 5:29 am    Post subject: 1976 T2 Transporter - fuel sending unit question Reply with quote
Hi All.
I'm replacing my fuel sending unit. I have an access panel to it and have it loose but it won't come out.
Every video I watched it just popped right out.
Am I missing something?
Thanks!!
jlrftype7
jlrftype7 is offline
PostPosted: Sat Jul 13, 2024 6:19 am    Post subject: Re: 1976 T2 Transporter - fuel sending unit question Reply with quote
A picture or two of your vehicle , at the spot you're having trouble, would help.
Welcome to The Samba... Smile
I pasted a link from another member on how to load photos below-
https://www.thesamba.com/vw/forum/viewtopic.php?t=6
‘84 Tin Top - Hilga....Auto
airschooled
Air-Schooled
airschooled is offline
PostPosted: Sat Jul 13, 2024 9:23 am    Post subject: Re: 1976 T2 Transporter - fuel sending unit question Reply with quote
How are you grabbing it to twist? It’s a bayonet style mount, so it needs a little spin lefty-loosey. I use a giant pair of channel lock pliers or the Harbor Freight oil filter pliers. Sometimes a screwdriver in the slot with just the right rubber mallet persuades it to break free even quicker.
Have a new o-ring on hand, a tiny bit of grease on it helps with reinstallation. If the sender spins in too easily and wiggles, congratulations you get to buy an oring from someone else and try again.
Robbie
www.airschooled.com
muzikmark
PostPosted: Sat Jul 13, 2024 11:13 am    Post subject: Re: 1976 T2 Transporter - fuel sending unit question Reply with quote
I used channel locks same way.
I have a new o-ring and fuel sending unit ready to go.
Just seems like I can't get this guy to come out.
Will post pictures of my bus and the sending units soon.
aeromech
aeromech is offline
PostPosted: Sat Jul 13, 2024 7:10 pm    Post subject: Re: 1976 T2 Transporter - fuel sending unit question Reply with quote
Curious about which sender you’re installing?
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
muzikmark
PostPosted: Sun Jul 14, 2024 4:57 am    Post subject: Re: 1976 T2 Transporter - fuel sending unit question Reply with quote
It is loose.
Twisted to the left and it only turns so far but it is loose.
I just can't get it to come out.
mikedjames
mikedjames is offline
PostPosted: Sun Jul 14, 2024 5:42 am    Post subject: Re: 1976 T2 Transporter - fuel sending unit question Reply with quote
When it gets as far as it goes , try going back a small amount and rocking it from side to side, lifting. It could be that one of the bayonet mounting "fingers" is caught because it is turned too far..
It should come out fairly easily when you get the rotational position exactly right..
See how the sender has protrusions that carry little "ramps" that cause it to seal down onto the tank as you tighten it .
Borrowing a picture from the gallery..
( This shows a better made part than what you will get these days, the resistance track is wound with the correct progressive winding pitch change to make the gauge read more accurately. )
Ancient vehicles and vessels
muzikmark
PostPosted: Mon Jul 15, 2024 2:39 pm    Post subject: Re: 1976 T2 Transporter - fuel sending unit question Reply with quote
Thanks for the responses and tips.
I finally got it out and installed a new one.
After all that, the gauge still does not read correctly.
I have nearly a full tank of gas and the gauge reads half tank.
Guess I'll be looking for one of those next!
Thanks again!
And what do most of you use to post pics?
Back in the day I used Photo Bucket but I haven't been on message boards for awhile.
75 Westy FI noob
75 Westy FI noob is offline
PostPosted: Sun Jul 20, 2025 9:16 am    Post subject: Re: 1976 T2 Transporter - fuel sending unit question Reply with quote
Is there no speciality tool for this type FSU ?
I have a new one and it just will not turn.
1/2” drive 4 prong tool …. There outa be one.
Ive tried the harbor freight oil filter wrench.. working on it in the bus through cut hatch (expanded from a C cut to square hole).
Tapped a screwdriver .. Ive slightly raised the leading edge of the tabs and oiled them.. no luck.
this new one is very very tight.
ive cut myself and put in a lot of time.. wife is starting with the “just sell the damn thing” mantra so it’s getting serious. Laughing Rolling Eyes
I may give this a shot. Would like to find a 4 pin tool though so I could put some downward pressure on it.
https://www.amazon.com/1266-Adjustable-Wrench-Diameter-Construction/dp/B08LGZ93TK
Last edited by 75 Westy FI noob on Sun Jul 20, 2025 9:51 am; edited 1 time in total
mikedjames
PostPosted: Sun Jul 20, 2025 9:43 am    Post subject: Re: 1976 T2 Transporter - fuel sending unit question Reply with quote
Thanks again!
