Seat rebuild Question
RealThing74
RealThing74 is offline
PostPosted: Fri Nov 01, 2024 6:27 pm    Post subject: Seat rebuild Question Reply with quote
Rebuilding seat Q.
I need to replace some of the seat attachment pieces (barbs), See pic.
Couple of Questions.
1. Do I need to take the broken ones off or can I put the New Barbs next to the broken ones?
2. How to attach the new ones weld them on or can you drill a hole in them and them attach with a screw?
Mike
81 Vanagon Westy
74 Thing Currently under a pan off restoration
73 Standard Beetle that we tow behind our Motorhome & use for sightseeing.
Click to view image
74 Thing
74 Thing is offline
PostPosted: Sat Nov 02, 2024 9:30 am    Post subject: Re: Seat rebuild Question Reply with quote
You can grind the old welded ones off it you want and can either weld the new ones on, use a sheet metal screw, or pop rivet.
Heiferman
Heiferman is offline
PostPosted: Mon Nov 11, 2024 12:45 pm    Post subject: Re: Seat rebuild Question Reply with quote
And you do not have to take the old ones off if you don't want to. You could flatten or cut off what was left but putting the new ones beside them would work just fine.
- 1973 Thing, 1970 Ghia, some LandCruisers and an old Ambulance