I just bought a BBT sender and it seems to be reading more accurately than my linear wound sender (JP Group) .
Showing the required non- linear resistance winding.
And a Made in Mexico label.
Posting pictures by uploading them to the Samba gallery: links below the text entry frame here.. Too many hosting providers start charging for storage or float off belly up.
75 Westy FI noob
PostPosted: Sun Jul 20, 2025 11:38 am    Post subject: Re: 1976 T2 Transporter - fuel sending unit question Reply with quote
What tool do you use to instal it ?
SGKent Premium Member
SGKent is online now
PostPosted: Sun Jul 20, 2025 12:49 pm    Post subject: Re: 1976 T2 Transporter - fuel sending unit question Reply with quote
if it is the rotating kind, the old seals swell and lock it in place. I use a chisel at 90 degrees to tap it around to unlock it. When locking it do not go too far. Use a new seal with a little silicone grease on it.
75 Westy FI noob
PostPosted: Sun Jul 20, 2025 12:56 pm    Post subject: Re: 1976 T2 Transporter - fuel sending unit question Reply with quote
do you use a chisel to instal it also?
Due to the downward angle, the far side pips up when i try that method.
Im very surprised there is t a purpose built tool for these things.
busdaddy
busdaddy is offline
PostPosted: Sun Jul 20, 2025 2:24 pm    Post subject: Re: 1976 T2 Transporter - fuel sending unit question Reply with quote
There probably is, but as a one and done thing for home use I doubt it'd sell well at a price that still makes it worthwhile for the seller.
If you are working through a hole straight down you might be able to find a section of plastic drain pipe you can saw some teeth into to engage the notches, bore a hole through the other end to stuff a dowel through. A crafty guy could even do something like screw pieces of steel bar to the sides of a pipe or round wooden stick of the right diameter. Or get all 21's century on it and whip up a 3D printed wrench for it.
Or use a blunt brass punch like I do, alternating hits on each side keeps it from getting sideways, brass prevents sparks.
Слава Україні!
PostPosted: Sun Jul 20, 2025 3:32 pm    Post subject: Re: 1976 T2 Transporter - fuel sending unit question Reply with quote
I should have mentioned I use a brass chisel/drift. I've always had the tank out when doing this but I am coming in at 90 degrees. I start it with my hands wearing gloves as far as I can turn it first. I always use a new seal with some silicone grease on it.
PostPosted: Sun Jul 20, 2025 3:47 pm    Post subject: Re: 1976 T2 Transporter - fuel sending unit question Reply with quote
looking at the top and tools available, I think I would get a piece of flat steel and cut it to fit the notches if one has to get to it only from the top. I found one tool on amazon but it says I live in the wrong place to order it.
https://www.amazon.com/OEMTOOLS-25156-Module-Spanner-Wrench/dp/B004FDL3BS
This one might be modified to work
https://www.amazon.com/Adjustable-Wrench-Remover-Spanner-55mm-160mm/dp/B08Z7T5QPJ
or get an old rusty ready to go toss socket and use a dremel wheel to cut 4 tangs that fit.
airschooled
Air-Schooled
PostPosted: Sun Jul 20, 2025 10:03 pm    Post subject: Re: 1976 T2 Transporter - fuel sending unit question Reply with quote
Vanagon sender shown but it’s the same concept on some new plastic senders.
https://drive.google.com/file/d/1vj6-XedyE1h6vIT6TKz1ewQYkSRF9xD7/view
If you have metal tabs, you’re using SuperLube grease on the o-ring right?
www.airschooled.com
germansupplyscott
germansupplyscott is offline
PostPosted: Mon Jul 21, 2025 10:33 am    Post subject: Re: 1976 T2 Transporter - fuel sending unit question Reply with quote
Here is a tool I made for re/re the bayonnet style fuel senders. It's a modified cup style oil filter wrench. Works well.
There is a factory tool for the Vanagon plastic fuel senders, I'll post a pic of that later. I've never seen a VW tool for the metal senders but I'd be surprised if there wasn't one.
SL
PostPosted: Mon Jul 21, 2025 12:44 pm    Post subject: Re: 1976 T2 Transporter - fuel sending unit question Reply with quote
great job Scott.
Wildthings
Wildthings is offline
PostPosted: Wed Jul 23, 2025 3:00 pm    Post subject: Re: 1976 T2 Transporter - fuel sending unit question Reply with quote
If you cut a square or rectangular hole in the rear deck, a large screwdriver or other pry bar against the edge of the hole will remove and install the sender nicely.
